Found some inexpensive ($3 plus change) digital voltmeters on eBay for lab projects. Wanted to monitor charging system on XS1B while riding. The unit is small, could fit on handlebars, inside instrument, under seat, or even behind side cover near regulator. Only (2) wires, one to ground, other to switched power.
Pic 1 - Spec sheet
Pic 2 - Mounted between instruments
Pic 3 - Ignition 'on', shows 11.2 volts
Huh? 11.2 volts? Need to charge battery...
Pic 1 - Spec sheet
