XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. Itís free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
Notices
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 11-09-2012, 06:21 PM   #1
Jaydela180
Jaydela180's Avatar
Default stainless steel bolt kit
is anyone familiar with this bolt kit?
http://alloyboltz.com/catalog/produc...cfs5g0qdp6gbu3
1980 xs650 bored to 700cc, JE 77.5 pistons, elephant foot rocker mod, tc bros hardtail, bs34 with Canadian needles (m 140 p 45), uni pk-92, tci ignition with high output coil, clutch spring mod, open exhuast, stock charge, shinko 712, top end rebuild winter 2012 @ 28,000 miles
1979 stock xs650.
Jaydela180 is offline   Reply With Quote
Old 11-10-2012, 10:21 AM   #2
Jezuz
Jezuz's Avatar
Default Re: stainless steel bolt kit
Aluminium + stainless = white powder = no threads any more. (in few years)
Jezuz is offline   Reply With Quote
Old 11-10-2012, 01:22 PM   #3
Jaydela180
Jaydela180's Avatar
Thanks for the heads up. I did not know about the reactivity of stainless and aluminum. Oddly, this was not mentioned in any other stainless bolt thread.
1979 stock xs650.
Old 11-10-2012, 01:56 PM   #4
Cafe-Dave
XS650B
Cafe-Dave's Avatar
First off, I hope all this helps.
http://en.wikipedia.org/wiki/Galvanic_series
Let's first assume we are using passivated, 316 Stainless steel
Aluminum will corrode when placed in contact with Stainless steel + an electrolyte. Stainless is much more noble than aluminum.
Notice how much closer Zinc plating is to Aluminum, and in fact zinc plating is less noble (zinc will corrode) which will protect the aluminum.
You can give some protection to a stainless bolt / aluminum mechanical joint by means of sealing the threads from one another. Anaerobic thread sealants are popular.
http://www.henkelna.com/adhesives/an...ning-14883.htm
Use a threadlocker in an engine case with aluminum threads, and you have asked for quite a bit of trouble that I doubt you'll want.
Use a thread sealant http://www.henkelna.com/industrial/t...bics-14405.htm
Thread Sealants
Loctite Thread Sealants are anaerobic adhesives that instantly provide a durable seal between close fitting threads to prevent the costly leakage of gas and liquids. Thread sealing is achieved as the anaerobic compound cures when confined in the absence of air, and between close metal fitting surfaces. When used to lock threaded assemblies together, anaerobic adhesives prevent loosening and corrosion of the fastener, maintain proper clamping force, and offer controlled torque for removal of the assembly.
Bonus round. Stainless steel is rather noble, doesn't like to react. Anaerobic thread sealants require what?
Absence of air, presence of metal for thread sealants (also thread lockers). There may be metal there, but it's aluminum (trace amounts of corrosion-able copper alloy elements, maybe) and stainless steel (does not play well).
We need a primer, something to start off the chemical reaction in a thread assembly.
Primers for Anaerobic Products
These anaerobic primer products range from solvent-based surface activators to acetone and isopropanol based primers that offer a wide reaching range of applications. Many of Henkelís Loctite primers help speed the cure of our anaerobic adhesives and sealants.
http://www.henkelna.com/industrial/p...et=00000002A1#
My favorite is Loctite 7649 Primer N
http://www.henkelna.com/industrial/p...=8797888086017
Primer T works good, but doesn't have Primer N's 30 day part life
http://www.henkelna.com/industrial/p...=8797888413697
Me? I use good zinc plated or black oxide hardware with loctite wicking grade thread lockers. Correct torque values, great retention and easy breakaway torques. Stainless steel can be wicked to deal with.
http://www.henkelna.com/industrial/g...king-13227.htm
TL,DR : And that's how I single-handed saved christmas. Go read everything, don't be lazy.
Cafe-Dave is offline   Reply With Quote
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
For Sale - MotoLanna --- Chain Guard --- stainless steel DanW Classifieds 1 09-30-2012 07:43 AM
Fuse Stainless bolt to aluminum rod? hotrdd The Garage 9 09-19-2012 04:54 PM
Stainless steel engine bolt kit on Ebay. Worth buying? Ironriot The Garage 9 02-20-2011 09:29 PM
Intro and Chrome vs Stainless Bolt Question jims428 The Garage 7 02-07-2011 07:42 AM
For Sale - throttle cables Stainless .Steel . $10.00 each, dr mac Classifieds 8 01-13-2011 03:40 PM
Tags
engine bolts
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
