XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. Itís free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
Notices
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 04-05-2011, 05:07 PM   #1
Stone
Just Livin
Stone's Avatar
Question How to free up a stuck clutch?
searched a bit but didnt find exactly what I was looking for, whats the best way to free up a clutch that is stuck? the right way that is...not starting it and popping it in gear...
or if anyone knows where a previous thread is at I would appreciate it. trying to get this done as we speak so any help would be much appreciated.
Thanks
Stone is offline   Reply With Quote
Old 04-05-2011, 05:09 PM   #2
littlebill31
Smells of Raw Fuel
littlebill31's Avatar
Default Re: How to free up a stuck clutch?
Taking it apart is the best, most secure way. Or... Put it in gear, pull in the clutch, and start kicking.
"People are often misquoted on the Internet."- Abe Lincoln
4 out of the 5 voices in my head say, "Go for it!!"
littlebill31 is offline   Reply With Quote
Old 04-05-2011, 05:45 PM   #3
78whiteorbs
78whiteorbs's Avatar
If you can get it into neutral just find a steep hill and dump it into second while feathering the clutch lever in and out > Worked for my bike
78whiteorbs is offline   Reply With Quote
Old 04-05-2011, 06:11 PM   #4
Stone
Just Livin
Stone's Avatar
damn thats tempting
Old 04-05-2011, 06:52 PM   #5
littlebill31
Smells of Raw Fuel
It's really fun too. Just make sure you have a helper to push back up.
Old 04-05-2011, 07:20 PM   #6
jamesgs4
fuck this, let's ride!
jamesgs4's Avatar
seafoam in the oil, warm up the bike in neutral. push the bike up to speed and hop on, shift it into 1st or second and ride it around a little bit, pulling the clutch and releasing it, should free up pretty quickly. oil change after a few miles.
jamesgs4 is offline   Reply With Quote
Old 04-05-2011, 07:52 PM   #7
rude
rude's Avatar
The right way? pull it apart, separate the plates, I did this to mine a few months ago and the clutch has "re stuck" since due to sitting (waiting for paint to get done).
Reading other threads on this clutch problem indicates I need to deglaze the steel drive plates, this is done by rubbing the plates on the concrete floor in a figure 8 pattern to scuff them up, I've also got a new set of friction plates to go in.
This "deglazing" suggestion is arguable, some have done it this way for years, I had a Ducati that needed this done every 10 to 15000klm to reduce clutch slip, any way that's my next step to unstick them and keep them unstuck.
Any alternate views on the method of deglazing out there...........
cheers
rude is offline   Reply With Quote
Old 04-05-2011, 07:55 PM   #8
cpt137
cpt137's Avatar
get it running, get moving it first after the oil has warmed up, pull the clutch in and keep accelerating and backing off the throttle. Worked every time for me.
cpt137 is offline   Reply With Quote
Old 04-05-2011, 08:31 PM   #9
Stone
Just Livin
Stone's Avatar
success, its working maybe not 100% but its progress haha
Old 04-05-2011, 08:55 PM   #10
XSLeo
XS650 Guru
XSLeo's Avatar
The way littlebill suggested works well and you don't have to push it home tired.
Pulling it apart is the best.
When I had mine apart I used some 120 sandpaper to sand off the burr left from when they stamped the steel plates out.
The stamping process leaves a burr on the inner teeth and on the outside diameter. The burr on the teeth can grab on the hub and slow the action or even hold the plates apart.
I also used the 120 to clean off any colored spots. All the same color.
The roughness left after sanding grips very well.
I also put in new Forodo friction plates and heavier springs. No slipping and with the cable and worm well lubed, and properly adjusted it pulls ok. I can pull the lever with two fingers.
The only way you can find out if you can do something is to try.
75 XS650B with a few mods, Dual disc brakes up front, Disc on rear, Pamcopete Ignition with the green coil, Radio Shack rectifier and Chrysler regulator, LED tail/brake and turnsignals. 750 kit,1.5 headepipes, Emgo shorty mufflers.
XSLeo is offline   Reply With Quote
Old 04-05-2011, 09:02 PM   #11
ReycleBill
Part Time Tyrannicide
ReycleBill's Avatar
cheers
I had a Harley that occasionally required me to pull the clutch plates on the side of the road and scrape them on the concrete curbs just so I could get it home. Those old Shovels were so easy to work on...
When the going gets tough the tough twist the throttle! Hard!
StolenMotorcycle.net helping you get your bike back in one piece!
ReycleBill is offline   Reply With Quote
Old 04-06-2011, 10:23 AM   #12
Stone
Just Livin
Stone's Avatar
ha soooo those screws are in there pretty good huh?
Old 04-06-2011, 06:39 PM   #13
XSLeo
XS650 Guru
XSLeo's Avatar
The six for the springs? Yes they can be a bit tight. A hand impact tool is just the ticket to get them out. The tool you hit with a hammer, not plug in the air hose, or wall.
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
Stuck/Stripped Clutch bolt Axel The Garage 19 05-15-2012 12:08 PM
Ethanol free gas ontherocks The Garage 0 01-08-2011 06:57 PM
Free shipping Rock-A-Billy ChopperS Shops 0 09-28-2010 11:58 AM
one stuck clutch please matt81xs The Garage 5 03-01-2010 06:14 PM
For Sale - Free beer! danno Classifieds 18 02-10-2010 10:17 PM
Tags
clutch
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
