XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. It’s free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
Notices
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 11-01-2010, 06:03 PM   #1
dontarantini
dontarantini's Avatar
Default Engine won't rev above 3,000 rps when warm!?
Hey guys,
I recently took a trip down from New Jersey to Florida on my 1980 XS650 Special, during the beginning of the trip I was having trouble with my turn signals, neutral light, & horn not working (all of which are powered by the same fuse), when I shook around the fuse under the box they would start working again (no fuses blown).
Somewhere halfway through the trip I would put the turn signal on and the engine would cut out whenever the signal would blink, so I stopped using the signals.. a while after that I started noticing that in 1st gear the bike would refuse going over 3,000 rpms, I'd shift to 2nd gear and it would make it through. Little while later trouble in 1st AND 2nd.. then it was just completely stuck at 3,000 rpms (I could go about 30 mph in 5th gear tho! ) Stuck.. I took apart the carbs and cleaned them out, checked fuses, looked inside the headlight for shorted wires, looked inside the turn signal switch. Nothing helped.
Stuck somewhere in Virginia I camped out for the night, when I get up the next morning I checked the Valves (which I adjusted before I left) and they were fine. I started it up and was surprised to find that it was working, I took to the road again hoping the mysterious problem had gone away.. about an hour or so later it came back. Stuck somewhere in North Carolina now somebody stops by to help, we head over to a bike mechanic he knows and we look at EVERYTHING, we checked the fuel filter, the gas inside the carbs, removed the rotor, checked plugs, swapped ignition coil, checked turn signal wiring and could find nothing.. absolutely nothing.
He comes back the next morning and we start to try again, he gives the battery a charge (charged for 15 minutes maybe?) with an expensive bike charger and the bike is working again (which it does when cold). I head out again and decide that if its the battery I should keep up high rpms to make sure it stays charged, I hit the highway and it pretty much worked fine til I hit Florida, near the end of Florida it was acting up again with the 1st gear rpm limit but thankfully I made it to where I was goin.
Now I'm home so I've got a bit more time and not such a rush but am still puzzled as to what it can be, I took my battery to Autozone and had them test it there, they said it was bad so I bought a new battery.. but the problem still hasn't gone away.
Anybody know what could possibly be causing this? I changed the Rotor before leaving and the resistance is still good, the Stator resistances between white wires seems good and the Pickup resistance as well. The strange part is that the Regulator seems to be charging, it gives me a 14.5 Voltage at the battery when revved up at a standstill. I have no clue anymore.. hopefully its not the TCI box because I can imagine that will be expensive.
I bought the Chrysler Regulator since the Red wire coming from the original regulator seems to be heating up and starting to melt the connector, I'll put it in tomorrow (I checked the Rectifier and the diodes seem to be intact so I'll just switch the green and brown wires to the new Regulator).
Btw, where do you guys suggest mounting the chrysler regulator since it needs a good ground?
If the regulator doesn't work do you guys have any suggestions on what it could be?
Keep you updated on whether its fixed or not.
Any help is better than none,
Thanks,
Matt
dontarantini is offline   Reply With Quote
Old 11-01-2010, 06:26 PM   #2
TwoJugs
Excess XS
TwoJugs's Avatar
Default Re: Engine won't rev above 3,000 rps when warm!?
I was guessing electrical while reading and I guess you are looking in that direction. Where in Fla are you at now?
You might want to look into a short in the harness. Check in the headlight bucket too. Tats where most wires go to and lots of connectors there to get lose. Might be charging fine when still. Running brings out the short and kills the voltage. Try checking batt volts when it acts up again before you put a charger on it or start it.
My welding skills have greatly improved my grinding skills...
TwoJugs is offline   Reply With Quote
Old 11-01-2010, 06:58 PM   #3
dontarantini
I'm staying over in the Cape Coral area, near Fort Myers.
I imagined it could be a short but can't imagine where or why it would cause the bike to be limited to 3,000 rpms.
I checked behind the headlight and didn't see anything too horrible but I will recheck tomorrow incase anything had changed on the remainder of the trip.
The part that gets me is that I'm unable to understand why it will idle fine but be unable to raise rpms.. is it low ignition coil voltage that can't keep up to the increased demand for spark? Caused by a low battery caused by a voltage regulator or possibly a short in the system that is draining the battery?
I assume the symptoms could also be caused by a malfunction in the electronic ignition's timing advance (TCI Unit), but I hope not.
If I get the rpms up they will stay up without a problem, but stop and go at lights for a bit and I'm screwed.
Old 11-01-2010, 07:09 PM   #4
TwoJugs
Excess XS
TwoJugs's Avatar
I am across the state a few hours or less. If you head back this way across alligator alley let me know. I have a shed full of XS parts and could probably find the swap out parts to do some troubleshooting for you.
I would look for low voltage at the batt when it acts up. Maybe rig up a digital voltmeter strapped to your tank while you ride. See what happens when it acts up, 3000rpms? Tap the voltage from the point closest to the ign box.
Old 11-01-2010, 07:33 PM   #5
kvanderploeg
The Dutch Terror
kvanderploeg's Avatar
I had an issue where it wouldn't rev above ~3,000 rpm. Spend $2 in parts and repaired the TCI box. See the thread here, and scroll down to see all the info and my photos.
http://www.xs650.com/forum/showthread.php?t=3289
Kent
1980 XS650 Bobber Build on a Mr. Lucky's Frame
2007 Yamaha V-Star 1100 Classic
2012 Yamaha Super Tenere
kvanderploeg is offline   Reply With Quote
Old 11-01-2010, 08:02 PM   #6
dontarantini
Thats a good idea TwoJugs, I'm gonna strap a voltmeter to the tank for my ride after swapping the regulator and see what happens. And I'll let you know if I head that way, I might be heading over to Miami within a couple of weeks.
Very nice writeup Kent, I didn't even want to look at that box wrong due to the fear of an expensive replacement, no idea it could be taken apart like that. I'll certainly be taking that one out tomorrow and see how it looks inside.
Were you having any trouble with the turn signals or only the neutral light? I'm pretty sure the neutral light and turn signals are getting power from the same place so it could be the same problem.
I'll let you guys know how it works out tomorrow,
Hopefully I'll get it runnin right without too much emptyin of the pockets
Old 11-01-2010, 08:02 PM   #7
XSLeo
XS650 Guru
XSLeo's Avatar
Well lets stop and think about things a bit. Hmmm, The bikes an 80, so all the parts are at least 30 years old. Your TCI box is at an age where things can start to go bad. Several people have found bad solder joints in the box, loose wires, burnt parts. I might start by pulling the TCI box and looking for anything real obvious.
Good luck on the fix.
Just had a thought, is the fuse box still original, if so that may be the trouble. The clips that hold the fuse get weak and can even break off. Replacing them with inline blade type fuse holders fixes lots of problems.
The only way you can find out if you can do something is to try.
75 XS650B with a few mods, Dual disc brakes up front, Disc on rear, Pamcopete Ignition with the green coil, Radio Shack rectifier and Chrysler regulator, LED tail/brake and turnsignals. 750 kit,1.5 headepipes, Emgo shorty mufflers.
XSLeo is offline   Reply With Quote
Old 11-01-2010, 10:45 PM   #8
Travis
Staff Member
Travis's Avatar
TCI boxes don't cost that much. Lots of people are removing them for Pamco or Boyer units so they are out there. They show up on ebay every now and then. A local bike salvage yard gets about $70 for them. There's got to be a few people here that have them laying around that would probably sell one to you. You could also buy a Pamco.
- Travis
Travis is online now   Reply With Quote
Old 11-02-2010, 05:45 AM   #9
kvanderploeg
The Dutch Terror
Quote:
xjwmx, the original poster had problems with the neutral light, but my neutral and turn signal lights were all working fine. Also, his TCI box looked a lot different inside than mine, so there may be differences in the years or even suppliers. Good luck, and keep us posted.
Kent
Old 11-02-2010, 07:50 AM   #10
TwoJugs
Excess XS
TwoJugs's Avatar
Sounds like a voltage supply issue. A poke around the headlight bucket, harness and fusebox might be worth the time. When it came time to make my harness from scratch I found out that the bike uses the run-stop switch to feed power to the ign system. I expected it to act like a magneto ground to shut the motor off when needed. Since it supplies voltage to the ign it brings new issues to the game. Even if the box gutts show something burnt and repairable I would want to know why it happened? Directionals and horns use a fair amount of current to operate. Weak grouynds can act like a weak power feed too
Old 11-02-2010, 02:27 PM   #11
dontarantini
Alright.. I took out the ignition box this morning... what a pain that was, had to take out the entire battery housing out
When I took the ignition box apart though it looked like it was in great condition, I tested the diodes and they tested fine, doesn't mean something else couldn't be wrong with it but I rather doubt the problem is there. I took several pictures of the circuit board which I can post if you guys want to see it.
I hooked up the Chrysler Regulator but left the stock Rectifier hooked up, then connected a Voltmeter to the battery and started it up. It seems to be charging a bit higher now than it was before, its hitting 14.3-5 volts at around 2,000 rpms, it was capping at around 14.7 while riding and when I would stop to idle (1,250 rpms) the battery was actually at 14.2, which seems a bit high, didn't know it could produce that much voltage at idle.
The turn signal didn't seem to have too much of an affect on the bike this time, so hopefully with a bit more riding the battery will make it to its full charge and take the signal in stride. I'll ride it a bit more and let you guys know how things hold up, but its looking like it could be the voltage regulator that was causing the problem, atleast thats my hope. If the turn signals drain too much and the regulator is not compensating then the battery could get low to the point that it will not have the juice necessary to fire off the amount of sparks needed at higher rpms, even though it will idle. I read somewhere that it takes even more voltage for a spark to cross a gap when under pressure, so even if you get a spark when you remove the plug and hold it against a ground it won't necessarily spark when inside the engine against the compression.
Thats my Theory.. hopefully it holds up and this phantom problem doesn't haunt me anymore,
Thanks for all the suggestions, I'll let you all know how it goes!
Btw, I was thinking of replacing the fuses with a blade fuse box, anyone know where I can find a decent fuse block? Saw the 1-Fuse Connectors at Walmart for $3 each but was hoping for a one-piece block with 4 slots.
Old 11-02-2010, 03:45 PM   #12
xjwmx
Back in the World
xjwmx's Avatar
An easier way to get to it and the r-r is to remove the panel in front of the rear tire and set it up on top of the tire. Gives you pretty good access.
It might be that reseating the tci connector fixed your problem. Or jiggling the wire connections at the board while you had the board out. Doesn't sound like your voltage was low enough to have much effect, to me. But I haven't read this whole thread.
I've learned a few more things about the tci and will try to update that thread that somebody referred you to, tonight.
But - if the engine cut out when the signal flashed it sounds like frayed wires somewhere. But the tci seems to work at a lower voltage than the stock flashers will. If you could jiggle the fuses and fix something, you need to really fix the fuses first.
1981 XS650, removed ts canceler, removed clutch switch, removed big gray headlight thing behind battery, removed kill switch (crumbled), removed chain guard, (came off), "throw in the towel" vacuum petcock mod, surplus Bosch H4 headlight shell. CB750 handlebars, various wire and tape.
xjwmx is offline   Reply With Quote
Old 11-03-2010, 01:59 PM   #13
dontarantini
Well, seems the problem isn't as bad anymore with the new regulator, but it is still there.
With a voltmeter connected I'm reading 14.20V at idle, when I squeeze the brakes the brake light makes that jump down to 13.30V and then slowly make its way down to 12.90, that seems like quite a bit of a drain on the battery there, and it seems like the alternator can't keep up.
After holding the brakes for a bit if I try to accelerate (while still holding brakes) it'll bog down, having trouble trying to get through 3,000 rpms like usual, but letting the brakes go and having the voltage pick back up it revs fine.
The turn signal still makes the engine hesitate but its a much smaller hesitation, doesn't really get in the way of riding.
New battery, regulator and rotor.. wonder what could still be the problem?
Maybe these lights are just too much of a drain for an older charging system, or maybe the lights are shorting out somewhere.. could it be a Stator going bad?
Maybe I should just swap the whole freakin charging system for a perm. magnet setup..
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
Mikuni VM34s - intermittent stalling when warm MB-Ian The Garage 2 09-15-2010 08:33 PM
Higher idle when warm? Inked Monkey The Garage 17 06-24-2010 10:23 AM
Tags
electrical, engine
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
