XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. Itís free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 05-22-2011, 09:32 AM   #1
YL82
Perpetual Restorationist
YL82's Avatar
Default Gasket for Fuel Petcock Drain Plug Bolt (for XS650C)
I ordered two Petcock Rebuild Kits (20-0014) from Mikesxs. I have the original fuel petcocks on my 76' XS650C and I decided to replace the gaskets, etc. on my petcocks instead of buying new ones for around $44 each. My petcocks have 3 screws on the backside.
All is going well, but I'm a little concerned about the diameter of the new red drain plug bolt gaskets that are included in the kit. They seem rather large for the bolt. I do have an inquiry sent to Mikesxs and I'm confident they will advise me on this.
I thought I might just try a run of the mill rubber gasket, but suspect that these rigid red gaskets are constructed of materials that are resistant to degradation from petroleum hydrocarbons such as gasoline.
I've looked at other websites (bikebandit, motogrid Yamaha, etc.) to find an OEM repalcement gasket, but nobody seems to have one available for Part Number 801-24437-00-00.
Comments, Anyone? THANKS!!
Here are some images:
1 - New gasket installed under drain plug bolt (hanging over).
2 - New gasket and petcock drain plug bolt
3 - Fuel Petcock (R) for XX650C.
4 - Old worn out gasket on drain plug bolt.
1982 XS650J Heritage Special
YL82 is offline   Reply With Quote
Old 05-23-2011, 04:43 PM   #2
XSLeo
XS650 Guru
XSLeo's Avatar
Default Re: Gasket for Fuel Petcock Drain Plug Bolt (for XS650C)
Are the gaskets for the fuel barbs the same size? If not try swapping them.
The only way you can find out if you can do something is to try.
75 XS650B with a few mods, Dual disc brakes up front, Disc on rear, Pamcopete Ignition with the green coil, Radio Shack rectifier and Chrysler regulator, LED tail/brake and turnsignals. 750 kit,1.5 headepipes, Emgo shorty mufflers.
XSLeo is offline   Reply With Quote
Old 05-23-2011, 05:14 PM   #3
Grinder
XS650 Guru
Grinder's Avatar
Found the same thing on my 77. Ended up just re-using the old ones. Don't they actually try these parts on the petcocks before they sell this stuff?
Grinder is offline   Reply With Quote
Old 05-23-2011, 06:52 PM   #4
5twins
XS650 Guru
5twins's Avatar
I've heard you can boil those red bakelite washers and they'll swell back up so you can re-use them. Never tried it myself but it's worth a shot. I wouldn't use the ones in the kit.
'78E Standard and 4 Euro twins
5twins is offline   Reply With Quote
Old 06-08-2011, 04:57 AM   #5
YL82
YL82's Avatar
To follow-up on this, Mikesxs mailed me the correct red bakelite gaskets for the drain plug screws for my petcocks.
Apparently, their description of the Petcock Rebuild Kit (#20-0014) misidentified the gasket in the kit as the Drain Screw Gasket instead of the Fuel Barb (dare I say it...Nipple) Gasket that it actually is.
They sent a letter indicating that they will have their suppliers ensure that one (1) drain screw gasket is actually included in the kit from now on.
I've not seen any revision to their website image and description for this Kit yet...
Oh, On a related matter, I have a pair of Viton Rubber gloves (probably 24 mil). I used a Cork Borer Set to cut out some Viton gaskets for the drain screw (while I waited on Mikesxs).
They look pretty good, though I haven't tried them yet.
Does anyone have any experience using Viton Rubber gaskets on XS650 Fuel systems?
I've read that Viton Rubber has good resistance to materials like gasoline.
Old 06-08-2011, 08:39 AM   #6
bluebikerblan
Geezer
bluebikerblan's Avatar
Quote:
Neither would I 5twins....Use the old ones that fit as is
"Bakelite" is a cured thermosetting phenolic resin 5twins boiling it will do little if anything to help it's ductility. I think you may be thinking of "Nylon"....(polyamide thermoplastics) whose ductility is reinvigorated by hyrolyzing.....boiling water bath helps with a lot of "Nylon" parts which have become brittle with age. Zip ties eg...."fresh again" Blue
bluebikerblan is offline   Reply With Quote
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
Need pics of fuel lines/petcock/carbs slackjaw44 The Garage 1 03-18-2011 03:30 PM
Quick fuel petcock question MB-Ian The Garage 3 11-25-2010 11:45 AM
Petcock/Fuel Flow bpd106 The Garage 4 09-21-2010 08:46 PM
Where to get drain plug crush washers? gentlemanjim The Garage 7 04-22-2010 08:34 PM
Wanted - Fuel Cap/Aluminum bung, Petcock Sources ChuckD Classifieds 2 02-18-2010 02:03 PM
Tags
carburetors
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
