Well I am stuck already on my engine rebuild on the very first reassembly item .
I knew that I would have to resolve this issue before I could start which has been putting me off starting. To tell you the truth its the reason the previous owner gave up and sold the bike to me.
Its the crankcase bush and needle bearing race for the selector fork shaft that is the problem.
For some reason the PO tried to remove the bush with a puller because the needle race had broken up. he thought it needed pulling until I showed him it is just a straightforward press in /out job. He was gutted.
My question is this .
Should the new bearing be pressed in so that the front lip of the bearing is flush with the inside face of the case ?
This one is sitting proud by 1.2mm which could be the result of the po trying to pull it out before I got the bike.
Could anyone with an open case check for me please .
I could just press the new one in to the same position but it may end up with too much or too little play for the selector shaft.
