XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. Itís free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
Notices
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 02-03-2012, 11:08 AM   #1
IMAN
IMAN's Avatar
Default 78 XS650 Coils
Hello fellow xs650 members,
This will be my first post and sure of many more as I just dove into a 78 XS650 about 1 month ago. I enjoy reading all of the info on this site related to the XS650, but like any new xs650 new owner I have problems and to stubborn to ask for help..lol...Sure the PO said everything was great and it ran!(BS) I have stalked the site about 3 weeks trying to learn and read all the info I can find on the bike(at least 15hr a week), but I'm a bit unsure about where to go next. Well let me give you a brief description of what I have done and what is going on.
1.) Got bike home and checked
Cleaned(changed) oil, slump,and tank(rust)
Fuses 20A(Great beep w/ M-Meter)
Replaced spark plugs(no spark to begin with and still no spark)
So my question is how to properly test a 78XS650 coil(s)PLACE mm ON WHAT SETTING and WHERE TO PLACE mm ON COIL OR POWER-SOURCE FROM bat), b/c that's the next step of checking for spark(correct)? From what I have read I place the MM..+ on R/W(from Bat) and MM..G on orange from battery no Volts( only volts I have are 12.9 at battery!)( If I place MM on coils where they are solder next to plastic or hard metal I get 4.2 on MM_)Thought I gained knowledge about it though a great search of info from goggle but from readings I find aren't enough for me!
That's all the info I can think of at this moment but if anything comes up I can explain, THE PROBLEM............!!!!!!!!!!!!l. THX IN ADVANCE FOR THE HELP!
Info I have is CLYMER- Service,Repair, Maintenance(book).....So not much b/c its does not go into detail!
IMAN is offline   Reply With Quote
Old 02-03-2012, 11:38 AM   #2
5twins
XS650 Guru
5twins's Avatar
Default Re: 78 XS650 Coils
Take a look at the factory shop manual which is online here .....
http://www.biker.net/
It contains coil testing info.
'78E Standard and 4 Euro twins
5twins is offline   Reply With Quote
Old 02-03-2012, 12:45 PM   #3
IMAN
IMAN's Avatar
Thank you for the quick reply!, but whats section does it seem to be under
1978 XS650SE Parts Manual?
Engine or Chassis can't see, to find it!
Old 02-03-2012, 12:57 PM   #4
5twins
XS650 Guru
5twins's Avatar
XS650 Service Manual 1978-1981, 650E Electrical.
Old 02-03-2012, 01:01 PM   #5
IMAN
IMAN's Avatar
If you can point me in the right direction of testing coils on a points system that would be great. Only thing I need to understand is where to look and hook for the leads and negative from what point to another from the M -meter
MM have red and black so do I hook red to red wire on the xs650 wire harness or the coil itself. and Black to orange?........would be alot easier to just call me.
Please just PM with yr number!
Old 02-03-2012, 01:16 PM   #6
retiredgentleman
XS650 Guru
retiredgentleman's Avatar
Do you have a Standard or a Special i.e. do you have 4 fuses or just 1 fuse?
78SE, Pamco Ignition with E-advancer and Accel #140403S Coil, dual bridge rectifiers, VR-115 regulator, LED tail/brake, BS38 carbs, OEM air boxes, OEM manifolds, OEM exhaust, Heiden Oil filter/cooler, 17/33 gearing, analog voltmeter, Brembo 4 piston calipers front and rear, "All Balls" roller steering bearings
retiredgentleman is offline   Reply With Quote
Old 02-03-2012, 02:11 PM   #7
IMAN
IMAN's Avatar
Retired,
It's going to be 4 fuses, special... All 4 checked out with MM and gave me a beep!
Old 02-03-2012, 03:26 PM   #8
IMAN
IMAN's Avatar
This is the MM I'm using and what setting would be used for the coil test
Old 02-03-2012, 03:39 PM   #9
jchrisk1
XS650 Junkie
jchrisk1's Avatar
I know that site can be a little hard to navigate at first, so here is the section to go to. Just click on 650E electrical and go to page 7.
http://www.biker.net/650_service/650service%20main.html
78 SE, BS38's, Pamco, Stock Charging System,
jchrisk1 is offline   Reply With Quote
Old 02-04-2012, 06:37 AM   #10
IMAN
IMAN's Avatar
OK I have found the answers I need I believe, but want to run it by before I test.
My coils have Brown and Orange so my R/W will be Brown correct?
Batery power is disconnected from main harness to coils?
To test prmary is MM+ to R/W(Brown) and MM-to Orange? Should read 3.9 ohms
To test secoundary is MM+ to plug wire end(cap removed) and MM- to orange? Should read 8K ohms
One last question before I test what should be the Voltage at end of the main wireing harness that connects to the coils coming from battery? 12V
Thanks in advance for all the info!
Old 02-04-2012, 10:32 AM   #11
5twins
XS650 Guru
5twins's Avatar
Yes, yes, and maybe. Test the voltage at the battery first. You should get very close to that at the coil power wires. You may see a couple tenths of a volt drop because of all the connections and switches between the battery and coils. If you get much less than that, say a volt or 2, then you need to clean all the connections and switches. Low power to the coils is a common problem on old bikes. It can really hurt performance or even make the bike not run at all.
Old 02-04-2012, 01:57 PM   #12
IMAN
IMAN's Avatar
Alright just tested coils for voltage so here are the results.
Primary(200 setting on MM)
Left coil is 3.8 ohms
Right coil is 3.8ohms
Secondary(20k setting on MM)
Left coil 8.3 ohms
Right coil 8.3 ohms
So coils should be fine?
Checked voltage going from battery, to coils and plug wires. With MM- grounded to battery and MM+ on R/W wire(s) from harness, bike turned on, and kill switch set to RUN I get the reading of 11.8 volts going to both coils and also to each plug wire(s). So with finding this information out I should be good on getting power to coils and plug wires? If anyone sees and mistakes I'm doing when testing voltage, please let me know b/c I'm new to working on electric! Heres the break down
Volts to coils 11.8
Volts to plug wires 11.8
Volts to plug caps 11.6
If everything checks out correct I should now look to the points to get spark correct?
Old 02-04-2012, 02:19 PM   #13
XSLeo
XS650 Guru
XSLeo's Avatar
How does the battery voltage compare to the red/white wire at the coils voltage?
As 5twins mentioned a large difference can effect if and how the bike runs.
With 11.8 at the coils and 13.5 at the battery is a bit much voltage drop. With 13.5 volts at the battery 13 volts at the coils is about right.
11.8 a 12.5 battery sounds ok.
Personally I don't like more than about .3 volts lost between the battery and coil.
Most of this loss is in the key switch or engine stop switch. Sometimes in the fuses or wiring connections. Most of these things can be opened up and cleaned, bright and shiny is a good thing. A small dab of dialectric grease will help keep connections well connected.
And yes, at this point the points will be suspect. They need clean contact surfaces and be properly gapped and timed.
Set the can chain tension first, then set the valves, then do the points. This order is neasry because the cam chain tension effects the cam timing as will as the points timing. Done in any other order gets mixed up setting.
It's all in the repair manual. Just set and gap the upper set first, then the lower.
The only way you can find out if you can do something is to try.
75 XS650B with a few mods, Dual disc brakes up front, Disc on rear, Pamcopete Ignition with the green coil, Radio Shack rectifier and Chrysler regulator, LED tail/brake and turnsignals. 750 kit,1.5 headepipes, Emgo shorty mufflers.
XSLeo is offline   Reply With Quote
Old 02-04-2012, 02:39 PM   #14
IMAN
IMAN's Avatar
Well Battery is around 12.6 and as you saw volts at coil is about 11.8.
O..boy the points, thing I have been trying not to miss with. Time to sit and read!
Old 02-04-2012, 02:45 PM   #15
XSLeo
XS650 Guru
XSLeo's Avatar
Those voltage numbers should get it running. The point aren't that bad, it just takes prctice to do them quickly. Just take your time and be clean. Any contaminents on the points will cause you greif. Get some spray electrical contact cleaner and som white paper, like business cards are made from. After you gap and time the points, spray the white card with the contact cleaner and pull the dampened carb through closed points, this cleans off any crud from the adjusting.
Old 02-04-2012, 02:48 PM   #16
retiredgentleman
XS650 Guru
Quote:
Originally Posted by IMAN View Post
Retired,
If your bike still has the original 4 position fuse panel, I highly recommend you replace it with automotive blade type fuses. The panel may look OK but the clips loose tension and resistance increases. Don't even try to test the fuse panel, just replace it and solder/ heat shrink the splices.
Old 02-05-2012, 06:45 AM   #17
IMAN
IMAN's Avatar
Thanks for the information on the points and fuses guys. I will be tackling this through out the week, so I'll keep you posted on the progress. Thanks again much help!
Old 02-07-2012, 07:26 AM   #18
IMAN
IMAN's Avatar
Well as I said I would keep you guys posted. The points were the problem as I suspected.
I took the information from here on how to go about and cleaning them with a bit of sand paper and lacquer thinner. Soon as I did that I have spark at the points and plugs. The spark at the points is a bit tanish, but the spark at the plugs is more of a white instead of a blue. I tried to crank it over to see if it would start, but no luck. I sprayed a dash of starter fluid in both carbs and got a loud pop, guessing the spark caught the fumes. I did not drain the float bowl of gas before I tried to crank her. So tell me if Im wrong, but draining the float bowl is next in the process to get clean gas in the carbs to see if she will crank. If no start then I should go with the timing of setting the can chain tension first, then set the valves, then do the points. Thx guys!
Old 02-07-2012, 06:02 PM   #19
XSLeo
XS650 Guru
XSLeo's Avatar
Doing A tune up involves doing things in order, this order is
Set cam chain tension
Set valve clearance
Set points gap
Set points timing
At this point you should have spark at the right time.
The color of arcing at the points is meaningless. Very noticable arcing can mean a bad condenser. If the condenser is good it keeps the arcing at the points to a minimum.
Good spark is a nice fat blue spark.
The voltage going to the coil should be very close to battery voltage. I like less than about .3 volts. As in 12.5 volts at the battery with no less than 12.2 at the coils.
The stock coils put out around 10,000 volts at 4000 rpms with 14.5 volts at the coil.
With 12.5 volts at the coil this drops to around 8000 volts. If the voltage at the points is much lower the coil output drops even farther, to less than 7000 volts. As I recall it takes about 6000 volts to fire the plugs.
So be sure you are getting battery voltage at the coils.
Old 02-08-2012, 10:09 AM   #20
IMAN
IMAN's Avatar
Thanks for the correct process of timing Leo! This morning I drain the old smelling gas from the float bowl, then turned on the petcocks to make sure I was getting fresh gas to the carbs(success) both carbs are getting fresh gas. Turned her over still just a loud pop, then a low pop-pop-pop. Friday I will be going over all connection cleaning them as well as the timing to make sure I'm getting spark at the correct time. PO said he road it last in DEC, but I know how you can take that will a grain of salt!
IMAN
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
gm coils on an xs650 crazyazsredneck The Garage 6 01-11-2012 11:12 AM
Issue with Coils specopsmedic The Garage 3 08-20-2011 12:33 AM
testing condensers and coils on a 79 xs650 sbtm The Garage 3 06-30-2011 12:55 PM
Can I use xs400 coils for my xs650? xs650biker The Garage 6 06-08-2011 10:28 PM
talk Coils with me PetesPonies The Garage 9 07-15-2010 06:13 PM
Tags
testing coils
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
