XS650 Forum
Go Back   XS650 Forum > General Discussion > The Garage
Register FAQ Members List Search Today's Posts Mark Forums Read
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries, but you have to register before you can post or view attachments. It’s free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
Notices
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Topics
Threads in The Garage can also be viewed by Topic.
Reply
Thread Tools
Old 03-07-2010, 01:13 PM   #1
cheftay
Keepin' it real
cheftay's Avatar
Send a message via AIM to cheftay
Default removing camshaft bushings??
I'm trying to replace the camshaft bushing, aka the breaker shaft bearing...
Any tips on doing this??
Thanks a bunch!
chef
1971 XS1B - almost restored
1975 XS650 - basket case - cafe build
1980 XS650 - basket case - bobber build
cheftay is offline   Reply With Quote
Old 03-07-2010, 01:18 PM   #2
inxs
XSively Addicted
inxs's Avatar
Default Re: removing camshaft bushings??
- oops:thumbsup:
edit...all of mine are roller bearing, but ive just been reading that some are bushed ? ...i wonder, if so, if you could drill them like the clutch pushrod bush
fear is temporary, regret is forever
inxs is offline   Reply With Quote
Old 03-07-2010, 01:42 PM   #3
cheftay
Keepin' it real
cheftay's Avatar
any other ideas?
Old 03-07-2010, 01:52 PM   #4
inxs
XSively Addicted
inxs's Avatar
- do you have a bush or a roller bearing in there...well, ive never had to do this, but i could imagine using a long thin brass drift to tap them out from behind, or a small bearing remover to pull them out
Old 03-07-2010, 03:06 PM   #5
cheftay
Keepin' it real
cheftay's Avatar
hmmm maybe I need one of those..
its part number 05-033 and 05032 http://www.mikesxs.net/products-26.html#products
Old 03-07-2010, 03:26 PM   #6
cheftay
Keepin' it real
cheftay's Avatar
Do you think a drift set from harbor freight would work? http://www.harborfreight.com/cpi/cta...emnumber=66337
Old 03-07-2010, 03:48 PM   #7
inxs
XSively Addicted
inxs's Avatar
- i doubt theyre long enough..go to a building centre or home depot or such and get a length of brass rod, thinner than the points/advance timing rod, cut say 150mm longer...you want to put a flat or slightly concave surface on the drift end
- do you have the points and advance housings off yet...they can be somewhat problematic...
Old 03-07-2010, 03:53 PM   #8
cheftay
Keepin' it real
cheftay's Avatar
Yeah I've got the housings and everything off, I even have the cam pulled out of the engine..
When I use a drift to get them out, Do I go all the way through from the opposite end and just know the one bushing out? and then do the other side the same way?
...Kind of a dumb question maybe but i've never used a drift before
Old 03-07-2010, 04:02 PM   #9
jay760
jay760's Avatar
I used a 12mm anchor bolt expanded inside and hit out from the other side.
jay760 is offline   Reply With Quote
Old 03-07-2010, 04:06 PM   #10
inxs
XSively Addicted
inxs's Avatar
- yeah...but use a small hook first to make sure there is a lip on the inside you can use
Old 03-07-2010, 04:07 PM   #11
inxs
XSively Addicted
inxs's Avatar
- hey, thats a great idea jay...gotta remember that one
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
Removing Clutch Centre Nut Ben Mccree The Garage 8 07-23-2010 08:50 PM
riser bushings Tech7 The Garage 1 02-14-2010 01:27 PM
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Copyright ©2000-2010, Jelsoft Enterprises Ltd.
Copyright © 2009-2010 XS650.com, Trav, LLC
