XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. Itís free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 01-16-2013, 11:46 AM   #1
franklinshaw
What just happened??
franklinshaw's Avatar
Default rectifier and condenser
Does anybody have a picture of a rectifier and a condenser for a 1976 xs650. I have a pile of parts and not sure which is which. I've tried to research it but I get pics of several different kinds of each.. Thank in advance fellas!
franklinshaw is offline   Reply With Quote
Old 01-16-2013, 11:54 AM   #2
Grinder
XS650 Guru
Grinder's Avatar
Default Re: rectifier and condenser
Look at post 6 here for condenser pic.
http://www.xs650.com/forum/showthrea...denser+picture
Post 2 here for the rectifier
http://www.xs650.com/forum/showthrea...=rectifier+pic
Grinder is offline   Reply With Quote
Old 01-16-2013, 01:05 PM   #3
franklinshaw
Thank you soo much!
Old 01-16-2013, 01:17 PM   #4
franklinshaw
So is the regulator and rectifier the same part? What exactly is this I have here?
Old 01-16-2013, 01:39 PM   #5
Royboy
many roads, little time
Royboy's Avatar
Location: North Central MN / Gold Canyon AZ (seasonal tramp)
No, two totally seperate and different items on an XS650. The regulator lives behind your left side cover and "regulates" the amount of current flowing to your battery. The rectifier lives below the battery box and converts AC current from the alternator to DC. Your photo is the flasher relay which lives by the coils under the fuel tank.
Maybe you should consider acquiring a manual.
roy
Whether you think you can or think you can't, you're right. (Henry Ford)
78'SE, 77'D, 78'SR500, 98' Honda Magna
Royboy is offline   Reply With Quote
Old 01-16-2013, 02:05 PM   #6
franklinshaw
ugh! I hate reading tho.... ha!
Old 01-16-2013, 05:07 PM   #7
5twins
XS650 Guru
5twins's Avatar
Actually, I think that pic is your combo headlight and starter safety relay. It mounts on the right side of the battery box and keeps the starter from running once the motor starts. On later models it also turns the headlight on once the motor starts. On a '76, that won't happen. It may just be a starter relay on yours.
'78E Standard and 4 Euro twins
5twins is offline   Reply With Quote
Old 01-16-2013, 05:43 PM   #8
Grinder
XS650 Guru
Grinder's Avatar
Yup, safety relay.
Old 01-16-2013, 05:44 PM   #9
franklinshaw
Well im deleting the starter so i won't need this?
Old 01-16-2013, 05:48 PM   #10
Grinder
XS650 Guru
Grinder's Avatar
No, but cap off the yellow wire. It comes from the stator on the stock charging systems.
Old 01-16-2013, 06:06 PM   #11
Royboy
Royboy's Avatar
Opps.
roy
Old 01-16-2013, 11:17 PM   #12
franklinshaw
Got it! ......
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
Condenser question Jasonbobb The Garage 2 07-15-2012 12:46 AM
cant figure out if rectifier i have is only a rectifier or a regulator as well aftershock The Garage 3 01-15-2012 09:10 PM
Points, Condenser STVR The Garage 1 09-30-2011 01:41 PM
Condenser problems Prospect The Garage 11 05-22-2011 04:15 PM
Mounting coils and condenser rwingsfan The Garage 2 11-18-2010 01:56 AM
Tags
bobber, chopper, electrical
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
