Mikes xs
xsgirl,
You should not start multiple threads with the same question or topic. If you want to add to your original post, then just post a reply instead of starting a new thread. A thread is a series of posts started by one member and answered by other members with a post. You can reply to your own post with a reply as well to continue the conversation.
To answer your question about the cam chain guides.
There has been a member report he has installed multiple guides with the correct torque and not had a problem.
On the other side of the coin there has been several members report stripped out thread holes.
There was a short time when these were in short supply. Not available anywhere.
Unless a member had a spare or two to help keep folks going.
Now again they are available through most outlets including Yamaha.
Difference in the one from Yamaha as opposed to Mikes? Can't say personally.
