CDNTX650
XS650 Guru
I know no one has probably had to do it....but i took some 800 grit sand paper and shaved about a half step out of those plastic donuts that hold the needles in my bs34 and voila....yes, they had to be lowered! Carbs have throttle shaft seals, mixture orings, float valve orings, 45 pilot, 140 mains. Even did it with the stock pilots. Plugs are over pilot jets. Best part is, if i need to back i can shim them back to stock. Uni filters too!
Thought i would share. Bike runs great now, i can cruise in low rpms and actually get on it without it cutting out. Turns out big mains really can bleed over quite a bit. Still have a small lean surge near redline, very small. Might try 142.5 mains.
