deadchef
xsbobblehead
i can't seem to figure this out. starts and idles fine. i feel like it's a lean condition but i've tried larger mains with no change. i've cleaned carbs, tank, rebuilt petcock, new plugs, set cam tension, valves, set floats, new float needles, new carb boots and gaskets. i've checked the battery and voltage is good at idle and goes up with throttle.
i'm just at a wall at this point and i'm not sure what else to check.
thanks
