| Welcome to XS650.com! |
| XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. It’s free and only takes a minute. Proceed to registration. (This notice will go away once you log in) |
| The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear) |
Thread Tools | Search this Thread |
#1 |
XS Monger
Well, ive been at this project for a few months and things are stalling out. Life gets in the way way to often around here. Hopefully this will help get me back on track, and some motivation wont hurt. This started out as a 81 XS frame with a 73 engine. Wanted to do somewhat more of a modern/deco chop, and avoid as much cookie cutter crap as possible. So i started out chopping the frame up and getting the stance down (after i built the jig) Wanted it raked out to about 40* 2-3" stretch, about 5" clearance...
![]() After i got the stance the way i wanted it, i started stinging my tube... ![]() ![]() ![]() ![]() ![]() ![]() ![]() Wheels came in, i originally wanted to go with dual 16's , (spoke front, street glide rear) with some gnarly knobby tires. But all the good looking dual sport tires don't come in 16's So i went with dual 18" front street glide wheels i grabbed from Ebay. These paired with the Duro dual sports i picked up look pretty tough... ![]() ![]() ![]() Went ahead and welded up most the frame, picked up a TIG from harbor freight (i know i know) but it works NICE, did a full review of the TIG on another forum HERE so i wont go into much more detail in this thread
#2 |
XS Monger
After i got them mounted i realized i was going to have to make some trees to get them to fit between the stock legs. I thought i might, but i was hoping not. Figured at best i would just have to machine some material off the wheel hub. So i did the math and made up some trees that would be wide enough, but i SUCK at math and am even worse when my kid is doing donuts around me asking for candy, so ended up having to both make trees, AND, mill the hubs to get the fit. LOL...
![]() ![]() ![]() ![]() ![]() ![]() ![]() After all that i was able to finally put it in a roller, came out pretty good, really happy with the stance although i dont like the way the tank sits so that was next... ![]() ![]() ![]()
#3 |
XS Monger
Decided to do the standard tank chop, cut 1.25 inches out to make it the width of the trees, and re-tunneled it to get it under the trees, and give it a better line.
![]() ![]() ![]() ![]() ![]() ![]() Made some bars using the clamps from the old trees and some 1" tube, was also able to get the rear sprocket drilled and bored to fit the street glide hub. You can see in the pics how much room i ended up with between the trees it was close! ![]() ![]()
#4 |
XS Monger
The frame was getting real tedious, alot of time measuring spacers, welding, grinding, MATH, errr!. SO i decided to switch it up and do some more of the sheet work. For the tank i wanted a bit of an aviation style paint job and feel. Basically just brushed metal, with some stained black streaks. Added a rib down the center, and welded in some bungs for the fuel gauge. Also welded a tube running through the tank so i could run a LED to light up the fuel gauge at night. Wires run through the tank, out the bottom. The LED is UV light. It will light up a dye additive in the fuel, making the fuel glow green. Ill be doing the same with a see through clutch case and dye added to the oil, as well as the brake fluid in the reservoir.
![]() ![]() ![]() Heres a simulated test with a piece of plexi in lieu of the gas tube ![]() And here it is after i brushed it out and powder-coated it gloss clear. Then i airbrushed some black streaks to age it a bit. Ill get a better pic later Looks freaking great in the sun. |
#5 |
man this is lookin good... lots of great ideas here
http://whiteknucklebobbers.blogspot.com/
#6 |
XS650exhaust.com
HOLY CRAP!!!
Tell us what do you do for a living? You ain't no used car salesman Awesome work! just wondering, what are you using for a mill? I see it in the background...
“It is better to keep your mouth shut and appear stupid than to open it and remove all doubt.” Mark Twain
"Any fool can criticize,condem and complain and most fools do." Ben Franklin |
#7 |
XS650 Junkie
That is some crazy nice fabrication skills. Awesome. The only problem I see is that UV light. Really hard on your eyes without protection. I use those at work with the dye for leak detection. You could have people seeing spots everywhere!
Seriously cool bike. |
" Face it, you're a neomaxizoomdweebie. What else would you be doing if you weren't out making yourself a better citizen?"
#8 |
Hands down!!! just insane. The rim wheel combo looks killer.
Never meet girl in park! Park meat in girl!
#9 |
wow, very nice work my man. you have some sweet skills.
#10 |
Talented, and creative...Mad skilz.
#11 |
King of the Ass-Hats
Wow. This one definitely goes into my favorites list. Impressive stuff.
You get me slapped with a fine. You pick fights with the customers and I have to patch everything up. You get us chased out of a funeral home by violating a corpse. To top it all off, you ruined my relationship with Veronica! What's your encore? Do you like, anally rape my mother while pouring sugar in my gas tank???
#12 |
FNG
Very nice !! I love the whells and the tank is bad-ass too.
#13 |
FNG
I Meant wheels but I'm still not awake. ^^
#14 |
Ride.Enjoy.Life is Simple
Well, with all those tools and all that excellent skill that you have, why didn't you design and make a real suspension for the rear?
#15 | |||
XS Monger
Quote:
The mill in the background is a leftover from an old business i had, not quite up to task for all the work needed on a bike. Its a grizzly X3. Works really well, just getting small. Quote:
![]() Quote:
Ive done a couple swingarm XS's, and am working on one now as well. Just wanted a rigid for this one. The seat will have springs LOL
#16 |
XS650exhaust.com
#17 |
XS Monger
For the headlight setup i really wanted a bit of a sport bike fairing, with a bit of a futuristic twist. The idea was to gut a couple of cheap aftermarket projectors, and mount them in a stepped fender. I also wanted a couple of dim green LEDs mounted inside for the parking lights to echo the other green highlights. Just wanted an eerie green "alien blood" type glow when the bike is sitting. In the pics the projector lenses still have the yellow polarizing layer on them, i have since took it off and they look MUCH better...
![]() ![]() After i cut out the holes, which was a geometrical nightmare. I telescoped some tubes together and plug welded it up. this way i could slide the lens/LED/bulb assembly through the back., which makes for easy bulb changes. Top is the low beam bottom is the high beam. ![]() ![]() ![]() The plan was to lay some nice TIG beads all around the visors and leave them as is, but cutting out the hole was pretty complex (for me anyway) and some gaps were too big. So i welded in all the gaps and smoothed it all out after i cut down the visors. Still need to blend a bit more but i HAD to test them out. The whole assembly can be adjusted in all axis's to dial in the headlights. Still need to add some details to it as well... ![]() ![]() ![]() ![]() ![]()
#18 |
Staff Member
Wow.. Outstanding work on the whole bike! Especially the trees! Thanks for sharing. I'm sure your work will inspire others. Care to share pictures of your other builds?
- Travis
#19 |
This might be a silly question, What kind of tires are those? that knobby look is awesome. looks like a cross between a avon gripster and a mx tire!!!!!!
#20 |
XS Monger
Similar Threads (based on keywords)
| Thread | Thread Starter | Forum | Replies | Last Post |
| finnally my xs build pics, Raked and hard tailed | swbill | The Garage | 133 | 05-20-2013 11:46 AM |
| Just picked up 1977 yamaha xs650, I'm new to Yamaha and have lots of questions | second generation rider | The Garage | 12 | 11-16-2012 04:57 AM |
| Just rode home a 82 xs650 (PICS added) | Fro- | The Garage | 27 | 09-09-2010 04:04 AM |
| pics of my 75 xs650.. needs definition | AceofSpades | The Garage | 16 | 08-07-2010 08:12 AM |
| another chopped/bobber | jayel | The Garage | 10 | 07-10-2010 08:57 PM |
| Tags |
| bobber, chopper, custom, fabricating |
| Bookmarks |
