| Welcome to XS650.com! |
| XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. It’s free and only takes a minute. Proceed to registration. (This notice will go away once you log in) |
| The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear) |
Thread Tools | Search this Thread |
#1 |
I like metal.
![]() Yup, you have seen it. Thought about it, and didn't buy it. But for a little over $100, it's a great set of dies. The rest of it is cheap. I know a company over on Pirate4x4 sells upgraded parts (Google it, there's a ton of info). But, the main problem is still poor alignment and curved bends with the crappy stamped steel housing. I like mine, but it needs work. The rolls always curl. My first complaint is that the dies are fixed. The best soluton is those fancy waterjet cut sides with multiple holes for adjusting dies. But I don't have waterjet. I want to modify one of the Harbor Freight 12-ton hydraulic PIPE benders so I can put the dies in to it. I understand it's still going to require some work to mount the wheel assembly. ![]() In the mean time I'm going to head to HF and measure the frame on the pipe bender. do any of you own one? |
Delinquents Car Club, Twin Cities Minn.
#2 |
If you fill your tubing full of sand and cap the ends, they make a better bend. Just a little trick I learned years ago. Esp. with aluminium.
#3 |
I like metal.
This design sparked the idea. One of the best ones I have seen for a home build.
#4 |
I like metal.
Are you saying to fill it and cap when you are using a roller?
I'm not trying to bend tubingor pipe. This is for rolling. I have filled copper tube with salt to bend fuel lines. I'm sure it works the same with tube. Just a pain in the ass. |
#5 |
I was thinking of bending..not rolling sorry. You are right on the pain in tha ass part.
#6 |
I like metal.
http://www.pirate4x4.com/forum/showthread.php?t=737981
Looks like I'm not the first person to think of this... ![]() Also the best thread about the HF unit. |
#7 |
Custom CNC Plasma
We have a system in development as we speak.
Because of the bent tubing on several of our production frame designs, it's become a necessity to have a power assisted tubing roller. Because we don't charge a premium on our frames, we can't afford a $5000 Bailegh tubing roller. Along with SWAG Offroad, We've developed a power-assisted design that utilizes the HF Tubing Roller along with SWAG's precision turned tubing dies. The unit is coupled with a DC bi-directional motor with an 80:1 transfer. It produces over 95 ft. lbs. Only 50+- ft. lbs. are required, but I found a great deal on Ebay for the hi torque geared motor. Here's a shot of the concept:
#8 |
I like metal.
It's neat, but the HF frame is still junk. Why not build a whole new frame? I think they would sell.
#9 | |
Custom CNC Plasma
Quote:
Besides... I'm not planning on selling it. I have more than enough stuff already sold that needs to get built fast! That's my ONLY reason for putting an electric motor on this thing. If anyone wants dimensions, I'd be happy to post them when I get done with the modification. I'll post a video of the roller in action as well... |
#10 |
I like metal.
Have you ad issues with your tubing curling when you roll it?
#11 |
Custom CNC Plasma
#12 |
Raider Rider/xs newbie
While not rolling have any of you had experience with this one from harbor freight
http://www.harborfreight.com/compact-bender-38470.html ![]() Or this one http://www.harborfreight.com/bench-t...der-38471.html
#13 |
I like metal.
That is a bender. Not a tube bender. Not a pipe bender. It's for doing flat iron scroll work or bending bar.
#14 |
Staff Member
I have the HF roller. It's been sitting on my workbench for a few months. I haven't used it yet though.
I only bought it because of the availability of dies from SWAG. I plan to do some playing around with it soon. I've read all the info on Pirate 4x4 and that's what led me to buying it. If I need to mod it with new side plates that won't be a problem to get them cut. I also have a DC motor with a 100:1 gear reduction from a wheelchair lift I might try to fit to it. |
- Travis
#15 |
XS650 Junkie
SWAG?
John |
#16 |
Really? That's what they used to bend the 7/8 .125 wall tubing for my build. Worked really well and didn't kink at all.
#17 |
Staff Member
- Travis
#18 |
4" radius I believe
Their dies were a bit different though more like the other one's posted above. Here's a pic. I'm talking about the seat rails. I had two sets made. The other set was bent even further.
#19 |
XS650 Junkie
Thanks, I'll check it out.
![]() John |
#20 |
I have that HF roller and have used it many times... only problem is the damn crap set screws are useless. Drill out the drive rod and put bolts all the way through and your fine.
Tube may twist in any roller when they slack up so you just have to keep your center line correct. I clamp a level to my tube when possible to keep it somewhat straight. vids here, more vids on my channel so feel free to dig around http://www.youtube.com/watch?v=5_lQBjDUj4Q |
www.chappellcustoms.com
Similar Threads (based on keywords)
| Thread | Thread Starter | Forum | Replies | Last Post |
| Harbor Freight lift table | section8joe | The Garage | 23 | 11-06-2012 10:05 AM |
| sandblasting engine/ harbor freight question | xscorex | The Garage | 10 | 11-06-2011 10:28 AM |
| Harbor freight 20% off all purchases till 10/31 | jedi_ | The Garage | 5 | 10-24-2011 07:04 PM |
| harbor freight electric tachometer ? | dimitri | The Garage | 1 | 04-06-2011 08:39 AM |
| Harbor Freight TIG welders | angus67 | The Garage | 39 | 09-18-2010 08:22 PM |
| Tags |
| tools |
| Bookmarks |
