XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. Itís free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
Notices
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 12-20-2009, 03:15 PM   #1
kman40
XS650 New Member
kman40's Avatar
Default oil coming out exhaust pipe
okay ,just bought bike. it starts runs on one cylinder then the other cylinder kicks in only to backfire and puke out large amount of oil.Is there oil passages that could be plugged in the top end?
kman40 is offline   Reply With Quote
Old 12-20-2009, 04:35 PM   #2
Travis
Staff Member
Travis's Avatar
Default Re: oil coming out exhaust pipe
Time for a rebuild!
- Travis
Travis is offline   Reply With Quote
Old 12-21-2009, 12:34 PM   #3
Travis
Staff Member
Travis's Avatar
Thought I would elaborate on this a little more… If you're sure it's oil coming out of the exhaust and not just condensation and carbon, you either have a hole in that piston, bad rings, or bad exhaust valve seal/guide. All require pulling the motor and taking it apart.
Have you checked the compression on that cylinder? Not that it's going to matter since you're going to have pull the motor anyway, but just curious. If you don't have the money, time, or knowledge to fix that motor, you could probably get a good used one for about $100 US that should get you going again in no time. It would probably be cheaper and easier anyway. Let us know what you figure out.
- Travis
Old 12-21-2009, 05:33 PM   #4
xs650rider
XS650 New Member
xs650rider's Avatar
mate i had the same problem my xs had a hole in the piston check out my photos best thing to do is pull it appart iv got a spare piston if thats what it is
xs650rider is offline   Reply With Quote
Old 12-30-2009, 06:51 PM   #5
kman40
XS650 New Member
kman40's Avatar
Okay I pulled the engine out of the frame.Took the top end apart and found that 1 piston and rings first over .25.The other piston the one that throws oil everywhere is standard piston with .25 over rings.Would this cause that much oil to come out the exhaust?Thanks for all the information..
Old 12-30-2009, 11:45 PM   #6
inxs
XSively Addicted
inxs's Avatar
- check your piston to cylinder clearance...if its 0.10mm or more its too much
- decoke the piston including the ring grooves and make sure the oil relief holes arent blocked
- check the piston for damage...pitting, cracking, scoring or broken sections in the crown, ring lands and skirt
- if you have your cylinder off, after cleaning the piston and rings put the rings back on the piston, invert it and slide back into the bore...stand over a white surface or light box...you will see if there is a gap anywhere
- the oil expander rings also have a tendency to compress...you can retension them if youve got 3 hands...this wont work if you have too much piston to bore clearance
-need a 75mm pipe or old piston...oil the outside surface
-slide the expander ring over the outside surface
-hold one end to the surface
-hold the middle against the surface-no gaps
-pull the other end towards the fixed end..ie. stretch it slightly...you only need a few tenths of a mm...when you refit the piston into the cylinder they will come to a natural balance
fear is temporary, regret is forever
inxs is offline   Reply With Quote
Old 04-20-2013, 02:54 PM   #7
supercooper04
supercooper04's Avatar
On mine. The bike had stood for ages. After running it up. The exhaust is really oily and you do get a good drip from the exhaust. The engine doesn't seem like its loosing a cylinder. But when its hot it has a valve tap. Adjusted the valves as per spec. but it is worrying.
supercooper04 is offline   Reply With Quote
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
Exaust H Pipe bkmarsha The Garage 3 02-02-2010 12:51 PM
maxi-x-pipe arrived today ryan79 The Garage 10 01-26-2010 06:23 PM
Tags
engine
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
