XS650 Forum
Go Back   XS650 Forum > General Discussion > The Garage
Register FAQ Members List Search Today's Posts Mark Forums Read
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries, but you have to register before you can post or view attachments. It’s free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
Notices
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Topics
Threads in The Garage can also be viewed by Topic.
Reply
Thread Tools
Old 01-23-2010, 12:26 AM   #1
cheftay
Keepin' it real
cheftay's Avatar
Send a message via AIM to cheftay
Default Best Headlight Anyone?
Hey everyone,
What are some of your alls opinions on headlights for the XS650?
I know mikes sells halogen kits( $32) as well as the blue replacement bulb($8)... there are 2 different 7" kits and then a conversion kit.
Are there other options besides these?
Thanks guys!
.cheftay
1971 XS1B - almost restored
1975 XS650 - basket case - cafe build
1980 XS650 - basket case - bobber build
cheftay is offline   Reply With Quote
Old 01-23-2010, 12:42 AM   #2
inxs
XSively Addicted
inxs's Avatar
Default Re: Best Headlight Anyone?
- with a little creativity you can mount any headlight you take a fancy too, even those including switches, signal lights, gauges, modern leds, older bulbs etc...if you go compact you will need to think about where you put the cabling thats hidden inside them - this can often be carefully laid along the frame under the tank...self-made simplified looms make this easier too
fear is temporary, regret is forever
inxs is offline   Reply With Quote
Old 01-23-2010, 10:25 AM   #3
retiredgentleman
retiredgentleman's Avatar
I just use a Slyvania H6024 Halogen from Walmart. 40/60 watts. I prefer to use a 40 watt low beam rather than a 55 watt low beam................it reduces the electrical load on the alternator.
retiredgentleman is offline   Reply With Quote
Old 01-23-2010, 01:26 PM   #4
cheftay
Keepin' it real
cheftay's Avatar
Okay cool! I don't think I'm gonna get creative really, just still with the 7inch assembly. I just was a nice bright light that I won't have any problems with.
From walmart really?
Is the 40 watt low beam pretty bright still?
Thanks!
.cheftay
Old 01-23-2010, 02:53 PM   #5
pumps
pumps's Avatar
On my XS I haven't swapped it out yet but on my old 79' KZ650SR Kawasaki I did the halogen headlight conversion and it was a big difference. I don't ride at night a lot but if I have to I sure want to see.
On an XS you won't pass yourself everyday.
Currently wrenching and riding on a 1977 D XS650- "Patience"
Patience project pics: http://s135.photobucket.com/albums/q148/pumps32/XS650/xs%20repairs/
pumps is offline   Reply With Quote
Old 01-23-2010, 03:26 PM   #6
cheftay
Keepin' it real
cheftay's Avatar
The conversion kit from mikes looks pretty nice. Is it just the bulb casing with the removable bulb?
Old 01-23-2010, 07:31 PM   #7
Gordon
Gordon's Avatar
Chef, I believe that Mike's is the whole bulb assy. with a replaceable bulb. In other word's, Just like a sealed beam but uses an H4/9003 bulb. I have a similar type from a '79, with a 60/130 watt bulb. I'm getting a little "older", so the higher wattage really help's at night. I switch the headlite 'off' during day time riding. I installed a toggle switch on the low beam circut, & when I switch it 'off', the lamp checker come's into play & turn's the highbeam on at half of the voltage. So I still have a 'daytime running lamp', but it is very dim, just enough of an orange glow for the cage runner's to see me. I also have a voltmeter from Mike's installed,& have not had any charging system problem's since I repaired the bad engine to frame connection.
'80 G MODEL
Gordon is offline   Reply With Quote
Old 01-23-2010, 07:38 PM   #8
blue900
blue900's Avatar
I end up riding mine in the dark quite a Bit, I detested the stock one, I felt I was over driving it bad at 55, Just showed some small spots on the Road, On a whim I bought a Candle Power Brand Light assembly from the Local Motorbike, 4 wheeler, snowmobile everything parts store. Its H-4 P43T 60/55 and has replaceable bulb and fits the stock bucket. The H-4 Light pattern is amazing and Truly wonderful, you can see the road in front of you and its much safer than the stock one. For sure it takes more power, I have an LED tail light. They are listed in the Dennis Kirk Catolog.
blue900 is offline   Reply With Quote
Old 01-23-2010, 09:20 PM   #9
cheftay
Keepin' it real
cheftay's Avatar
Gordon that sounds like a really nice setup! I think I'm gonna go ahead and get the halogen lamp kit from mikes. I'd like to get the voltmeter too but I think i'm gonna hold off.. So far My charging system hasn't had any problems. I installed a brand new wiring harness a couple months ago and it's been okay so far.
Blue900, it looks like you're in love with the H4 so I think it'll work perfect for what I need, Thanks!
Old 01-25-2010, 05:22 PM   #10
donmillerx
donmillerx's Avatar
I picked up the 7" lamp kit from mikes, don't love it and now i'm actually looking for a headlamp with a built in speedo...
donmillerx is offline   Reply With Quote
Old 01-25-2010, 06:16 PM   #11
cheftay
Keepin' it real
cheftay's Avatar
why aren't you pleased with it?
Old 01-27-2010, 01:03 AM   #12
XSLeo
XS650 Junkie
XSLeo's Avatar
I'm using the same lense bulb unit that Blue900 is using. Not only is it bright it throws more light in front of you and less out too the sides and on your feet. On low beam it throws a spot up and to the right, this helps you see the edge of the street and side walk better. Lets you see the people and animals over there before they get on the street.
Before I did the mods to the charging system and cleaned up the switches the extra draw from the headlight made keeping the battery charged. I have converted my brake/tail light and turnsignals to LED's, very bright and almost no current draw. This compensates for the extra from the headlight.
I was having trouble with bad grounds on the headlight, this was blowing the bulb. I was in Harbor Freight and saw a headlight bulb in there for like $4.99, It was a 55/65 watt, it is a very white light with a slight blue tint. I really like the light, how long it will last is the only thing.
75 XS650B with a few mods, Dual disc brakes up front, Disc on rear, Pamcopete Ignition with the green coil, Radio Shack rectifier and Chrysler regulator, LED tail/brake and turnsignals
XSLeo is online now   Reply With Quote
Old 01-27-2010, 02:47 PM   #13
KevC
KevC's Avatar
How about a nice Cibie 7" unit, had one years ago in a Honda CB200 and it was a massive improvement
Cibie 7" light unit
Kev
KevC is offline   Reply With Quote
Old 01-27-2010, 04:38 PM   #14
XS1961
XS1961's Avatar
I just use the Lucas style( A la Triumph/Norton) with 55/60W car-type bulb ...Loadsa room in the bowl for wiring & a sandwich ...Looks nice 'n 'classic' .. Around £35 all in
No XS running... two awaiting assembly...No time...Lifes too short
XS1961 is online now   Reply With Quote
Old 01-27-2010, 05:21 PM   #15
Los D
Los D's Avatar
Gordon, how are you liking this headlight setup. They look great/clean, and I was considering one for my '74.
http://iamnotabrewster.blogspot.com/
http://www.facebook.com/losderelictos
Los D is offline   Reply With Quote
Old 01-27-2010, 09:43 PM   #16
donmillerx
donmillerx's Avatar
Looks great man...
that's what i was looking for.
Old 01-27-2010, 10:53 PM   #17
cheftay
Keepin' it real
cheftay's Avatar
Do you guys know anything about IPF headlights? They're mainly a 4x4 off-roading company but they claim to make some pretty BA headlights...
http://arbusa.com/Products/Lights/He...ements/23.aspx
Old 01-28-2010, 10:23 AM   #18
Gordon
Gordon's Avatar
I really like that assy. Nice & clean look. I also like the signal & neutral lamp's in the original guage mount's, very innovated.
'80 G MODEL
Old 01-28-2010, 01:47 PM   #19
KevC
KevC's Avatar
Quote:
cheftay
dont know anything about IPF apart from what you prob already know, Australian company, designed for offroad so shoud be tough & seem to have a good reputation.
There are a few threads over at the garage on Mikes conversion
xs650 garage headlamp conversion thread
Also JC Whitney do a few
JC Whitney Headlight Conversion Kit
Kev
Old 01-30-2010, 05:24 PM   #20
XS1961
XS1961's Avatar
Mine..Click image for larger version
Name:	my headlight.jpg
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
Wanted - Need a points cover, headlight bezel, stuff. xrise36 Classifieds 0 11-21-2009 12:56 PM
Tags
electrical
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Copyright ©2000-2010, Jelsoft Enterprises Ltd.
Copyright © 2009-2010 XS650.com, Trav, LLC
