XS650 Forum
Go Back   XS650 Forum > General Discussion > The Garage
Register FAQ Members List Search Today's Posts Mark Forums Read
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries, but you have to register before you can post or view attachments. It’s free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Topics
Threads in The Garage can also be viewed by Topic.
Reply
Thread Tools
Old 02-25-2010, 04:04 AM   #1
veedub1955
veedub1955's Avatar
Default Harley Davidson XL Sportster Narrow glide conversion : How To
Hi Im Nick from Denbigh, North Wales UK, currently building a hard tail XS
Here's how I converted my front end to a Harley Davidson 35mm showa forks off a Sportster (XL) or a Superglide (FX). I'm sure you can use the same principle to adapt any other forks to it, I wanted the front end to be narrow with a 21" front wheel and the calipers on this model look really neat and tidy
First of all comparison for lower triple tree and steering stem, as you can see the Harley at the bottom stem is much shorter and narrower
So I chopped the stem off each lower tree using a lathe, you could just grind the welds off if you dont have access to a lathe, there is a weld only on the bottom of each stem that holds it in
XS Tree, I made a bevel cut on each tree so you can weld it up good and strong again after, you will see the break in the weld as a ring once you have broken through
Then cut the harley one too, after cutting the stem I made a cut straight across the face of the yolk, this will serve as a good datum point for holding the yolk on a miller or boring machine, or to clock it in if you use a 4 jaw chuck in a lathe to enlarge the stem hole in the Harley yolk. Also note I cut the rear bracket off the stem that acts as the Harley stop first before putting it in the lathe
Now as mentioned above the XS steering tube is larger than the Harley one so you now need to enlarge the hole to 29.5mm or as I did on a boring machine, enlarge it for an interference fit
Unfortunately Ive lost the pic mocked up on the boring machine, sorry, you can use a miller, lathe with 4 jaw chuck or even a drill but you need this hole to be exactly square and have an interference fit for it to be a decent job, so take this to your local machine shop if your not sure
Now the top yolk amazingly is EXACTLY the right size for the steering tube, I couldnt believe it when it just popped on nice and snug! And is held in by the standard XS top nut
Then all built up using standard XS tapered bearings, looks the business
Now all I need to do is weld the steering stem up, fabricate 2 small steering stops, this also will be a neat job as you can use the XS stop welded to the frame neck, all I going to do is weld two small tabs on the bottom yolk and this will be spot on. I will add another pic of this when done. The XS front axle also fits the forks, it is mounted on in the pic, so if your going to use a standard wheel and sure it will fit OK
Hope this helps someone
veedub1955 is offline   Reply With Quote
Old 02-25-2010, 04:49 AM   #2
inxs
XSively Addicted
inxs's Avatar
Default Re: Harley Davidson XL Sportster Narrow glide conversion : How To
- welcome...i like the look of narrow 21in fronts...how are you going to balance it in the rear?
fear is temporary, regret is forever
inxs is offline   Reply With Quote
Old 02-25-2010, 05:54 AM   #3
veedub1955
veedub1955's Avatar
Hi, Im running a narrow 18" coker on the back, althought that may change yet lol
Old 02-25-2010, 04:34 PM   #4
Travis
Staff Member
Travis's Avatar
That looks awesome, thanks for the write up!
Isn't the XS650 axle 17mm? and don't the forks take a 3/4" (19.05 mm) axle?
"I'll contribute. My first article will be "How to Bag a Skank". Could be my best literary work." - a_robotham
Travis is online now   Reply With Quote
Old 02-26-2010, 04:49 AM   #5
veedub1955
veedub1955's Avatar
To be honest Ive not checked I just slipped the axle in temporary and it nipped up
Ill get back to you on that!
Old 04-19-2010, 09:18 AM   #6
veedub1955
veedub1955's Avatar
Travis is right I only quickly nipped the xs axle up, you do need the harley 3/4" one
Also welded a couple of small tabs on the lower tree for the steering stops, plenty of lock
without any fouls, very happy with this conversion
Old 06-21-2010, 05:21 AM   #7
veedub1955
veedub1955's Avatar
Welded the stem up now and made two steering stops out of hardened 6mm steel dowels.
I recommend drilling the dowel holes up 1st before welding the stem up cause its nigh on
impossible to drill the holes straight if you do, worked out a really neat solution
Old 06-21-2010, 05:25 AM   #8
veedub1955
veedub1955's Avatar
Also had the 77-83 sportster harley hub laced up to a 21" rim, then beadblasted the rear wheel before I powdercoat them black, pics of it as a rolling chassis so you can get an idea on what the front end looks like as soon as the wheels are back
Old 06-21-2010, 07:40 AM   #9
Ironsled77
XS650 GRAND HACK
Ironsled77's Avatar
Very nice write up
Posted via Mobile
Ironsled77 is offline   Reply With Quote
Old 06-22-2010, 01:42 PM   #10
XSLeo
XS650 Junkie
XSLeo's Avatar
Nice job, well written and good pics.
Just a thought, wouldn't it be easier to turn the 650 stem down to match the Harley tree than boring the harley tree to match the 650 stem?
75 XS650B with a few mods, Dual disc brakes up front, Disc on rear, Pamcopete Ignition with the green coil, Radio Shack rectifier and Chrysler regulator, LED tail/brake and turnsignals
XSLeo is offline   Reply With Quote
Old 06-22-2010, 02:33 PM   #11
veedub1955
veedub1955's Avatar
No mate because the Xs stem is hollow and there won't be any meat left in it as the Harley stem is quite narrow
Old 06-22-2010, 04:57 PM   #12
XSLeo
XS650 Junkie
XSLeo's Avatar
Yes, your right didn't think of that.
Old 06-22-2010, 10:03 PM   #13
danno
danno's Avatar
I'd be tempted to leave the front rim alone, and have the rear rim clear coated. I think your wheels make a nice looking couple as they are (but I am sure they will look killer in black, as well).
danno is online now   Reply With Quote
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
New non XS650 project! Harley Evo Custom BigJimmyW13 The Garage 11 02-18-2010 06:47 PM
Tags
h d conversion, how to, suspension
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Copyright ©2000-2010, Jelsoft Enterprises Ltd.
Copyright © 2009-2010 XS650.com, Trav, LLC
