XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. It’s free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
Notices
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 04-09-2012, 04:07 PM   #1
yamasarus
yamasarus's Avatar
Default Restoration of an XS1
I looked for an XS1 to restore for about 5 years. I finally found one that I could afford in Florida (I live in NC). It had a 75 front end, wheels, and tank, but the numbers matched and were correct for an XS1. It was also a later production number so I avoided the needle bearing on the piston pin. I started finding the parts I would need and spent about a year doing that.
Many parts I already had , like the NOS instruments. The first step after disassembly was to send the fenders, rims, rear fender bracket, handlebar and bracket, and chain-guard to the chrome plater. All body parts were stripped and readied for paint. The frame was blasted, etch primed and painted with single stage black. All other paint is House of Kolor Kandy or white with plenty of clear. I have never cared much for the original green so I went two coats darker on the Kandy to get what you see here. Every component was freshened up or replaced. Most of the nuts and bolts were replaced with polished stainless. The engine was also disassembled and freshened up as necessary. Upgrades like tapered neck bearings and fresh swing arm bushings were also done. A reproduction exhaust system from Mikes XS was used. The correct taillight, correct K70s, chrome spokes, oring chain, and lots of polishing aluminum were also added. It's as close to a "new" XS1 as I could make it. All work, to include paint, polish, tin-zinc plating, and lacing was done by me. The only thing I send out is chrome work. I really enjoyed this restoration as an XS1 was my first "big bike"back in the day. I am retired and the whole job took 8 weeks. Fun stuff!
XS1 BUILD-1 1.jpg   XS1 Finished 003 1.jpg   XS1 Finished 004 1.jpg   XS1 Finished 006 1.jpg
yamasarus is offline   Reply With Quote
Old 04-09-2012, 04:26 PM   #2
Travis
Staff Member
Travis's Avatar
Default Re: Restoration of an XS1
Excellent Work! It's nice to read more about the bike and see the before and after pictures!
- Travis
Travis is online now   Reply With Quote
Old 04-09-2012, 04:49 PM   #3
Royboy
many roads, little time
Royboy's Avatar
Absolutely beautiful! Top drawer workmanship, hell I'd like to own it but now that you've gone and done all that I can't afford it. Go have a beer on me!
roy
Whether you think you can or think you can't, you're right.
Royboy is online now   Reply With Quote
Old 04-09-2012, 05:17 PM   #4
stacks99
stacks99's Avatar
Looks awesome! Nice work Yamasarus
stacks99 is offline   Reply With Quote
Old 04-09-2012, 05:43 PM   #5
Shiffty
Jim Wilson
Shiffty's Avatar
Very Nice Job.
Shiffty is offline   Reply With Quote
Old 04-09-2012, 05:48 PM   #6
CDNTX650
XS650 Guru
CDNTX650's Avatar
sweet!!! i thought all 256 motors had the needle bearings on the small end of con rods.?
2010 Kawasaki Versys
1974 TX650A resto modded and done.
1978 KZ650 b1. Darn near stock, no restore.
CDNTX650 is offline   Reply With Quote
Old 04-09-2012, 08:01 PM   #7
hooktool
XS650 Junkie
hooktool's Avatar
Nicely done, a real beauty. I see another in the background in one of the pics. Where do you live?
Did you use the Caswell products for the zinc plating? I bought one, but have yet to use it.
John
hooktool is offline   Reply With Quote
Old 04-09-2012, 08:26 PM   #8
yamasarus
yamasarus's Avatar
Thank you all for the kind words. It means alot coming from fellow XS fanatics!
CDNTX650: The needle bearing was used up to #3269. From that point on the rod was redesigned to eliminate it. The 256 style engine was used through 1973.
hooktool: I live in Kannapolis, NC. I have several 650s, though I am thinning the herd. I used the Eastwood kit but I am about to purchase the Caswell. I think it might give a more durable finish. I haven't had any problems with the Eastwood kit but study the two processes and I think most would agree that Caswell is better....not as fast, but better with more options.
Old 04-09-2012, 08:50 PM   #9
retiredgentleman
XS650 Guru
retiredgentleman's Avatar
Super job...................great looking bike!
78SE, Pamco Ignition with E-advancer and Accel #140403S Coil, dual bridge rectifiers, VR-115 regulator, LED tail/brake, BS38 carbs, OEM air boxes, OEM manifolds, OEM exhaust, Heiden Oil filter/cooler, 17/33 gearing, analog voltmeter, Brembo 4 piston calipers front and rear, "All Balls" roller steering bearings
retiredgentleman is offline   Reply With Quote
Old 04-10-2012, 05:46 AM   #10
pregrid
XS650 Guru
pregrid's Avatar
8 weeks!? Didi you sleep? Beautiful job!!
Dave......
'79 street tracker
pregrid is offline   Reply With Quote
Old 04-10-2012, 08:39 AM   #11
therealjamesdean
therealjamesdean's Avatar
That's a beautiful job. It's nice to see a restoration. Thanks!
therealjamesdean is offline   Reply With Quote
Old 04-10-2012, 08:45 AM   #12
gggGary
Old guy, NO expert.
gggGary's Avatar
Thanks for posting up a bit of history on this handsome XSOTM winner!
It was certainly well disguised when you found it.
type, post, read, edit, type, save, oops, repeat.
gggGary is online now   Reply With Quote
Old 04-10-2012, 09:36 AM   #13
cra-z1
cra-z1's Avatar
Very nice work. Nice to see another saved
cra-z1 is offline   Reply With Quote
Old 04-10-2012, 10:00 AM   #14
solosailor
solosailor's Avatar
I have my 1975 down to bare frame and was planing o a strip and cafe rebuild, but my bike was orig when I got it so I have everythige. Seeing your beautiful restoration has changed my direction. Question: where did you have the re-chrome?
solosailor is offline   Reply With Quote
Old 04-10-2012, 10:18 AM   #15
drog
drog's Avatar
Very nice job indeed! I really like the shade of green that you came up with.I also have an XS1 that i might restore one day,still need a few bits and pieces for it though.It also is a number matching engine/frame.Did you tin/zinc the taillight bracket? Was yours originally chrome? I will have to dig mine out and see what i need,might have to pick your brain for pointers,haha! Thanks for posting the pics and story,made my day!
drog is offline   Reply With Quote
Old 04-10-2012, 11:12 AM   #16
gggGary
Old guy, NO expert.
gggGary's Avatar
XS1 taillight brackets were painted silver, XS1B were chrome with a round taillight.
Old 04-10-2012, 01:53 PM   #17
yamasarus
yamasarus's Avatar
Quote:
My plating was done by: Concord Plating, Concord, NC
704-784-4660
ConcordPlating@gmail.com
The owner is Joel Lopez and they do ship.
The 75 is my favorite and I ride mine all the time. Stock is most comfortable!
Old 04-10-2012, 01:54 PM   #18
yamasarus
yamasarus's Avatar
Quote:
I'll be glad to help any way I can. 70s are always worth restoring!
Old 04-15-2012, 07:24 AM   #19
Cpkid
Cpkid's Avatar
Great job! I'm restoring 2 70s now. I had one painted , and I hope to get the paint back soon. Where did you get the forks ? There hard to find. I'm missing a rear fender hoop , but I'll use a 71 . I can't wait to get on the road. Your color looks great as well . Best of luck. I'll be there soon I hope.
Regards,
CPKID http://
Cpkid is offline   Reply With Quote
Old 04-15-2012, 08:24 AM   #20
Dennis
Dennis's Avatar
Now thats a piece of art
Great job
stock 83 650 Heritage Special
Dennis is offline   Reply With Quote
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
Wanted - Battery Box XS1 Xs1B. Stock air filter boxes xs1 xs1b Cpkid Classifieds 4 10-04-2011 05:41 PM
Paint restoration QTreiber The Garage 6 07-04-2011 11:34 PM
'79 xs restoration bcxs650 The Garage 4 09-23-2010 10:00 PM
Tank Restoration Rabbid The Garage 6 07-22-2010 09:48 PM
Considering restoration skyhawk04kilo The Garage 12 06-01-2010 02:59 PM
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
