XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. Itís free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 09-29-2009, 08:55 PM   #1
Travis
Staff Member
Travis's Avatar
Default Homemade and Unique Tools
Letís see some of the homemade tools you guys have made!
Sometimes when youíre working in your garage or shop, the tool you need doesnít exist. Or maybe youíre cheap or donít want to run to the store to get some simple tool. Maybe you can build a tool thatís stronger than what you can buy. Whatever the reason, letís see the tools youíve made.
Also, letís see the unique tools that you donít see in every toolbox, but are very handy to have around.
Iím sure youíve seen this one before. The $2 carburetor synchronizer. Works great!
Beefed up clutch hub holder tool. The one I got from mikesxs crumpled when getting a stubborn clutch center nut off. Itís made from 4 old steel clutch plates tacked together.
The pieces I made for using electrolysis to get rust out of gas tanks. More info on that process.
A couple of cheap ground down and bent screwdrivers and wrenches. I use the two screwdrivers on the left for removing pilot jets and mixture screws. I think I bent the cheap wrench to get at a bolt when removing an xs650 starter with the motor still in the bike.
These two aren't homemade or all that unique, but they come in handy and you donít see them in every tool box. The locking adjustable wrench works better than I ever imagined. It will grab nuts and bolts very tight and will even loosen ones that good wrenches will strip. The double pivot needle nose pliers are great for reaching into narrow deep places.
- Travis
Travis is offline   Reply With Quote
Old 09-29-2009, 11:44 PM   #2
plane_ben
XS650 Junkie
plane_ben's Avatar
Default Re: Homemade and Unique Tools
I use my trusty 1/2" drive air impact gun for clutch nut. Just use a glove or rag to hold the center hub. Comes right off every time.
If you don't do it this year, you'll be another year older when you do. Warren Miller
plane_ben is offline   Reply With Quote
Old 09-30-2009, 11:38 AM   #3
Travis
Staff Member
Travis's Avatar
Yeah, my 1/2" impact isn't so trusty. It sucks so bad I don't usually even get it out. The mikesxs clutch holder was usually good enough for holding the clutch but this one was on so tight that I had to make that tool and use a breaker bar. A good ĹĒ impact probably would have done the job, but that tool didn't cost me anything and it's nice to have around.
- Travis
Old 09-30-2009, 02:50 PM   #4
plane_ben
XS650 Junkie
plane_ben's Avatar
Necessity is the mother of invention. I have personally resorted to hammer and chisel. But i'm older and hopefully wiser now.
Old 10-01-2009, 11:28 AM   #5
Travis
Staff Member
Travis's Avatar
A few more:
Heavy Duty Scraper
Top Dead Center Stop. Have to be careful when using this on the XS 650 you don't hit a valve. Made this using an old spark plug. It was a lot more work hollowing it out that I thought it would be.
Little pump for setting fork air pressure
For holding various fork damper rods
Made this to use when working on a '60s Schwinn bicycle 2-speed bendix hub.
- Travis
Old 10-07-2009, 09:34 AM   #6
inxs
XSively Addicted
inxs's Avatar
- for drilling to remove broken studs with extractor
...drill through screw with 7/64" bit
...Drill the nylon end of the nylock nut with a 0.310" drill about 0.15" deep, the base diameter of a broken 8mm stud.
...now you can drill a straight hole into the stud using this as a guide
fear is temporary, regret is forever
inxs is offline   Reply With Quote
Old 10-07-2009, 09:53 AM   #7
Travis
Staff Member
Travis's Avatar
Great idea inxs!
- Travis
Old 10-11-2009, 09:52 PM   #8
plane_ben
XS650 Junkie
plane_ben's Avatar
Made a valve spring tool today. Works like a champ.
Old 10-12-2009, 09:27 AM   #9
Travis
Staff Member
Travis's Avatar
Ben, very cool. Thanks for sharing.
- Travis
Old 10-22-2009, 07:41 AM   #10
inxs
XSively Addicted
inxs's Avatar
- i use this to hold the 17mm allen head bolt inside the fork slider so i can release the fork tube...each end has 2 x 17mm nuts tightened (with locktite) against each other...i have it this long so i can do it in the bike - taken out and compressed 40cm is all you need ...i keep meaning to weld a short cross piece on one end to hold/twist it with
- a short length of threaded rod, 2 nuts, a collection of large washers and the 2 old internal bearing races to pack the new bottom bearing race as it slides inside the stem
Old 10-22-2009, 09:22 AM   #11
Travis
Staff Member
Travis's Avatar
I've done something similar with the races. Did you grind just a little off the circumference of the old races to they come out easier after they've pushed the new race into place?
- Travis
Old 10-22-2009, 10:26 AM   #12
inxs
XSively Addicted
inxs's Avatar
- no i used the races just as they were, the tube bottom flares out just enough to allow clearance...
Old 10-22-2009, 10:32 AM   #13
Travis
Staff Member
Travis's Avatar
Good to know!
- Travis
Old 10-22-2009, 06:40 PM   #14
crash
XS650 Junkie
crash's Avatar
These are my tools.
crash is offline   Reply With Quote
Old 10-22-2009, 06:54 PM   #15
crash
XS650 Junkie
crash's Avatar
More of my tools.
Old 10-22-2009, 09:33 PM   #16
Travis
Staff Member
Travis's Avatar
It's like the Where's Waldo of homemade tools.
Ok, so I see the homemade roller.. That's pretty cool.
And the scissor lift with the plates on the top and bottom. Great idea.
Anything else in these pictures that I missed?
- Travis
Old 10-23-2009, 04:26 AM   #17
crash
XS650 Junkie
crash's Avatar
sorry been in the bar,we made the table lift from a pallet lift that lifted pallets of paint will lift 5000lb,and the vise on the table for the front tire,
Old 10-23-2009, 09:23 AM   #18
Travis
Staff Member
Travis's Avatar
That's cool. I didn't even notice that the table wasn't meant for bikes. At first glance I just though it was a heavy duty handy lift.
- Travis
Old 11-05-2009, 07:50 AM   #19
5twins
XS650 Guru
5twins's Avatar
I make lots of little "helpers". I have a small stick welder and scrounge scrap metal from the various construction sites I'm working at. It's amazing the good stuff that gets thrown out. Here's a link to a few tools .....
http://mysite.verizon.net/vze83kbx/id2.html
This past summer I whipped up a combination wheel work table and base for my Harbor Freight motorcycle tire changer. It works great. Here's some info .....
http://xs650temp.proboards.com/index...ay&thread=8163
'78E Standard and 4 Euro twins
5twins is online now   Reply With Quote
Old 11-05-2009, 08:31 AM   #20
crash
XS650 Junkie
crash's Avatar
nice work on the tools
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
Insurance for tools? Travis The Garage 19 01-14-2015 03:34 AM
Mount a Motorcycle Tire Without Using Tools jimed The Garage 9 06-13-2010 10:22 PM
Tags
build, fabricate, homemade, tools, unique
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
