XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. Itís free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 07-25-2013, 08:48 AM   #1
Bruceifer
Bruceifer's Avatar
Exclamation I need to unfreeze a motor xs650
Well hi there peoples ,,and how's it going ? !!! ,, first of all thanks to Maurice,, I will be showing that article to my brother to make sure he doesn't become a victim of this sort of thing , I read it so I will be more careful ! so I'm off to the store to buy stuff !!!. I have a xs650 that has 11000 miles on the odometer but its froze up ( the motor ) , I'm going to put something in the cylinders to free it up ,, any suggestions ? ,,
Bruceifer is offline   Reply With Quote
Old 07-25-2013, 08:55 AM   #2
jsmith1107
jsmith1107's Avatar
Default Re: I need to unfreeze a motor xs650
Marvel Mystery Oil beyond a doubt.
jsmith1107 is offline   Reply With Quote
Old 07-25-2013, 09:47 AM   #3
Bruceifer
Bruceifer's Avatar
should I put it in the spark plug holes ? , That might be a semi dumb question , but not as dumb as the 1 I didn't ask ! ,, and thanks for the reply !!!
Old 07-25-2013, 09:55 AM   #4
FrkyMnky
XS650 Junkie
FrkyMnky's Avatar
Yep. Put it it, rotate it some if you can, if not let it sit overnight and come back.
FrkyMnky is offline   Reply With Quote
Old 07-25-2013, 10:00 AM   #5
jetmechmarty
XS650 Junkie
jetmechmarty's Avatar
Can you get the valves closed on one side or the other? If the penetrating oil fails to loosen it up, you can free it with hydraulic pressure as long as you can get the valves closed on one side.
You will be able to bust it free with a grease gun or a hydraulic pump. Check out this link:
How to make a spark plug into a "Greaseplug"
For me, this method worked on a rusted stuck V8 using a hand held grease gun.
Marty (in Georgia)
XS650SK
XS650SH
XS6502F
XS650E
jetmechmarty is offline   Reply With Quote
Old 07-25-2013, 10:25 AM   #6
jd750ace
Front Toward Enemy
jd750ace's Avatar
Quote:
I put MMO in a metal coffee can and heat it up til it's smoking, then funnel it in the plug hole and let it sit overnight.
"I've never had a problem with it" does not make it a good idea.
1979 Special II. K&Ns in air box, Pamco with E-advance, Dyna coil mostly stock.
2003 Road Star Silverado Silver Edition
2002 SV650
jd750ace is offline   Reply With Quote
Old 07-25-2013, 10:35 AM   #7
Bruceifer
Bruceifer's Avatar
Nice ! ,, and in 15 minutes , really , that's fast ! , I say that because I'm a cnc machinist by trade , and still in the makings , I was thinking a good soak down with the mystry oil, then using a compression tester, charge the cylinders 1 at a time , starting at about 40, to 50 psi. to start with and increasing as needed , I should be able to soak the valves with oil , back off the rockers, and tap them to seat them with a brass hammer right ? ! ,, I do appreciate all suggestions , Thanks in advance ! , its not always the perfect answer, its the answer that helps me find the answer !
Old 07-25-2013, 02:01 PM   #8
Bruceifer
Bruceifer's Avatar
I got the oil in soaking, I sprayed pb blaster on the out side of the engine,, looks like the shed had a hole in the roof or something , a lot of greenish colors on it , the engine case is ugly , looks weathered , how can I clean that to make it look better ? , or would I be better to paint it ? , parts of it have that gray clay look , any hope for it ?
Old 07-25-2013, 03:04 PM   #9
jd750ace
Front Toward Enemy
jd750ace's Avatar
Get it running first, aside from a hose-down. You may find you short-circuit a lot of cleaning if you have issues getting it loose and going. Oil and gas have a way of getting all over the place!
2002 SV650
Old 07-26-2013, 02:58 AM   #10
Bruceifer
Bruceifer's Avatar
Last night My brother and I took a boreoscope and had a look in side the cylinders, Looks pretty rusty, I might have to tear down the heads and use a block of wood and hammer , and free them up 1 at a time , and theres still the chance of using the grease gun , but I'm sure that if I plan on using the top half of the engine I might have to have it machined, original plan was to use the lower half of the engine and the top half of 1 I have ? , I still have time , no rush !
Old 07-26-2013, 05:05 AM   #11
DADDYGCYCLES
DADDYG
DADDYGCYCLES's Avatar
First of all quick fix doesn't always work. Take the time and break the top end down to see what you are up against. I do this all the time and some come apart easy and some don't.
If you use a good oil and it sits a couple days and goes past the pistons and rings you can lift the cylinders off the block and block them up and try to tap them loose. I just did one with kerosene and it worked fine with just a block of wood and hammer. If they are rusted that bad Pistons/rings are no good and you will need a bore.
DADDYGCYCLES is offline   Reply With Quote
Old 07-26-2013, 07:23 AM   #12
peanut
XS650 Guru
peanut's Avatar
I've only had to use a block of wood on the pistons a couple of times .
I usually find that putting an engine in 1st or second gear and then gently rocking the car/bike back and forward will free up most siezed pistons eventually.
Don't expect it to happen immediately or even with a few minutes . it may take an hour or more bit by bit gradually the pistons will start to move.
You are going to have to remove the head anyway because you'll never be able to run an engine that has seized with rust like that.
Try a couple of thumps on the top of the pistons with a piece of 2x2" hardwood to get some movement then use the rocking in gear method to free them right up
peanut is offline   Reply With Quote
Old 07-26-2013, 08:11 AM   #13
jetmechmarty
XS650 Junkie
If you get the valves closed on one cylinder or the other, the grease gun will break the engine free. Having done so will keep you from having to beat anything apart on disassembly. Not using a hammer goes a long way towards not breaking things.
I have a friend who restores John Deere tractors. He brings stuff home that has been sitting in the field for years. He has a hose that screws into the engine, and the over end goes to a hydraulic cylinder. They break loose every time! His method is less messy than grease, but he went to the extra effort to make the tool that he uses often. The grease gun will git er done.
Marty (in Georgia)
XS650SK
XS650SH
XS6502F
XS650E
Old 07-26-2013, 08:39 AM   #14
Bruceifer
Bruceifer's Avatar
I went out there this morning and was trying to free up the kick start, and it moved a little, sprayed it down with wd40 in both cylinders , took the air hose and blasted the cylinder with air , at the same time I worked the kick start , and it turned right over . !!!
thinl im gonna spray it again and just leave it sit awhile .
Old 07-26-2013, 09:35 AM   #15
jetmechmarty
XS650 Junkie
Hooray! Now you won't have to deal with a big grease turd when you take it apart. If it kicks over, it will come apart without a hammer. It's your lucky day!
Marty (in Georgia)
XS650SK
XS650SH
XS6502F
XS650E
Old 07-26-2013, 01:19 PM   #16
Bruceifer
Bruceifer's Avatar
I'm still going to make 1 of those adapters !!!
Old 07-27-2013, 08:28 PM   #17
Bruceifer
Bruceifer's Avatar
Hey guys ,, check this out , Marvel Mystry oil ,, http://youtu.be/MJ-uf4YyeHI
Old 07-28-2013, 05:04 AM   #18
nj1639
Paleo-simplistic
nj1639's Avatar
Hmm.....looks like more piddlin' time in the polebarn for me and MMO.......
'83SK, XS750 forks, XSJohn quick throttle mod,2 over bore, 17/32 gearing, UNI's, Voltmeter, bitsa -'77D, upgraded ignition w/stock TCI, bs34's w/UNI's, voltmeter-
'78SE upgraded w/stock TCI, bs38's w/UNIs, '79SF tank and side covers
http://www.xs650.com/forum/showthread.php?p=66518#post66518
Go ahead, turn the damn power and water off....I'm ready!
nj1639 is online now   Reply With Quote
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
Wanted - Looking to start a build. Xs650 frame& motor maybe xs11 motor? Jszzk20 Classifieds 0 12-03-2012 12:02 AM
For Sale - XS650 Motor INDIANAXS650 Classifieds 2 06-05-2012 04:07 AM
Wanted - xs650 motor bigwelt Classifieds 5 05-25-2012 11:10 AM
Wanted - xs650 motor angrycamanche Classifieds 0 02-29-2012 05:52 PM
For Sale - xs650 motor Motrhedd Classifieds 3 01-14-2011 01:50 PM
Tags
how to
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
