XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. Itís free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 02-27-2011, 04:56 PM   #1
ReycleBill
Part Time Tyrannicide
ReycleBill's Avatar
Default What Causes Air Cooled Head Gaskets To Blow?
As I delve into my first effort to replace a blown head gasket on an XS 650 I'm pondering. I know that steam is most often the reason water cooled engines blow head gaskets but because our XS560s are air cooled I can't help but wonder what causes them to blow head gaskets in the hope that I can prevent future blown gaskets.
And please don't just say overheating is the cause because the result of overheating is most often piston seizure, not blown gaskets.
Any informed thoughts?
When the going gets tough the tough twist the throttle! Hard!
StolenMotorcycle.net helping you get your bike back in one piece!
ReycleBill is offline   Reply With Quote
Old 02-27-2011, 05:46 PM   #2
Jack
XS650 Junkie
Jack's Avatar
Default Re: What Causes Air Cooled Head Gaskets To Blow?
Engine studs are the main culprit,they're weak causing them to stretch and they're just plan to thin,along with that cushioning grommet they use to seal off prevent oil seepage past the studs.
Jack is offline   Reply With Quote
Old 02-27-2011, 06:06 PM   #3
CDNTX650
XS650 Guru
CDNTX650's Avatar
check and re-torque every year.
2010 Kawasaki Versys
1974 TX650A resto modded and never done....new...everything..cases up.
1974 engine...Rebuilt. ...waiting patiently on the stand.
2014 triumph scrambler.
1971 plymouth valiant....she's minty!
CDNTX650 is offline   Reply With Quote
Old 02-27-2011, 06:37 PM   #4
ReycleBill
ReycleBill's Avatar
Jack and CDNTX650, Thanks, that's something I can chew on.
Old 02-27-2011, 07:09 PM   #5
ReycleBill
ReycleBill's Avatar
Next question: How do I get my hands on a set of high performance head studs?
Old 02-27-2011, 07:42 PM   #6
CDNTX650
XS650 Guru
CDNTX650's Avatar
not sure of that, i just re-torque till i get constant readings after a re-build...then once a year.
Old 02-28-2011, 03:19 PM   #7
ReycleBill
ReycleBill's Avatar
Here's what I've learned thus far:
The factory head studs are not up to doing the job. The racers used to make their own but the treating of metals is a little over my head-- does anyone sell high performance head studs for XS650s.
Studs need to be kept at proper torque settings.
Head gaskets on air cooled engines do not blow because of overheating. But, detonation (spark knock) will cause overheating and sometimes blown head gaskets. Detonation is caused by any or all of the following: timing advanced too high, Air-fuel mixture set too lean, too little air flow. We must be careful not to confuse cause with effect. Detonation causes blown head gaskets-- overheating is a common symptom (effect) of detonation.
Detonation can also cause lots of things worse than blown head gaskets.
Loud pipes might save lives but loud pipes kill perfectly good engines by hiding the sounds of detonation. (Makes me glad I got rid of that 2-1 header and megaphone that came on my bike when I bought it.)
That said, another cause of detonation can be overheating. Detonation causes overheating and overheating causes detonation. Cause and effect sometimes intermingle.
An oil cooler is a must. Check!
Directing more air flow to the head is a must. A chin scoop and lowers attached to my new crash bars are planned.
An oil temperature gauge would be smart.
And finally, getting the engine out of the frame is a B&*&! when you've already got a hernia (busted nut.) I'm not looking forward to wrestling it back in.
Old 02-28-2011, 03:28 PM   #8
DLD1
Mechanical Stuff Nut
DLD1's Avatar
Replace those sealing washers that have rubber in them with good copper washers, they will seal fine and hold the torque better.
DLD1
DLD1 is offline   Reply With Quote
Old 02-28-2011, 03:43 PM   #9
Travis
Staff Member
Travis's Avatar
Are the head studs really too thin? I haven't heard anyone complain that they are having problems with them stretching or anything.
- Travis
Travis is offline   Reply With Quote
Old 02-28-2011, 04:33 PM   #10
ReycleBill
ReycleBill's Avatar
Quote:
In my opinion, the fact that they must be re-torqued most every year indicates they are less than they could be.
Old 02-28-2011, 04:34 PM   #11
ReycleBill
ReycleBill's Avatar
Quote:
DLD1
Now I must check to see which I ordered.
Old 02-28-2011, 05:28 PM   #12
retiredgentleman
XS650 Guru
retiredgentleman's Avatar
This link has a ton of good information:
http://xs650temp.proboards.com/index...lay&thread=327
Copper washers work very well on the large studs. Proper torqing is super important, and retorqing after the engine has been run. Make sure you have a good torque wrench.
Removing or re-installing an engine is a 2 person job. It weighs 165 lbs................why would you want to injure yourself by doing it solo???? A couple of pipes and some nylon slings makes engine handling a piece of cake.
78SE, Pamco Ignition with E-advancer and Accel #140403S Coil, dual bridge rectifiers, VR-115 regulator, LED tail/brake, BS38 carbs, OEM air boxes, OEM manifolds, OEM exhaust, Heiden Oil filter/cooler, 17/33 gearing, analog voltmeter, Brembo 4 piston calipers front and rear, "All Balls" roller steering bearings
retiredgentleman is offline   Reply With Quote
Old 02-28-2011, 05:48 PM   #13
ReycleBill
ReycleBill's Avatar
Great stuff there. I find it interesting that the subject of PCV (Positive Crankcase Ventilation) was mentioned as I've been wondering if this could be a possible cause (additional factor?) of blown gaskets.
And the photograph will be remembered always.
Old 02-28-2011, 06:22 PM   #14
rwingsfan
Xs 650 Dummy
rwingsfan's Avatar
I put mine in and out by myself most of the time, really not that hard. You do not have to gorrilla it either. I put it on a jack rollit over beside the bike grab on and put her in laterally. Course no one ever confused me with a smart person.
2012 Harley Road Glide
1980 Harley Shovelhead
1997 Mustang convertible
rwingsfan is offline   Reply With Quote
Old 02-28-2011, 06:27 PM   #15
CDNTX650
XS650 Guru
CDNTX650's Avatar
I don't think so. I just check head bolt torque as part of my yearly look over.
Old 02-28-2011, 07:05 PM   #16
xschris
rock and roll man!
xschris's Avatar
pulled my engine by myself, of course i had beer power!
1979 xs400 2-f, 1980 xs400 SG, 81 xs400 SH, 82 xs400 heritage
xschris is offline   Reply With Quote
Old 02-28-2011, 07:21 PM   #17
MacMcMacmac
Laconic
MacMcMacmac's Avatar
I pulled a Seca Turbo motor by myself. It was a heavy bastard.
Depending on the thread pitch and length, you might check and see if some of the high perf dragbike engine studs from APE performance could be used. Might not be the cheapest route, but they are about the strongest studs you will find.
83 Heritage, superbike bar, halogen light, mini gauges, re-pop gas tank/sidepanels, Brit style taillight, New headers with Commando Pipes, 31 tooth sprocket, starter gear repair, $5 Canadian Tire fusebox, AGM battery, cafe style seat, Honda 750 ACE shocks. 2nd gen Virago bar clamps. More to come..
MacMcMacmac is offline   Reply With Quote
Old 02-28-2011, 07:30 PM   #18
XSLeo
XS650 Guru
XSLeo's Avatar
If you click tech at the top of the page and scroll down to homemade tools, browse the tools you will find several ideas on engine removal tools. I like the u-shaped, long handled tool that you hang from the ceiling. I think you could use it across a wheeled office chair too.
The only way you can find out if you can do something is to try.
75 XS650B with a few mods, Dual disc brakes up front, Disc on rear, Pamcopete Ignition with the green coil, Radio Shack rectifier and Chrysler regulator, LED tail/brake and turnsignals. 750 kit,1.5 headepipes, Emgo shorty mufflers.
XSLeo is offline   Reply With Quote
Old 02-28-2011, 07:34 PM   #19
ReycleBill
ReycleBill's Avatar
So does anyone know the thread pitch, length and other dimensions-- I've not yet opened mine up.
Old 02-28-2011, 09:02 PM   #20
Punkskalar
Hugh's HandBuilt
Punkskalar's Avatar
Bill,
Contact ARP with the measurements you need. They will set you up with some headstuds that won't go ANYWHERE. I've used their studs on all kinds of things in the past that "stock" was not good enough for.
All NEW Website, Tech Articles, Products and more from Hugh's HandBuilt - check it....
www.HughsHandBuilt.com
*There is never a charge for Tech Support even if you don't purchase from us - We are Enthusiasts Helping Other Enthusiast and that is just the way it is
Punkskalar is offline   Reply With Quote
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
Exhaust gaskets Downer The Garage 4 12-17-2010 05:44 PM
For Sale - NEW carb bowl gaskets for 79 XS 650 camo Classifieds 2 12-01-2010 01:34 PM
Yamabond on top and bottom of gaskets? rodemyyamaha The Garage 3 10-23-2010 06:29 PM
gasket and sealer or just gaskets WacoBrian The Garage 3 07-18-2010 01:48 PM
Engine/Crankcase Gaskets? cheftay The Garage 5 02-25-2010 12:27 PM
Tags
engine
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
