XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. Itís free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 07-07-2011, 07:03 PM   #1
1980 xs650special
1980 xs650special's Avatar
Default Valve adjustment
I'm a newby at some of the engine adjustments but can anyone explain in detail how to adjust the valves on a stock '80 xs to the right tolerances?
1980 xs650special is offline   Reply With Quote
Old 07-17-2011, 01:47 PM   #2
XSLeo
XS650 Guru
XSLeo's Avatar
Default Re: Valve adjustment
Two words, repair manual. Get one.
The only way you can find out if you can do something is to try.
75 XS650B with a few mods, Dual disc brakes up front, Disc on rear, Pamcopete Ignition with the green coil, Radio Shack rectifier and Chrysler regulator, LED tail/brake and turnsignals. 750 kit,1.5 headepipes, Emgo shorty mufflers.
XSLeo is offline   Reply With Quote
Old 07-17-2011, 01:59 PM   #3
cmattina1
cmattina1's Avatar
I used that, ended up with my valves wide open. There is a youtube video that in conjuction with the manual is more useful
1978 Special (1975 engine, PAMCO, pod filters)
1974 RD350 (winter project?)
cmattina1 is offline   Reply With Quote
Old 07-17-2011, 04:13 PM   #4
CDNTX650
XS650 Guru
CDNTX650's Avatar
Quote:
holy fuck you guys, not rocket science.
Put motor to TDC using the marks on the stator/rotor, pull exhaust/intake and tappet cover off of one side or all of them for all i care....one side should have wiggle up and down on both intake and exhaust tappets (other will be tight) which means that cyl is a TDC on the comp. stroke. Use your feeler guages to set .004 on the intake and .006 on exhaust if memory serves me correct. Rotate engine 360* and do the other side.
If any of this confuses you time to buy a new bike and have your dealer look after you. The manual is very easy to follow to set valves...all i have is a clymer.
and these are set cold....not warm...cold, like sitting over night.
2010 Kawasaki Versys
1974 TX650A resto modded and never done....new...everything..cases up.
1974 engine...Rebuilt. ...waiting patiently on the stand.
2014 triumph scrambler.
1971 plymouth valiant....she's minty!
CDNTX650 is offline   Reply With Quote
Old 07-17-2011, 08:00 PM   #5
cmattina1
cmattina1's Avatar
So, if the tappets wiggle a little bit, enough to notice, that means they wiggle MORE that .006 or .004.
Where do you adjust them to, the widest the gap gets, or where they rest?
Old 07-17-2011, 08:02 PM   #6
jamesgs4
fuck this, let's ride!
jamesgs4's Avatar
at TDC.
get a free manual at www.biker.net
jamesgs4 is offline   Reply With Quote
Old 07-17-2011, 09:06 PM   #7
CDNTX650
XS650 Guru
CDNTX650's Avatar
They will wiggle ever so slightly at TDC of the ones you are checking because there is no pressure on them from the cam. Both valves are closed for the compression stroke meaning everything is at rest.. the other side is on an exhaust stoke so the valves are tight/exhaust valve is being pushed on...you can see that. You can feel that .004 and .006 although minute.
when starting from scratch after a rebuild you will have to watch for the exhaust valve being pushed on to figure out which side as all of your tappets should be backed right off for reinstall of the rocker box.
maybe you don't understand the feeler guage part of it. Will a .004 guage slide in to the little gap between the tappet and the valve stem on that side (intake) at tdc....if not then they are tight..if a anything bigger fits in then they are loose.......back the lock nut off and back the tappet off till a .004 guage will fit in...hold tappet with little wrench...tighten lock nut to hold that setting. done.
Old 07-18-2011, 11:06 AM   #8
cmattina1
cmattina1's Avatar
i did understand it, but at the time i was using an adjustable wrench rather than the tappet wrench and to find TDC i used a penlight and looked through the spark plug hole... so, when re tightening the locknut the tappet was moving with it and with the adjustable wrench, it was hard to hold on to the little tip.
I did go out this moring and take a looking using the T mark and the tappet wrench, and it seemed to go alot smoother. Though i'm still getting that rattle! I guess it is just the lud tappets. My cam was set at flush at TDC on a warm engine, i don't know what else i can do...
Old 07-18-2011, 11:09 AM   #9
bloodthirstysystem
bloodthirstysystem's Avatar
they are supposed to rattle when you shake them. if they didn't your valves wouldn't be closed all the way
bloodthirstysystem is offline   Reply With Quote
Old 07-18-2011, 11:19 AM   #10
cmattina1
cmattina1's Avatar
nah, i meant after i started it. It is making the metal rattle sound. A lot of people say, "adjust your cam and your valves and it will go away". Many others say, "they all sound like that"
I will double check my clearances, though they all seemed good: Could slide the feelers in with a tiny bit of resistance?
Old 07-18-2011, 11:31 AM   #11
5twins
XS650 Guru
5twins's Avatar
That's how you're supposed to use them. They don't call them "feeler" gauges for nothing, lol. They're supposed to slip in and out with a slight drag when clearance is correct. And if you had a manual, why would you try to find TDC with a flashlight through the plug hole?
'78E Standard and 4 Euro twins
5twins is online now   Reply With Quote
Old 07-18-2011, 11:49 AM   #12
cmattina1
cmattina1's Avatar
I wasnt looking hard enough at the rotor when i was rotating the engine and couldn't find the T mark. at the time, i was just googling, and one of the intructional sites mentioned that not all rotors had the T mark. this of course was only days after i bought the bike. As I said, i learned from my mistake, i'm a Environmental studies student with little background in mechanics. Only one way to start, right?
Old 07-18-2011, 12:26 PM   #13
gggGary
Old guy, NO expert.
gggGary's Avatar
I would have guessed English Major but I suppose environmental studies is today's equivalent.
"The goal of the forum is sharing our experiences and what we've learned,
not dismissing the ideas of others"
gggGary is offline   Reply With Quote
Old 07-18-2011, 12:33 PM   #14
Maddog Marty
Alotta Patina
Maddog Marty's Avatar
Cmattina1, I've gotta say that I admire you for doing this and working to figure it out. So many of us assume that things are easy when we know all about them (like when I ask my kids to help with my iPhone or computer...they know so much more than I do!). Anyway, good luck and best wishes, and please keep asking and looking. What you say makes sense, and if you've never used feeler gauges before I understand why you may be having difficulty. Especially in a little, crowded area like that for your first time with feelers. Keep asking, keep us posted on your activities and progress. I, for one, am THRILLED with someone apparently your age getting into these and making a go of it.
Maddog Marty
"Mr. Bad Example"
Maddog Marty is offline   Reply With Quote
Old 07-18-2011, 01:03 PM   #15
cmattina1
cmattina1's Avatar
Environmental studies may be today's english equivilent indeed, my friends and I joke about it all the time. To boot, my undergrad is "Outdoor Recreation" and my masters is actually environmental studies! I get a lot of flak from my dad who is a millwright. Regardless, I got it all done today and I didn't screw anything up! As I said before, i just wasn't putting a fine enough touch on things with the adjustable: Thank god the bike came with a complete yamaha tool kit.
Old 07-18-2011, 01:55 PM   #16
gggGary
Old guy, NO expert.
gggGary's Avatar
My excuse is: I may have siphoned one gas tank too many as a youth by sucking on the tube..............
Old 07-18-2011, 02:13 PM   #17
cmattina1
cmattina1's Avatar
the good news is, brain cells grow back!
good news for many of us !
(and bacon contains certain chemicals that prevent heart attacks)
Old 07-18-2011, 02:14 PM   #18
501Spanky
501Spanky's Avatar
My home town of Thunder Bay! As I was reading, I was think to myself - "at least he's not an outdoor reccer" LOL
Welcome to the board, lot's to learn here
SAWZALL CREW MEMBER #3!
2003 Vulcan 1500 Classic (geezer glide)
1983 XS650 Heritage Special Hardtail Chopper
501Spanky is offline   Reply With Quote
Old 07-18-2011, 02:17 PM   #19
cmattina1
cmattina1's Avatar
I did not get along with the majority of the people in my classes. Luckily i get compliments from many on how i am the "first outdoor reccer i get along with". Being from downtown hamilton helps in not being one of those suburban tree huggers
Old 03-06-2013, 04:30 PM   #20
Jon1wdsmen
Ride Loven
Jon1wdsmen's Avatar
Intake .004? Clymer says .0025 I know that they varied it in early years but mine is a 1980 G model. Clarification so I don't beat the hell out of things on a fresh complete over haul. The shop that did the heads wrote .004 intake and .006 exhaust
1980 XS650G
Jon1wdsmen is offline   Reply With Quote
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
Valve Adjustment Theory Or Hypothisis? ReycleBill The Garage 16 07-10-2011 12:22 PM
83 heritage special valve adjustment? .002 and .006? section8joe The Garage 1 05-10-2011 07:46 PM
Valve Adjustment - Quick Question bdholsin The Garage 8 04-23-2011 11:27 AM
Cam chain adjustment royxxx The Garage 3 11-04-2010 02:29 PM
Oil after valve adjustment harmonc The Garage 13 09-08-2010 11:43 AM
Tags
engine
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
