XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. Itís free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 04-07-2013, 08:08 PM   #1
pahako
pahako's Avatar
Default valve adjustment
Is there another way to determine tdc besides lining up the mark on the rotor? The reason I ask is because the rotor on this 80 special I am working on is new and there doesn't seem to be a clear mark. I adjusted the valves using what I believed to be the mark, but it is difficult to see, and is a very small, but seems to be a clear endent on the edge of the rotor. The reason I am not completely sure about the mark is because there seems to be slightly more noise from the valves, like the gap is off, when the engine is running. Thanks
pahako is offline   Reply With Quote
Old 04-07-2013, 09:38 PM   #2
CDNTX650
XS650 Guru
CDNTX650's Avatar
Default Re: valve adjustment
Pull a plug and look. Youll be able to see when its there. That will be close.enough for doing the valves
2010 Kawasaki Versys
1974 TX650A resto modded and never done....new...everything..cases up.
1974 engine...Rebuilt. ...waiting patiently on the stand.
2014 triumph scrambler.
1971 plymouth valiant....she's minty!
CDNTX650 is offline   Reply With Quote
Old 04-08-2013, 05:55 AM   #3
Brian902
XS650 Junkie
Brian902's Avatar
Common practice is to:
1 - Remove spark plug
2 - Rotate engine counter clockwise as viewed from the left side
3 - Watch for intake valve to open and close
4 - With long screwdriver in the spark plug hole feel for when the piston next reaches it's highest point
5 - Check both intake and exhaust valves, both should be loose, if not go to step 2
6 - You are now close enough to TDC on the compression stroke to allow adjustment of the valves
7 - Adjust valves
8 - Go to step 1 and repeat for right cylinder
9 - Replace plugs, start bike and adjust cam chain
10 - Your done!!!
Brian (1978 XS650SE / 270 / Web Cam / Probe Ignition / CVK's)
Brian902 is offline   Reply With Quote
Old 04-08-2013, 06:18 AM   #4
gggGary
Old guy, NO expert.
gggGary's Avatar
+1, if the rocker arm is on the base circle part of the cam profile, it is close enough for valve clearance setting. Basically the valves on the other cylinder will be in the overlap/open area. The engine will tend to want to turn to and sit in the "valley" between the valve ramps on the other side that's plenty good for valve setting.
"The goal of the forum is sharing our experiences and what we've learned,
not dismissing the ideas of others"
gggGary is online now   Reply With Quote
Old 04-08-2013, 07:27 AM   #5
grepper
fiddle futzer
grepper's Avatar
If you really want to get accurate, Hugh's Handbuilt had a really nice Blog post on this.
tdc and how to find it
XS650SG-stock (sold), XS650SF-bob, XS650E-stock, 75 CB750 K5, 79 CB750 K. 81 CB750 K, 2001 Honda Valkyrie Interstate, 2004 Wahoo Scooter
grepper is offline   Reply With Quote
Old 04-08-2013, 07:02 PM   #6
pahako
pahako's Avatar
Thanks everyone for your input. I should be able to handle it from here.
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
Valve adjustment confusion.... JP50515 The Garage 9 06-14-2013 08:32 AM
Valve adjustment 1980 xs650special The Garage 22 03-07-2013 08:01 AM
Not enough Exhaust valve adjustment scharny61 The Garage 5 08-07-2012 11:12 PM
Valve Adjustment Tool mgjaynes The Garage 15 05-21-2012 06:04 PM
Oil after valve adjustment harmonc The Garage 13 09-08-2010 11:43 AM
Tags
engine
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
