re mikes Xs big green single coils wheres + or - ???
2phased
No where
Just finished mounting mikes big green coils to my 277/750
when i noticed that theres no indication on the coil what terminal is positive or earth !!
anybody help
J
great so since i have 2 x single coils which goes to the kill switch and which goes to power or does it matter ?
2phased,
Well, actually, it does matter on a single output coil. The correct polarity will produce a negative voltage to the spark plugs. A negative voltage is 40% more efficient than a positive voltage. Also, the timing light is designed to work best with a negative voltage.
Here is a pic of the coil:
The green wire goes to the green wire on the PAMCO the red wire goes to switched battery (+).
I guess on single outputs...never thought of that. I don't remeber if my dual output greenie had polarity markings. but then one side is - and one is + on the secondaries correct?
So. Possibly a dumb question. Red to the kill (red with white stripe)? Green to points signal wire and condenser. I'd love an illustration of this set up if anyone has time. Or a pic of your similar set up. I just wanna do this right the first time
On a dual output coil it does not matter. Single output it makes a difference, but the coil should be marked + or -. Plus side to the switch.
Unfortunately the coil wasn't marked I just copied pamco peters picture above. I wonder why they wouldn't mark them. Did they just stop doing that?
It's part# 17-6807 single tower xs performance high output coil from 650 direct. Aka Canadian version of mikes xs. I'm extremely new to terms so I don't know weather they're single or dual output coils.
Re post #6 Pamcopete that information is golden. In ignorance I also assumed it made no difference. Thanks for posting.
Yes green, grounds through the points.
Here is a method to verify that the output of the coil is negative:
Only one of the outputs from a dual output coil will pass this test. The other output is positive, which is 40% less efficient, hence the reason why most dual output coils are called "high performance" and produce a much higher voltage than ordinary coils to compensate for this inefficiency.
Possibly this one?
