racerdave
^ Gone not forgotten ^
I am running out of room, and doubtfull I will have much time this summer to continue work on her. All the good stuff most trackers get. Ready to be pulled apart for frame detab and paint to both the frame and glass. The glass is just white gelcoat. It is not a 750, that is just playing around. Started life as a 1979 XS650 Special. Tracker bars,Hughs solid riser bushings,fork brace,rebuilt calipers,stainless brake lines,Ferodo frt/rear pads,Brembo front master cylinder,dog leg levers,Pamco ignition and hot coil,Shorei battery,VR115 regulator and Radio Shack rectifers setup,cut down oem battery bax and atc fuse holder,GPSW Champ 750 tank with dual forward petcoks,Omars rear seat cowl, Omars 1/2 mile ceramic coated pipes with inserts in head and headpipe outlet,Vesrah HD clutch springs,EBC 7 plate clutch kit,EZ pull cable, VM34 carbs setup from 650 central with aluminum manifolds, Uni Pods, Omars 19 inch rear wheel adapter, new chain and sprockets,radian swingarm, Maxis 27x7x19 on rear, same included for front, late model Triumph Thruxton shock/springs, plenty I have not mentioned.All above bought new for this project. Runs great. Wisconsin title. Located in Joliet, Il. My build thread shows a lot:
http://www.xs650.com/forum/showthread.php?t=9843
Many pics here:
http://s234.photobucket.com/user/kawidave1/library/My Yammie Tracker?sort=3&page=1
Will not part out. I will slowly add to this post all the new stuff on it. Any questions post or pm. $3000.00 Located 50 miles south of Chicago Il.
