XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. Itís free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 04-09-2013, 04:21 PM   #1
pristic
pristic's Avatar
Default Hidden wiring tips and tricks?
Hi,
Holy hell! How do you run wiring through Keystone 7/8 bars!
Anyone done it? Just patience and wiggling or what. I want to (have to here) run a blinker switch but hate hate hate wires. In fact I even hate the throttle, clutch and speedo cables. Brake lines too hahaaha. One day ill come up with some invention to have a bike with NO visible wires/cables.
But until then... How the heck did you do it?
It's a small hole on left hand for wires to go in.
Small hole near centre of the bars to come out and down to electrics tube. Getting past the "corner" in the keystones is a nightmare.
Any tips on getting your wires through?
Same really applies for the rest of the frame (eg hardtail) which is next to get hidden.
Originally said I won't hide it but this bike only has like 4 wires on it now :-) ok a few more but VERY minimal.
Posted via Mobile
pristic is offline   Reply With Quote
Old 04-09-2013, 05:57 PM   #2
Curtis P
Curtis P's Avatar
Default Re: Hidden wiring tips and tricks?
Just keep pullin yer wire
1972 XS650 chopper
Raked, stretched, hard tailed
8 inch over girder, yea its horny
Curtis P is offline   Reply With Quote
Old 04-09-2013, 08:54 PM   #3
angus67
xxxxxxxxxxxxxxxxxxxxxxxxx
angus67's Avatar
are you just trying to shove the wires thru>?
If I were to try this, I would take cotton string, and use compressed air to blow the string thru, then tie the string to your wires, and pull back thru. maybe try a lubricant? wd-40?
Another thing u can try is buy three conductor cord at the hard ware store that is used for power tools. Puts 3 wires together in a nice compact cable.
I did my whole bike with this stuff. Good size wire, and rated for at least 110 volts , so, Im pretty sure 12v will be fine.
1971 xs1b 3600 miles
1980 xs chop, bored to 680, kick only. ridgid. bs34's xsjohn's needles. 46pilot, 140 MJ.
1972 xl250 (pre elsinore)
2003 suzi marauder. Debaffled, stage 3 carbs.
angus67 is offline   Reply With Quote
Old 04-09-2013, 09:09 PM   #4
pristic
pristic's Avatar
Thanks guys. I'm liking the compressed air idea! Cables are nice and flexible. What happens is in keystones they curve up then have a corner 110deg maybe then down and another 90deg corner. It's the first sharp corner that I can't get around. The wire goes in fine the everytime finds that really sharp corner and rolls up into it.
A draw wire (string or good fishing line) and me trusty massive petrol compressor should work. Didn't even think of that so thanks!!
Yes it's only wire. No cables like clutch etc. I just want a tiny blinker switch is all. Really small on/off/on switch but the wire hidden.
Will post pics when it's done.
Cheers,
Peter
Posted via Mobile
Old 04-10-2013, 08:30 AM   #5
lowliferat
certified hack
lowliferat's Avatar
Use a vacuum at the other end
Unfit 4 Society
Pursue , Evade , Survive .
"If your not living on the edge, then your taking up too much room" Evil K.
80 G Survival bike bs 34s, Hugh's PMA , pamco, shit pipes. 81 hard tail project
lowliferat is offline   Reply With Quote
Old 04-10-2013, 09:21 AM   #6
GeorgeKillianLett
Pretty new to bikes.
GeorgeKillianLett's Avatar
If you're having trouble pulling the cable around 90's, you can take electrical tape and wrap the pull string down to the wire in a taper so that you don't have a bunched up section that will catch.
Hope this gives you an idea of what I'm talking about.
Don't forget to give yourself a "courtesy tail" (that's where you fold the end piece of tape over and it sticks to itself) so that it's easier to pull the tape off after the pull
also pull an additional string if you have multiple pulls to do!
It's not a question of where he grips it!
It's a simple question of weight ratios!
A five ounce bird could not carry a one pound coconut.
GeorgeKillianLett is offline   Reply With Quote
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
Tips, tricks & hints rficken42 The Garage 14 11-30-2012 02:06 PM
Wiring and reg/rec tips SeventhSon The Garage 3 05-13-2012 10:40 AM
Hugh's Engine Rebuilding Tips/Tricks... Punkskalar The Garage 11 12-26-2011 11:20 AM
How difficult is it to install the Mikes XS wiring harness? Any Tips? bret The Garage 7 05-26-2011 12:31 PM
hidden cables in handlebars? jackass dave The Garage 6 01-19-2011 07:45 PM
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
