Sundie
Jabroni
So, just to give context, i freshened the top end this winter, replacing a bad head gasket and bottom gasket. After the initial ride last weekend, the right cylinder was smoking quite a bit, and oil consumption was high. Like 1 litre per 100km high.
Pulled the plugs, oil soaked. Kind of baffling. Checked compression, was fine at 125+. Checked the valves, and looked into the intake runners - intake was greasy, which was weird, since the guides were perfect, and new valve guide seals were installed.
Started checking things out, and after finding that my crankcase breather vents into the stock airboxes weren't passing a lot of air, thought maybe the breather was clogged, which would cause excessive crankcase pressure, and certainly push oil down the valves. (and out various engine seals, and and and... Everywhere, really.
I found two rubber plugs in the vent. They had holes through them. They looked like designed reducers - they took the hole from the 8mm or so that they are to 1mm.
Sooooo... I've never found something like this before, and from an engineering point of view, it seems... Non-optimal, to be generous. You *want* the crankcase to be able to easily vent, or possibly under a slight vacuum.
These were restricting so badly, that when you shut the engine off, you could actually hear the engine de-pressurizing with a "phewwwwww" kind of sound.
Anyone else ever seen something like this?
