mrriggs
XS650 Junkie
I DID IT! I DID IT! I finally got these things working. And when I say working, I mean working like a finely tuned fuel injection system. It is absolutely flawless. There isn't even a hint of hesitation or bogging anywhere.
The off-idle transition has plagued me from day one. No matter what I did it was too rich. I had to feather it off of idle and it would blubber and stumble for a split second before taking off. The slides in the newer carbs did not have this issue but they stuck so badly that it made the bike unrideable. Comparing them side-by-side with the older slides I can not see any difference between them. The only thing I can think is that one of the older slides has some sort of manufacturing defect in it. After many miles the bore of the right carb was all sooty looking so I suspect it was the right slide that was bad.
I've known for a while that I should use the newer slides but have been putting it off because they needed to be lapped. When I originally lapped the old slides it took me over four hours and killed my fingers. I recently read a post on the Home Shop Machinist board where a guy showed how he lapped some valve rods using a Dremel contour sander. I got online and found that Dremel has discontinued the contour sander, but lucked out and found a good used one for $20.
The contour sander has an adjustable speed reciprocating head. I think it only moves about 1/16". All I needed to do was make a quick, simple mandrel to mount the slide to the sander.
It's just a wooden dowel with a hole drilled in one end for a wood screw and the other end turned down to fit in the sanding head.
It worked like a charm. I got an excellent finish on both slides and it only took a half hour each. After thoroughly cleaning the carbs I reassembled them, dropped them on the bike and gave it a quick sync. The difference is like night and day. It is so crisp and clean EVERYWHERE. I am so used to the off-idle hesitation that it had, it surprises me now when I crack the throttle and it just goes. It seriously feels like a fuel injected bike. The throttle response is instant and perfect. After all the time and money sunk into these carbs, it is finally worth it.
