XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. Itís free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
Notices
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 06-01-2013, 10:14 PM   #1
CalsXS2
XS650 Junkie
CalsXS2's Avatar
Default Air compressor. How do you have yours mounted to the floor
IT'S ALIVE!!
So I finally got this thing pieced together. Every part on it is new except the tank, and electric motor. It's a walker all right. It wants to vibrate across the floor. I'm really shocked at how quit this thing is.
I'm just wondering how you guy's have your compressor's mounted. On my old one, I just left it on the shipping pallet. But I'd have to build one more or less now. I really don't want to drill big ass hole's in my garage floor either,,, unless I have to. Post pic's of your set ups.
Rural King has a rubber mat. I could cut it to what ever size I want. I wonder if that would keep thing's in place. I wonder if these rubber pad's are any good. You guy's ever see these.
http://www.ruralking.com/powermate-v...94-0137rp.html
Here's my Frankenpressor.
"EXPLAIN IT TO ME LIKE I WAS A 6 YEAR OLD"
1972 XS2 restoration underway!!
1973 TX750 Twin. A $40 Barn Find!!
1982 Suzuki GS650 G
CalsXS2 is offline   Reply With Quote
Old 06-01-2013, 10:17 PM   #2
Street Tracker
Dirt Track Mentality
Street Tracker's Avatar
Default Re: Air compressor. How do you have yours mounted to the floor
Red headed it to the slab myself but mine is out side.
Donny
82,81,80,79 XS 650 Parts Street Tracker Hopes
Street Tracker is offline   Reply With Quote
Old 06-02-2013, 04:52 AM   #3
DogBunny
XS650 ThermometerDipstick
DogBunny's Avatar
You may not want to drill holes in your floor, but that is the correct way to go. If you've never done it before, you need a hammer drill and a masonry bit. You can rent the hammer drill from a Home Depot. Vacuum the holes clean. You need a setting tool and a hammer to set the anchors. Use drop-in anchors, and make the hole deeper than the anchor. This will put the top of the anchor below floor level, so when you move you can fill/repair the hole.
1976 with points; 1979 with Pamco; 1982 with TCI; 1977 XT500; 1990 Sportster
http://www.handspiral.com/ThermoDipStick.htm
DogBunny is offline   Reply With Quote
Old 06-02-2013, 06:47 AM   #4
jd750ace
Front Toward Enemy
jd750ace's Avatar
My 30 gallon is framed, on wheels and has rubber feet. Sorry I'm not much help. I have seen a couple on a pair of 4X4's rather than a full pallet, with rubber strips on the bottom of the 4X4s.
"I've never had a problem with it" does not make it a good idea.
1979 Special II. K&Ns in air box, Pamco with E-advance, Dyna coil mostly stock.
2003 Road Star Silverado Silver Edition
2002 SV650
jd750ace is offline   Reply With Quote
Old 06-02-2013, 07:11 AM   #5
Mikeinnh
Mikeinnh's Avatar
When I was in Florida, I had mine bolted to the floor with anchors. I didn't use a hammer drill, just a good masonry bit and didn't have any problems. Since mine didn't come with rubber pads, I made some by cutting 3 pieces out of an old motorcycle tire, drilling a hole in each for the mounting bolt, and putting 1 between each compressor "foot" and the slab. Cuts down on vibration and noise. Since we moved to New Hampshire, my antique garage has a wood plank floor and I don't even have the compressor screwed down.
Mikeinnh is offline   Reply With Quote
Old 06-02-2013, 08:06 AM   #6
rusty rocket
XS650 Junkie
rusty rocket's Avatar
You could build a small pallet the footprint of the compressor(I would lay a 2x4 on the flat side and shiplap the corners), you can then toe screw the pallet to the bottom plate of your wall with a long screw(3''-4"). I think that would be more than enough to keep it from scaring all the other tools in the garage.
When I read about the evils of drinking I gave up reading!
rusty rocket is offline   Reply With Quote
Old 06-02-2013, 08:27 AM   #7
jd750ace
Front Toward Enemy
jd750ace's Avatar
Quote:
That would keep it from walking away, but my wife would shit her britches when that thing kicked on and started shaking everything out of the medicine cabinet with it secured to the wall!
Mine's loud as shit, and I like it being on wheels, because I can wheel it away to a tire with a full tank, and I can wheel it out the garage door when I'm using a lot of air so the garage is not a constant drone of compressor. Not practical with a larger one, but one of the reasons I got the one I did.
2002 SV650
Old 06-02-2013, 08:36 AM   #8
rusty rocket
XS650 Junkie
With a large stand up unit it needs to be bolted down some how. When I was moving last year mine tipped over(i caught it but it could have been a real bad thing). They are just to top heavy.
Old 06-02-2013, 08:46 AM   #9
jd750ace
Front Toward Enemy
jd750ace's Avatar
I agree. My dad has never used the stand-up tank type due to this. He's always used the horizontal tank setup.
stand-ups beyond 30 gallons are dangerous without being tied down, and probably 30's as well if they are not portable types.
2002 SV650
Old 06-02-2013, 01:17 PM   #10
angus67
xxxxxxxxxxxxxxxxxxxxxxxxx
angus67's Avatar
imo, anything over 30 in a home garage is overkill, unless your painting. my 33(yes, I just contradicted myself) Has wheels, and I like that for when a neighbor needs a tire filled. it isn't bolted to the floor, but I do have a horse stall rubber pad in the corner were it usually lives.
1971 xs1b 3600 miles
1980 xs chop, bored to 680, kick only. ridgid. bs34's xsjohn's needles. 46pilot, 140 MJ.
1980 xs bobber. electrical nightmare. Destined to be xs1-b clone
2003 suzi marauder. Debaffled, stage 3 carbs.
angus67 is online now   Reply With Quote
Old 06-02-2013, 03:39 PM   #11
CalsXS2
XS650 Junkie
CalsXS2's Avatar
Quote:
Well. I'm hoping this thing will run a sand blaster.
1982 Suzuki GS650 G
Old 06-02-2013, 05:04 PM   #12
CalsXS2
XS650 Junkie
CalsXS2's Avatar
Well, here's what I ended up with. I'm not 100% satisfied. All though putting it on the 2x4's made it a little more stable, I think if a drunk fell into it, it could be knocked over. Not that there's ever any drunk's in my garage.
Adding to an all ready top heavy model, the new pump I put on there is a lot bigger than the old one. Don't get me wrong. It's not that unstable. I'd just feel better if it was a little more secure. Ya know what I mean.
I put some witness marks around it and plugged it in. It does not move. I think to ease my mind I'm going to go ahead and put either a rubber pad, or just strip's under the 2x4's, and just use some Tapcon's to hold it in place.
1982 Suzuki GS650 G
Old 06-02-2013, 05:20 PM   #13
Royboy
many roads, little time
Royboy's Avatar
Location: North Central MN / Gold Canyon AZ (seasonal tramp)
I replaced the relatively junk original Porter Cable which failed in less than a year with a great old Smith 2 cylinder that I had laying around. It was top heavy before and with the Smith up there it is more so. 2x4 base and I tethered it from the compressor to the wall with a chunk of light chain just to cancel the tip over factor.
roy
Whether you think you can or think you can't, you're right. (Henry Ford)
78'SE, 77'D, 78'SR500, 98' Honda Magna
Royboy is offline   Reply With Quote
Old 06-02-2013, 06:00 PM   #14
jd750ace
Front Toward Enemy
jd750ace's Avatar
RoyBoy, did your compressor pump shit, or did the motor capacitors die? Been a notorious problem over the past few years with Chinese capacitors because the materials don't get processed right, and since them bastards are pretty much sole suppliers nowadays, it ain't gonna get better. Damn Chinese!
2002 SV650
Old 06-02-2013, 06:44 PM   #15
Royboy
Royboy's Avatar
The compressor started pumping its crank case oil into the lines. Cylinders were shot. Not worth fixing. Cheap crap.
roy
Old 06-02-2013, 08:30 PM   #16
CalsXS2
XS650 Junkie
CalsXS2's Avatar
A videographer I'm not. Hell. I can't even spell it.
But here's my attempt. Kinda sucks. But at least you can tell what it is. And I didn't trash the camera this time.
http://www.youtube.com/watch?v=UPppCnl2l3s
http://www.youtube.com/watch?v=qC4knYtJnzk
1982 Suzuki GS650 G
Old 06-02-2013, 08:39 PM   #17
CalsXS2
XS650 Junkie
CalsXS2's Avatar
Quote:
roy
Mine more or less did the same thing. But for $50, I figured the tank and electric motor was worth that.
The guy swore "It Runs. Just won't build pressure". Ya right.
1982 Suzuki GS650 G
Old 06-02-2013, 09:54 PM   #18
CalsXS2
XS650 Junkie
CalsXS2's Avatar
I have a new concern. The old pump's main tube to fill the tank was a lot smaller than the new pump's. No biggie. I just moved to a different port so I didn't create a restriction going from 3/4" to 1/2".
But in doing so, I now realize I used the port where my regulator was supposed to go. Now instead of my main air supply feeding from a 1/2" port,, it's feeding from a 1/4" port,,, using a 1/4" regulator.
I'm hopefully going to be doing some sand blasting with this set up. Is my 1/4" regulator going to be ok. I do have another big port I could use if need be. But it's about 1-1/2". I'd have to get a bushing to hook it up.
So am I over thinking thing's here. I get told that a lot,,,lol. Will this set up be ok. Thanks.
1982 Suzuki GS650 G
Old 06-02-2013, 11:09 PM   #19
MacMcMacmac
Murdercyclist
MacMcMacmac's Avatar
We would often just attach hockey pucks to the feet to keep the tanks from walking on horizontal units, but verticals really should have a wide base, or be bolted down.
Hate to say it, but the sandblasting is going to be slow going, unless it's small parts in a cabinet. Our 10hp Ingersoll Rand was just adequate with a 1/8" nozzle. It will get done, just don't expect to be blasting non-stop. I don't think I'd bother with a regulator, the tank is going to draw down pretty quickly once the blaster gets going, and as I said, you don't want a single stage pump set up for much more than 130psi anyway. 1/4" regulator is way too small for blasting, and probably will restrict the flow too much for a good impact gun as well. If you need lots of flow, use the bigger tank bung and bush it down to 1" or 3/4". Yes, it's going to be a royal PITA to get that original bushing out.
BTW, that original pump was nowhere near a 5hp unit. It is a good 2hp pump at best, and there has been some litigation in the past few years over bogus HP claims on compressors. I'm not surprised the pump failed, it was probably turning a billion rpm and running hotter than a firecracker (you can tell by how discolored the paint is on the cylinders). Normally, they are very sturdy pumps that will easily last 30 years when operating as they were designed to. Heck, I'd probably rebuild it and keep it for another project. Those old SpeedAire/Campbell Hausfeld VT pumps were excellent, simple pumps that were sold under a huge variety of names, including Craftsman, when Craftsman meant something. Have you done an amp draw check at cut-out pressure to see if the pulley sizes are going to work ok? If Hugh has his eye-crometers, my ear-crometers says the RPMS sound like they are around where they should be, but an amp check would be nice. You did a nice job with the setup!
MacMcMacmac is offline   Reply With Quote
Old 06-03-2013, 03:48 AM   #20
CalsXS2
XS650 Junkie
CalsXS2's Avatar
Thanks for the reply.
As far as sand blasting goes, I don't plan on doing a lot. Just my own bike resto stuff. Like the frame on my 72 XS2 for starters. And of course all the other parts as well.
I'm going to be using a cheap Harbor Freight blaster. Most of the reviews say it works well @90psi, as long as you have a big enough compressor. Which by the sounds of what these reviewers were saying they had,,, mine should work. Hopefully.
Here's a link to the unit. It has a 1/4" air inlet. Since that's the case,,, should I worry about trying to hook up a larger line since it's just going to the 1/4" air inlet of this sand blaster.
http://www.harborfreight.com/portabl...kit-37025.html
I may end up down the line getting a Harbor Freight cabinet,,, or build my own.
http://www.harborfreight.com/40-lb-c...net-68893.html
Do you think my compressor will work for these sand blasters.
Oh ya. How would I go about checking the amp draw.
1982 Suzuki GS650 G
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
Any air compressor Guru's. Trying to retro-fit a pump CalsXS2 The Garage 9 05-24-2013 11:58 AM
Big az$ air compressor swbill The Garage 23 05-29-2012 03:51 PM
Swingarm floor stands Royboy The Garage 9 03-16-2012 07:16 PM
New air compressor? section8joe The Garage 5 02-06-2012 03:17 PM
Advice on buying an air compressor Crab_Cake The Garage 13 03-10-2011 01:17 PM
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
