front sprocket nut torque
Primary drive gear nut torque specifications per Haynes manual-
xs650, xs650 SE (UK),
xs650 E,F,G,H,SE,SF,2F,SG,SH,SJ,SK (US)
65 ft/lbs
xs650 D (US)
58-82 ft/lbs
- always thought the primary drive nut was on the crank
- the drive sprocket nut torque varies depending on what model and manual you read
- XS1-XSB 22mm...10-12 m-kg...72-87 ft-lbs
- XSE 22mm.............5.0 m-kg...36 ft-lbs
- XS 78-80 22mm......6.5 m-kg...47 ft-lbs
