XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. Itís free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 02-20-2012, 03:42 PM   #1
alfredo
1978 xs650 Special
alfredo's Avatar
Lightbulb Ultrasonic Cleaner Build Thread
I am thinking about undertaking the creation of an ultrasonic cleaning machine. I have seen a lot of web articles (like this one) that suggest the use of a linear amplifier, some ultrasonic transducers, a computer sound card and some RCA cables.
I am posting here, because I just don't understand how this could work. I know how to solder and understand very primitive basics of electronics, but nothing near enough to assemble it from the instructions in that link. I am hoping the people of the forum could help out.
The Goal: I want to build a big tank with multiple transducers to clean anything from camshafts to car engine blocks. Possibly heated if I can find a cheap way to heat the tank (walmart griddles on the bottom?).
The Tank: I am going to build a fairly large stainless tank 5' x 4' x 3' which I think calculates to about 450 gallons (cubic feet multiplied by 0.00433). Seemed like a lot at first, but then I looked at my local water companies rates and if I am reading that right, it's less that $2.50 to fill it up. Which is less than what I would spend on a spray can of cleaner. It should be big enough to do bike and car blocks and everything in between and since I always dabbling in something, it would appear to be best to build it once and forget it.
Ultrasonic Transducers: I found this site that lists discs, rings, plates, blocks and cylinders, but I have no clue which is better for what. All I can gather is that I need to ensure they have a good kilohertz range (10khz to at least 60khz) as well as a high top end (150khz). I believe the Ohms need to be high (~10) as well or the amplifier will barf. As to how many to buy, which to buy, how to hook them up or how to attach them to the tank. There are all sorts of sizes and types, but the jargon is beyond my comprehension.
Some ones I found:
The Linear Amplifier: no clue here. What to buy? How many will be needed to run the transducers mentioned above? I read somewhere that only one amp will run one transducer . . ? Are these car amps or something entirely different?
Sound Card: these are cheap and I am pretty sure I will need to hook it to a computer for it to work. I (well, we all are) am fortunate to live in a time when cheap pcs are abundant. Should be able to find a crappy small computer to run this thing pretty cheaply. But still, here, no clue what to buy or how to hook it up or what sound to play to make this all work.
RCA Cables: self explanatory, but not sure how to hook them up.
So, with all that said, I am pretty much lost, but think that someone on here or many people will be able to chip in and we can come up with a solution. Any help would be appreciated.
crappy sketchup model of the tank
alfredo is offline   Reply With Quote
Old 02-20-2012, 03:47 PM   #2
xjwmx
XS650 Guru
xjwmx's Avatar
Default Re: Ultrasonic Cleaner Build Thread
Most of the audio amps and sound cards you find aren't going to have any output above about 20kHz. I considered maybe making a little ultrasonic cleaner once using parts from out of a little ultrasonic room humidifier. I think they're called 'cool mist' type humidifiers.
xjwmx is offline   Reply With Quote
Old 02-20-2012, 04:28 PM   #3
Tim H
Tim H's Avatar
I didn't read your links so I don't have any advice for your core project. But you can easily heat something with parts stolen from a hot plate, oven or whatever you find lying around.
If you want something a little better, a PID controller, SSR or contactor, some elements and a thermocoupler will make a very nice and accurate temperature controller.
This place has fairly cheap components:
http://www.auberins.com/index.php?ma...=index&cPath=1
Tim H is offline   Reply With Quote
Old 02-20-2012, 07:02 PM   #4
angus67
xxxxxxxxxxxxxxxxxxxxxxxxx
angus67's Avatar
At work we make paver screeds, the big ones used for paving new roads. the part that vibrates those is a 1' rod, with a weight off center in the middle it weighs like 10 pounds. Kind of reminds me of the vibrators in a xbox controller. The center weight is off ballance making it vibrate very strong. try one of those hooked upo to a electric motor like a bench grinder.
As far as the volume of the tank, if its anything other than water, dont you have to register some papers with the epa? I mean, 50 gallons of chem dip would be a huge problem if your tank seams split. (not questioning your welding....just sayin.)
soundss like a great idea.i loved the cleaned up head i got back from the machine shop. unfortunately it didnt match the rocker box, so i painted it.
1971 xs1b 3600 miles
1980 xs chop, bored to 680, kick only. ridgid. bs34's xsjohn's needles. 46pilot, 140 MJ.
1972 xl250 (pre elsinore)
2003 suzi marauder. Debaffled, stage 3 carbs.
angus67 is offline   Reply With Quote
Old 02-20-2012, 07:08 PM   #5
alfredo
1978 xs650 Special
alfredo's Avatar
I would probably only use a combination of water and pinesol. I am not sure I'd need to tell anyone about that, I hope . I hear amazing things about pinesol and ultrasonic cleaners.
I have read about the vibratory methods and I think the census is that only the true high frequency pulse will do best.
Old 02-20-2012, 07:12 PM   #6
hotrdd
XS650 Junkie
hotrdd's Avatar
I've done almost all of e same research and in the end just gave up because I couldn't source affordable, good parts for a reasonable price. It might be easier to find a used unit. But please keep us posted if you get something working.
I dreamt it, I wrenched it, I ride it
1976 XS650, Rebuilt engine, BS 38 Carbs, Open exhaust and intakes, Boyer Ignition, AGM Battery, Virago XV(front rim, forks, rotor and speedo), maxim 550 rear rim.
hotrdd is offline   Reply With Quote
Old 02-20-2012, 08:21 PM   #7
angus67
angus67's Avatar
tellin' ya bro, ....xbox vibrator. think about it . cheap, easy.
Old 02-20-2012, 09:05 PM   #8
avenue
push.
avenue's Avatar
looking to a hot water heating element for warmth. with the right threaded fitting, you can easily weld in a...quick thought.
how about using a hot water heater? cut off the top, work out the ultrasonic elements, and you're good to go. the water heater even has a drain plug for cleaning.
if nothing else, plug the cleaner up to the hot water outlet of the heater and recycle the water back through. continuous water flow, fresh heat. all you need is the ultrasonic pulse.
just sayin. keep us updated.
'83 277pamco. kick-only. PMA. sparx capacitor. green coils. uni pods. open pandemonium ya-mama pipes. bs34s 45/135. short wheelbase hardtail.
avenue is offline   Reply With Quote
Old 02-20-2012, 09:10 PM   #9
avenue
push.
avenue's Avatar
just remember not to run the heating element without water. it'll burn out almost instantly without being submerged. good thing, though, is the elements are cheap and readily available at the hardware store.
Old 02-20-2012, 09:36 PM   #10
angus67
angus67's Avatar
the inside of a standard water heater is only about 1 and a half feet. they are double walled(usually).
cant fit a engine block in that. I'm not even sure you could fit the top of a xs case with the long head bolts attached..
but that is an great idea. water heater elements.....put that on the list.
but the recycling of new heat would be greta. some sort of pump to circulate.
Old 02-20-2012, 09:49 PM   #11
osteoderm
out of the box
osteoderm's Avatar
I've toyed with this idea myself. I hate to sound discouraging, but coming from an industrial electronics background, I have to warn you that these devices don't scale easily. With any size, the power requirements for effective use climb dramatically. Commercial ultrasonic tanks push ~50 watts/gallon. A 25kHz transducer is a starting point, but 40-60kHz is closer to the standard.
Yes, I see how a PC sound card and software frequency generator could be used for a source signal, and how a linear amp could be used for power generation. If you're experimenting, I suggest trying a 120Vac PA amp. Working along these lines, I can see getting a working small tank together, maybe a couple gallons. When I looked at it for myself, I soon saw that the time and money to build such a thing was almost more than just buying one.
An effective 450-gallon tank might require upwards of 20,000 watts of power... imagine going to a concert with a 20,000 watt stack of amps and speakers... yeah, that kind of power...
Larger ones are out there, but I've never personally encountered an ultrasonic tank over 50 gallons, and that one was a serious piece of equipment, 240Vac/30A, 60kHz, and I didn't ask the price...
1974 TX650, intermediate suspension mods, minor brake mods, partial streamlining, working lights and horn...
osteoderm is online now   Reply With Quote
Old 02-20-2012, 10:18 PM   #12
angus67
angus67's Avatar
way to be a debbie-downer, osteoderm
Old 02-20-2012, 11:01 PM   #13
osteoderm
out of the box
osteoderm's Avatar
Please don't get me wrong... I think DIY is ultimate-awesomeness and I'd hate to discourage anyone, but I also hate to see good money thrown after bad...
I've seen a bunch of car batteries strung together for a quick'n'dirty trailside tack-weld. It got us home, but it's no replacement for a welding machine.
Old 02-21-2012, 01:48 AM   #14
Travis
Staff Member
Travis's Avatar
I don't think you need a 5'x4'x3' tank for any engine block you'll want to clean. About 34" x 24" x 24" would be plenty big even for a big V8! That's still an 85 gallon tank. I'd carefully research the size of the largest engine block you'd possibly want to clean and base your tank size off of that. You might be able to get it down to 50-60 gallons and make this project reasonable. Even at 60 gallons and 50 watts a gallon, that's 3,000 watts so you'd need to run it on a 220 circuit.
Check this out .. A 90 gallon industrial unit. 4000 watts and 375 lbs without liquid! http://upcorp.thomasnet.com/item/ult...ng-systems/90?
angus67, no offense, but vibrating water using vibrator motors (offset weights) is nothing like ultrasonic cleaning.
- Travis
Travis is offline   Reply With Quote
Old 02-21-2012, 08:26 AM   #15
lukach4
lukach4's Avatar
Quote:
You dont really need a heating element...I use ultrasonic cleaners every day and as long as you start with warm/hot water the ultrasonic waves in the water naturally heat up... just saying.. one less thing to worry about..
lukach4 is offline   Reply With Quote
Old 02-21-2012, 08:41 AM   #16
alfredo
1978 xs650 Special
alfredo's Avatar
Quote:
The only worry there would be that I would want to reuse the solution more than once, so draining it and refilling with hot water might be a little much.
Yeah. I rolled this by my father and he gave me the crazy eyes . A smaller form factor will certainly do just as well. Going to redo my original plan and scale it down.
Old 02-21-2012, 09:24 AM   #17
arod_1
XS650 Fan
arod_1's Avatar
This is a link to a company that manufactures Ultrasonics. We use them at the company I work for. They do sell amplifiers and transducers separately, but definitely not the DIY prices. But will give you an idea of what it would take to make something like that work. Maybe some ideas.
http://www.emersonindustrial.com/en-...s/default.aspx
'83 Heritage Special
Stock carbs, jets, pipes, air boxes, TCI ignition box
Accel Coil
arod_1 is offline   Reply With Quote
Old 02-21-2012, 07:52 PM   #18
angus67
angus67's Avatar
aw. ...gee, travis, your breakin my heart. is ok.
Old 02-21-2012, 09:21 PM   #19
alfredo
1978 xs650 Special
alfredo's Avatar
Thanks man! I am beginning to think that the general census is that generating the required power is going to be the biggest cost of this.
Old 03-16-2012, 04:27 PM   #20
alfredo
1978 xs650 Special
alfredo's Avatar
Have done as much research as possible and it basically doesn't make sense for one reason: The linear amplifiers needed for something even close to this scale are co$tly. So much so it is prohibitive for me to move forward on this.
Thanks for all for pitching in the time to help shape this idea, even if it ended up being a popped balloon.
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
StCin's hardtail build thread. first bike, first build. stcin7 The Garage 72 07-06-2012 08:07 AM
Carb care, post-Ultrasonic cleaning? Ironriot The Garage 3 06-01-2012 09:13 AM
My 81 XS650 Build Thread gemiller The Garage 2 05-17-2012 03:43 PM
My build thread motorbreath The Garage 18 04-24-2011 10:59 PM
My Bobber Build thread!! Lee Harvey Griswold The Garage 10 06-17-2010 10:41 PM
Tags
cleaning solvents, technical
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
