That looks pretty normal. The plates are probably sticking from oil cling. As you see, the pressure plate doesn't move out much, only a couple MM. Divide that between a dozen or so steel and fiber plates and you don't get much space between each one. But it works. With the engine spinning, the plates will slip against each other and the clutch will disengage.
