Non-damaging removal of rust from chromed parts.
Grewth
UK
I've got quite a collection of chromed parts, where the chrome is in presentable condition, but the reverse side has a good layer of surface rust.
Both the mudguards ( just picked up a nice rear one), the headlamp rim, rear unit shrouds (XS1B), and the tail lamp mounting.
Lots of bits in fact. I know that this wouldn't bother most folk, and I could just ignore the rust, or even slap a thin layer of grease over it.
But what I'd really like to do is chemically remove the rust then apply some sort of neutral coloured primer, maybe silver grey ?
I'm just wondering what will strip the rust without damaging the chrome ?
I know that a lot of rust stripper is acid based, and I can remember what battery acid did to the chrome on some of my bikes.
Yes, that's good stuff, but I'm not sure he can get it in the UK? It's also not cheap.
Try Citric Acid on a test piece. It comes in powder form from Garden supply shops. Also 0000 wire wool and oven cleaner works but needs elbow grease.
I would be wary of electrolysis and chrome. I believe there are toxic by products and it would be difficult to only do one side of an item.
As suggested vinegar is ok but I find it slow and I don’t like the flash rusting. If you can find Evaporust or equivalent that would be your best bet. Electrolysis on chrome parts isn’t a good idea because of the toxic by products. Quick and fairly easy is wire brush, degrease and a coat of POR15 then spray or brush a top coat to prevent the POR15 from discolouring.
Yeah I had that problem when I tried to buy "aircraft stripper "
It was still available in the US at the time but banned in the UK, and nobody would ship it from the US
Vinegar is cheap :agree: and safe to work with
I got hold of a gallon of "non brewed condiment " once upon a time (probably thirty years ago), it's the concentrate that they make vinegar from in Fish and Chip shops.
Now that stuff was not safe to work with, but I bet it would dissolve rust in minutes.
Probably impossible to get hold of now unless you're in the trade
diet Coke/diet Pepsi and scotch brite or maybe something less liable to scratch... the diet coke is for this purpose a dilute maybe buffered (dunno 4 sure) solution of phosphoric acid salts....eats rust. https://en.wikipedia.org/wiki/Phosphoric_acid Whether or not it's a good idea... no idea about that. Anyway we keep a bottle on the chemical shelf for the rust chemistry problems,,,and also keep Kroil and wintergreen...
I just tried Evaporust for the first time. It’s definitely safe for chrome. $30 per gallon. My phosphoric acid solution is much cheaper.
I bought this over the weekend, below. Probably similar stuff. There's a few brands readily available here but this was delivered next day from the makers and postage free. So I'll be giving this a go later this week on some generally rusty stuff and probably some chromed stuff.
Orthophosphoric acid
