XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. Itís free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 02-01-2012, 02:01 PM   #1
badrock
badrock's Avatar
Default Supermoto wheels
Hi everyone. It's my first post but I'm following the forum since more than a year
I'm working on a SE from 83 and I want to change the original alloy wheels.
Initially I was looking from different swingarms that would fit, but I would loose the round look so I decided to stick with the original.
Finding xs spoken wheels here where I leave is difficult, but cross/motard are easy to come by.
I've been looking around quite a lot, but could not find any info about fitting supermoto/cross wheels on the xs (cr250/ktm400).
I have found a couple of 18" supermoto rims+tyres from a ktm, that have the same axle size(17mm in the front and 20mm in the back).
My may concerns are about the rear wheel, mainly the sprocket alignment, size of the rotor and possibly the rim being too large?
What should I check when buying?
Anyone has experience with it?
badrock is offline   Reply With Quote
Old 02-01-2012, 04:30 PM   #2
XS771
XS771's Avatar
Default Re: Supermoto wheels
I have a supermoto with 17'' rims and thought it would nice to have 17's front and rear on my xs650 instead of the 19 and 16 . All it would take is some hubs and lace them to 17'' rims plus time and money....
XS771 is offline   Reply With Quote
Old 02-01-2012, 06:13 PM   #3
GreasyC
GreasyC's Avatar
If you don't use the stock hubs you'll need to make custom wheel spacers and possibly make changes/spacers to get the disk in the calliper and the sprocket in the right place.
If you do use the stock hubs you're looking at custom spokes and possibly custom rim drilling. Try Buchanans for that. If you go this route you have to decide what tire sizes you're going to run first so you know which rim to get.
GreasyC is offline   Reply With Quote
Old 02-02-2012, 06:26 AM   #4
badrock
badrock's Avatar
Thanks for the replies
It's very difficult to find xs hubs here where I leave, in general getting complete wheels is cheaper/easier.
I'm not afraid of having to build/find spacers for wheels and rotor. I would need a new caliper on the back (I have a drum now) and see if I can find a nice one for the front (the original rotor seams pretty small.. maybe 260mm? ).
Saturday I'm planing to remove swing arm and wheels, bring them with me and check if it's going to be a nightmare or not
here is a link to the add... let me know what you think.
http://motoren.marktplaats.nl/onderd...n-18-inch.html
My concerns are about the rear hub... it looks huuuge
For the rim it should not be a problem (people usually fit 18" on the back), and I would change the tyres anyway...
Old 02-02-2012, 06:44 AM   #5
gggGary
Old guy, NO expert.
gggGary's Avatar
Fitting a sprocket that will provide suitable gearing for the XS may be problematic on supermoto hubs. The large sprocket mounting bolt circle and small OD of a sprocket with gearing suitable for much more than XS pole climbing duties is the issue. Most supermoto wheels are 17s with low profile tires so that adds to the difficulties. I need to figure this out myself. I have set of KTM supermoto wheels and need to adapt them also. But that project is still a ways off.
"The goal of the forum is sharing our experiences and what we've learned,
not dismissing the ideas of others"
gggGary is online now   Reply With Quote
Old 02-02-2012, 09:39 AM   #6
badrock
badrock's Avatar
@gggGary: Thanks, you gave me something to think about!
The smallest sprocket I could mount on the ktm wheel is a 38 tooth.. This means that I'll be forced to mount a bigger front spocket (the 18t for the xs or create a curtom one).
http://www.dropbears.com/u/utilities/sprocket.htm
mmm.. doing some math:
- wit the original sizes the ratio is: 1.94~2.00
- 17t front and 40t back (stock): 2.35 (17% rpm increase )
- 18t front and 38t back: 2.11
so... the only feasible combinatio is 18/38, that would give me a a 5.5% increase in RPM (will run at 5275 RPM when it used to run at 5000 RPM stock)
Well... I want to build a cafe racer, with good handling for mountain roads... so, I could live with that, traiding top speed for accelleration
The question is more it it's worth it..
price of the wheels (300$)
custom spacers (50-100$)
sprockets (60$)
new calipers... (probably 50$)
...and more that is always there
mmm
Old 02-02-2012, 09:51 AM   #7
gggGary
Old guy, NO expert.
gggGary's Avatar
Keep in mind also that the clearance from the sprocket to the clutch push rod is small, I have seen more than one kinked push rod with marks where the chain hit it. My guess is a really loose chain skipped on the sprocket but....
A 520 chain might help maintain clearances.
Old 02-02-2012, 02:42 PM   #8
GreasyC
GreasyC's Avatar
If you keep the stock rear hub you can keep the stock sprockets, then you just need the right spokes and rim. Might be the more practical route. Keep in mind that supermoto/sport bike tires are usually at least 150mm wide in the rear so they won't fit in the stock xs swingarm. You really need to pick a tire set first and then see what needs to be done to make it fit your bike.
Old 02-02-2012, 02:51 PM   #9
gggGary
Old guy, NO expert.
gggGary's Avatar
Oh yeah, and an offset front sprocket so the chain clears the wide rear meat.
Old 02-03-2012, 07:56 AM   #10
badrock
badrock's Avatar
Yep, probably the best option would be to stick to the 17t front sprocket. With the 38t on the back it would be a 12% increase in rpm... still doable..
Yep, that would be the ideal solution... but hubs here are very expensive, double the price than the wheels I'm considering!
Do you guys know what's the best width for a rear 18" rim?
Is there another model that has a similar sized hub I could use? (sr500, cb450...)
Old 02-07-2012, 01:00 PM   #11
badrock
badrock's Avatar
I thought I would share the outcome
Incredibly light compared to the original, and fits very nicely what I have in mind for the bike.
The rims are 18x2.15", so no problems with clearance.
I'll need to offset the front sprocket a bit and machine some spacers.
I have a tokico 4 piston caliper and a 260mm front disk.
Will the 260mm rotor be enough, or if it better to upgrade to 300-320?
Old 02-07-2012, 01:44 PM   #12
gggGary
Old guy, NO expert.
gggGary's Avatar
Just by looks that front rotor needs to be bigger for the heft of a 650 with "cafe racer" desires.
Old 02-10-2012, 10:05 AM   #13
JET Improvements
JET Improvements's Avatar
Those rollers look sick! I have been eyeing a similar set on my local craigslist for one of my projects. How close is the clearance in the rear, tire to swing arm? Are you using the stock front tubes with a bracket for the caliper?
Life is a war of attrition...last man standing wins.
JET Improvements is offline   Reply With Quote
Old 02-12-2012, 05:52 AM   #14
badrock
badrock's Avatar
Thanks
The clearance on the back is very good, with 130/80/18 tyres and a 2.15" rim I still have more or less 1.5cm on each side (3/5").
For the front I'm planing to use the stock forks, tokico caliper from a gsxr with a 0.8 cm bracket and a 300-320mm rotor with 1 cm offset.
I was measuring yesterday... and it's gonna be really tight..
Old 02-12-2012, 04:16 PM   #15
Travis
Staff Member
Travis's Avatar
That looks really good! Do you know what KTM they are from? I'm might look for a set of those hubs.
- Travis
Travis is offline   Reply With Quote
Old 02-13-2012, 03:48 AM   #16
badrock
badrock's Avatar
Originally they were fitted on a KTM 400 SXC, and it looks like it was produced only in the 1999... very difficult to come by, as most of the motards have 17" rims.
For the hubs, most of the pre '01 models have the same axle (17mm front and 20mm back) so u should be able to find more models that fit, if you are just look for hubs.
The problem I'm having now it to find a front rotor from a different bike with the same bolting pattern, and with a cm offset. The thick spokes on this hubs leave no space for a 4 piston caliper , and I'm trying to avoid making a spacer between the rotor and the hub.
Do you guys know if there is an aftermarket disk producer where I can get this info (bolt pattern for different bikes)?
Is there any bike, that uses a 20mm rear axle and a 220-240mm rotor, from which I can take the back caliper?
Old 02-13-2012, 12:10 PM   #17
Travis
Staff Member
Travis's Avatar
Thanks for the info. I wish I could help you with your search for parts.
- Travis
Old 02-14-2012, 09:31 AM   #18
Hey Johnny Park
XS650 New Member
Hey Johnny Park's Avatar
These dirt bike rotors are very thin. I am sure they are designed to slow a motocross bike, not stop it. I'm looking into buying a XS to chop and build a hardtail bobber. I also have a set of KTM rims and hubs with the newer front axle that is 26mm in diameter. Mine are from an EXC model which are 21 inch from and 18 inch rear.
I also own a high-end euro Supermoto, Husaberg. It has a thick rear rotor, unlike the dirt bike rotors. It is roughly 5mm in thickness, brand is BRAKING, they should be able hook you up
Hey Johnny Park is offline   Reply With Quote
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
Where to get new wheels tigman175 The Garage 1 08-17-2011 01:18 PM
Trade - mag wheels for spoke wheels motorkiller31 Classifieds 10 07-10-2011 10:30 PM
For Sale - wheels!!! Bobber 12 Classifieds 2 05-19-2011 11:23 PM
Wanted - Wheels kopcicle Classifieds 2 05-15-2011 12:24 PM
Anyone swap mag wheels for spoked wheels jbgore The Garage 11 10-06-2010 01:40 PM
Tags
wheels
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
