XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. Itís free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 03-27-2011, 10:41 AM   #1
specialman
XS Power
specialman's Avatar
Default 1981 No Spark, Tried everything Ive read...Please Help!
I tried literally everything, but im sure you guys can narrow it down maybe a little bit further but im stuck and lost and im to the point where im about the rip the whole harness out and make a simplified wiring like i did with my 72.
Ok, first off to make things easier I made jumpers to connect the ignition switch. (red, brown, blue) Then i made jumpers to also eliminate the kill switch (red to red)
I then got power to all I think 5 fuses with good voltage. So i tested the Coil (red/white stripe to orange) i got somewhere in between 2.5-3 ohm. Then i tested one lead end to the other without resister caps on I will post exact reading in a couple hours im going out to test everything one more time. I think it was like 11-13 ohms if i remember correctly.
Ok then i tested the pre-coil (inside shifter side case) well i didnt want to stab holes in the wires so i brought up the wiring diagram found out those three wires (which strangely change colors. Where they come out of the unit i think they are black, grey, orange then in the harness plug for the cdi they are green/white black and red but i figured out which ones where which) I tested black to red and black to green i got a little under .700 for the one (i think like .697) and a little over .700 for the other.
I dont know what else to test if someone has some idea(s) that would be great but if i cant get this thing figured out soon, im ditching the whole harness and making a simplified one.
A little history on this bike i bought it stock 2 yrs ago (ran great) last yr i sold it to a guy and he cut the frame and in general just f'd this thing up (without even riding it)
Then told me he couldnt get any spark. When i got it back he had the grounding strap on the opposing side of where the positive goes on the starter selonoid. But he didnt have any battery in it. I immediately fixed that once i got that home and i have been tinkering around on it since but it has me right now this bike has less than 10k miles on it, i just dont see any resonable explanation for this thing not having spark.
Kevin
I just want to
specialman is offline   Reply With Quote
Old 03-27-2011, 10:51 AM   #2
DADDYGCYCLES
DADDYG
DADDYGCYCLES's Avatar
Default Re: 1981 No Spark, Tried everything Ive read...Please Help!
From what you are say its a stock bike with stock harness correct!
Get a test light or volt/ohm meter and see if you have 12 volts to coil and to TCI unit.
No 12 volts then something not hooked up. There are only a couple wires that have to be hooked up to get spark. Here is a diagram that may help you a little. Its for a chopper but close to same and if all the wires are screwed up anyhow just follow this and you will have 12 volts and if all the parts are good spark. You have TCI black box and REG/REC correct.
DADDYGCYCLES is offline   Reply With Quote
Old 03-27-2011, 11:04 AM   #3
gggGary
Old guy, NO expert.
gggGary's Avatar
Did he weld on the bike??
Hope the TCI didn't get smoked if he did.
"The goal of the forum is sharing our experiences and what we've learned,
not dismissing the ideas of others"
gggGary is offline   Reply With Quote
Old 03-27-2011, 11:04 AM   #4
specialman
XS Power
specialman's Avatar
yes this is correct! I will test them in a little bit. I have the battery back on the charger right now.
Old 03-27-2011, 11:04 AM   #5
specialman
XS Power
specialman's Avatar
i have 2 "tci" units to test and try with.
Old 03-27-2011, 11:59 AM   #6
littlebill31
Smells of Raw Fuel
littlebill31's Avatar
How do you test for spark? I ask 'cuz pulling off a cap, as I have seen people do, without grounding the spark plug to the engine, can fry the TCI. Some just pull the plug and cap and look at the plug while they turn the engine or pull off the cap to tune by using the "dead cylinder" method. Can't do that with the TCI.
"People are often misquoted on the Internet."- Abe Lincoln
4 out of the 5 voices in my head say, "Go for it!!"
littlebill31 is offline   Reply With Quote
Old 03-27-2011, 02:45 PM   #7
specialman
XS Power
specialman's Avatar
i hold the threads of the plug to the heat sink fins on the cylinder. Is this not correct? Thanks in advance for any insite..
Old 03-27-2011, 03:10 PM   #8
littlebill31
Smells of Raw Fuel
Ya, holding it to the fins is fine. That's what you want to do so it, essentially, arcs. I mean that some don't and either just pull the boot or don't ground it. This is ok for points engines, a big no-no for TCI.
Click image for larger version
Old 03-27-2011, 03:15 PM   #9
gggGary
Old guy, NO expert.
gggGary's Avatar
grab about 2' of bare copper house wire, wrap an end around each plug let it touch the engine and you won't need three hands to keep everything from flopping around while you crank it over.
Old 03-27-2011, 03:21 PM   #10
retiredgentleman
XS650 Guru
retiredgentleman's Avatar
If the bike still has the stock 4 position glass fuse type of fuseholders......................they are very unreliable......................replace with automotive blade type fuseholders. They can look good, but have high resistance, causing voltage drop to the ignition. The kill switch is another item that can cause voltage drops.
Pick-up coils should be about 700 ohms. High voltage from lead to lead should be about 11K ohms, without resistance caps.
78SE, Pamco Ignition with E-advancer and Accel #140403S Coil, dual bridge rectifiers, VR-115 regulator, LED tail/brake, BS38 carbs, OEM air boxes, OEM manifolds, OEM exhaust, Heiden Oil filter/cooler, 17/33 gearing, analog voltmeter, Brembo 4 piston calipers front and rear, "All Balls" roller steering bearings
retiredgentleman is offline   Reply With Quote
Old 03-27-2011, 04:24 PM   #11
DADDYGCYCLES
DADDYG
None of you guys have a spark tester? You can get them at a lot of places. I think i got mine threw DENNIS KIRK. It goes between the plug and cap and shows the spark or you can just ground the plug when you take it out. I have never burned up a TCI testing spark you are only cranking motor for a couple seconds. If you don't see spark on first couple cranks there is none. They even sell spark plug caps that light up when they fire you could use those too. I just wouldn't do it without a good ground on after market ignitions because some of there directions say that you could burn up there unit.
Old 03-28-2011, 10:38 AM   #12
srinath
srinath's Avatar
I am actually in the same situation, only worse off. Mine is an 81 with stock wiring but a lot of the relays etc removed and bypassed for the sake of eliminating bad relays.
The ignition coil tests like he said, 11K ohm secondary, 3.2 ohm primary.
The pickup's also test right @ 700.
The thing started and ran a few mins ~2 weeks ago.
Then I have not had spark for nearly 2 weeks. I intermittently got a weak spark but never got it to start.
Then I pulled off the ignition box and opened it, man is it easy to open, and the egg shaped diodes that go bad - were already swapped out for nice cylindrical radioshack ones. That leaves that transistor. I picked up a tip 120 @ radioshack, but haven't installed it yet. However my question revolves around that transistor.
I have a transistor tester that is supposed to respond in 1 position in the low drive mode and in 2 adjacent positions in the high drive. It also should ahve under 1% leakage and what not. The one in the board responds in 1 position in high and none in low. However it tests very good for leaks, nearly 0.
Anyway I am thinking of putting in that tip120 just to look for spark. Or can anyone tell me what else could be going on.
Thanks.
Srinath.
srinath is offline   Reply With Quote
Old 03-28-2011, 10:59 AM   #13
xjwmx
XS650 Guru
xjwmx's Avatar
^Do the joints for the diodes look like the rest? They might be original, or somebody might have already thought it was bad and worked on it.
Since the wiring has been changed, I'd get one of the simplified diagrams with TCI and check with a meter power, ground, pickup connections, and coil connections to the TCI. Tighten up and clean the connectors, etc. Also check the plug wires and caps. When you take the measurements, clip the leads on and move the wires around to try find an intermittent connection.
xjwmx is offline   Reply With Quote
Old 03-28-2011, 01:14 PM   #14
specialman
XS Power
specialman's Avatar
i just picked up a $40 harbor freight special with a bunch of spools of different color wire. I am going to use the diagram above to re-wire it with basic needs. Wish me luck!
Old 03-29-2011, 05:39 PM   #15
XSLeo
XS650 Guru
XSLeo's Avatar
Some one found a bad zener diode in there TCI. If you look thru the threads about fixing the TCI boxes you will find it.
The only way you can find out if you can do something is to try.
75 XS650B with a few mods, Dual disc brakes up front, Disc on rear, Pamcopete Ignition with the green coil, Radio Shack rectifier and Chrysler regulator, LED tail/brake and turnsignals. 750 kit,1.5 headepipes, Emgo shorty mufflers.
XSLeo is offline   Reply With Quote
Old 03-29-2011, 05:47 PM   #16
xjwmx
XS650 Guru
xjwmx's Avatar
specialman, when I said check out a simplified wiring diagram, I meant to use it to check your voltages with (because it's much easier to read than the one in the manual). But rewiring it with it might not be a bad idea! If the po/pm messed it up and never rode it, no telling what its wiring's like now.
Here's a thread on wiring that's current:
http://www.xs650.com/forum/showthread.php?t=7192
Current, get it? Ha ha! Current. Ummmm never mind.
Old 03-30-2011, 02:22 PM   #17
specialman
XS Power
specialman's Avatar
lol thx i got spark but i need to clean up the carbs and sync them so this thing will stay running
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
The best thing you ever read. xjwmx The Lounge 69 08-25-2011 10:06 AM
Will a 1981 Maxim chain guard fit a 1981 XS 650???? Maverick The Garage 4 09-01-2010 09:09 AM
read my plugs please. bradshaw106 The Garage 6 07-30-2010 06:36 AM
News and Info Forum is Read Only! XS650 Site How-To Articles 0 09-28-2009 06:49 PM
Classified Forum Rules - READ HERE FIRST BEFORE POSTING OR REPLYING! XS650 Classifieds 0 08-30-2009 11:13 AM
Tags
electrical
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
