Had a bit of a nightmare trying to fault find my non working flashers last week which wasn't helped by what appears to be a discrepancy in some of the electrical schematics on the site.
The 1978,79 and 80 schematics show one of the flasher relay terminals conected to ground which surely cannot work as there doesn't appear to be a 12v+ live feed to the relay. unless it comes via the yellow /green wire from the flasher cancelling unit ??
The above schematics show the following wires on the flasher relay
1. A brown /white wire (which is the live feed from the relay to the flasher switch and flasher lamps)
2. A yellow /green wire which connects to the flasher cancelling unit
3. A black wire which connects to the common black ground wire system throughout the bike .
The flasher relay of my 79 special has a different connection to those shown on the 78,79 & 80 schematics and has the following coloured loom wire connected to the flasher relay
1. A brown /white wire (which is the intermittent live feed from the relay to the flasher switch and flasher lamps)
3. A brown wire which connects directly to the 12v+ horn /flasher relay fuse on the fuse block . This is clearly meant to be the live feed to the flasher relay on this bike
Why do the schematics show a black ground wire and not a brown live feed ?
