2 Old Rattle guns landed here .Someone else given up on
The Aluminium one is a Atlas Copco LMS - 24
Quality Brand over here .
Have sent them an e -mail if any service kits is available
O rings and Plastic is worn the trigger has to much play so it leaks.even with new O rings
And the internal slide valve a bit worn also leaks a little
Spring looking like a tweezer fell out No clue where it goes cant figure it out for Now
The Air motor is weak it is dirty and after a bit cleaning it turns a little but still weak
Maybe need new rotor wings and inside + plastic
But the metal parts looks fine
The yellow one is probably a low grade machine
Does not turn and don't keep the oil inside
Might throw it
If anyone done it please share thoughts Usual way Forward besides new O -Rings
Might throw it
