knife steel
case hardening is still used extensively in industry, in various forms, one of the biggest uses is gears, since you want the hard wear resistant tooth, but a tough core.
one trick i used to make a bread knife useful when i was in colege was to selectively heat treat different parts of the blade basically quentched only the edge of the blade, the re-annealed the back. it served me well since, though i now have proper kitchen knives, haven't had to sharpen it since.
it's basically (simplified) how the japanese heat treated their swords, (the source of the pattern on the blade, different phases of steel, the pattern dictated by he clay used to prtect the edge during annealing)
Visegrippe, I would like to make a katana I don't have the skills for that though
I copied this from this videos description
The authentic Japanese sword is made from a specialized Japanese steel called "Tamahagane" which consist of combinations of hard, high carbon steel and tough, low carbon steel. There are benefits and limitations to each type of steel. High-carbon steel is harder and able to hold a sharper edge than low-carbon steel but it is more brittle and may break in combat. Having a small amount of carbon will allow the steel to be more malleable, making it able to absorb impacts without breaking but becoming blunt in the process. The makers of a katana take advantage of the best attributes of both kinds of steel. This is accomplished through a number of methods, most commonly by making a U-shaped piece of high-carbon steel (the outer edge) and placing a billet of low-carbon steel (the core) inside the U, then heating and hammering them into a single piece. Some sword-makers use four different pieces (a core, an edge, and two side pieces), and some even use as many as five.
The block of combined steel is heated and hammered over a period of several days, and then it is folded and hammered to squeeze the impurities out. Generally a katana is folded no more than sixteen times, then it is hammered into a basic sword shape. At this stage it is only slightly curved or may have no curve at all. The gentle curvature of a katana is attained by a process of quenching; the sword maker coats the blade with several layers of a wet clay slurry which is a special concoction unique to each sword maker, but generally composed of clay, water, and sometimes ash, grinding stone powder and/or rust. The edge of the blade is coated with a thinner layer than the sides and spine of the sword, then it is heated and then quenched in water (some sword makers use oil to quench the blade). The clay slurry provides heat insulation so that only the blade's edge will be hardened with quenching and it also causes the blade to curve due to reduced lattice strain along the spine. This process also creates the distinct swerving line down the center of the blade called the hamon which can only be seen after it is polished; each hamon is distinct and serves as a katana forger's signature.
The hardening of steel involves altering the microstructure or crystalline structure of that material through quenching it from a heat above 800 °C (1,472 °F) (bright red glow), ideally no higher than yellow hot. If cooled slowly, the material will break back down into iron and carbon and the molecular structure will return to its previous state. However, if cooled quickly, the steel's molecular structure is permanently altered. The reason for the formation of the curve in a properly hardened Japanese blade is that iron carbide, formed during heating and retained through quenching, has a lesser density than its root materials have separately.
After the blade is forged it is then sent to be polished. The polishing takes between one and three weeks. The polisher uses finer and finer grains of polishing stones until the blade has a mirror finish in a process called glazing. This makes the blade extremely sharp and reduces drag making it easier to cut with. The blade curvature also adds to the cutting power.
