XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. Itís free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 06-03-2011, 01:57 AM   #1
132zed
132zed's Avatar
Default DIY Suicide clutch with Jockey shifter
You know sometimes things can seem SO simple that you must be missing something. Things can never be simple. They are always complicated. If you think itís simple then there is a factor that is missing.
And thatís where I stand.
Iíd like to have a suicide clutch and a jockey shifter. For the jockey shift I was picturing taking the shifter lever, cutting the peg off, turning it vertical (or at 140 degrees..Depends on the angles), drilling holes, attaching a random Ĺ inch (diameter) rod I have. Sure Iíd have to bend it a bit to get the angles right butÖthat seems to be it. Just throw a die on the top and put whatever you want on it.
For the suicide clutch I thought about a bracket bolted in the stock control location. Run the cable toward the back of the case and underneath. Run it through the bracket giving you the stability you need to actuate and on to the forward controls.
It canít be that simple. Help me out guys. What am I missing? Is this even possible?
132zed is offline   Reply With Quote
Old 06-03-2011, 02:46 AM   #2
SKRIBLZ
xs650 newbie
SKRIBLZ's Avatar
Default Re: DIY Suicide clutch with Jockey shifter
I will send you pics of my set up in the morning
I just tried to take some but my garage light wasnt bright enough
SKRIBLZ is offline   Reply With Quote
Old 06-03-2011, 02:51 AM   #3
AussieHard
AussieHardTail
AussieHard's Avatar
There are a few guys with suicide shift on here.
I think Punkskalar might have one
Definitely 650Jarrett his Wabi Sabi bike also has one.
http://theflyingxs.blogspot.com/
74, 78, & 80 XS650s
AussieHard is offline   Reply With Quote
Old 06-03-2011, 07:45 AM   #4
grepper
fiddle futzer
grepper's Avatar
For foot clutch mod see http://www.xs650chopper.com/2010/10/...-suicide-ride/
XS650SG-stock (sold), XS650SF-bob, XS650E-stock, 75 CB750 K5, 79 CB750 K. 81 CB750 K, 2001 Honda Valkyrie Interstate, 2004 Wahoo Scooter
grepper is offline   Reply With Quote
Old 06-03-2011, 08:49 AM   #5
blackbetty
XS650 Junkie
blackbetty's Avatar
I'll be running a foot clutch jockey/shift set up on my '75.
Running a foot clutch using the factory clutch cable is a simple solution, but apparently it's much more susceptible to breakage (Andy at Pangea runs a cable operated foot clutch, as do the fong bros.). The mod grepper mentioned is also is decent albeit a little shanty; Bill Norton perfected the design with a super elegant solution that maintains clutch adjustment and utilizes a machined collar with a bronze bushing to support the shaft.
I contacted him, sent him my cover, and he machined a TRICK modified worm gear for me. This is the way to go for a no hassle foot clutch; however, in order to keep the lever from slipping, one has to use a double clamp shaft collar. He also keeps the cable catch on the inside of the worm gear should you ever decide to go back to standard clutch.
I should be able to get a super accurate adjustment out of this because I don't have any cable slack to account for either.
I'd like to see what tricks ol Hugh used underneath his cover....
Check it out, this is my actual cover and worm gear:
blackbetty is offline   Reply With Quote
Old 06-03-2011, 12:00 PM   #6
grepper
fiddle futzer
grepper's Avatar
BlackBetty: That looks WAY better than the one on xs650Chopper.com!
How much did her charge you for that?
Old 06-03-2011, 12:21 PM   #7
DADDYGCYCLES
DADDYG
DADDYGCYCLES's Avatar
I make them up all the time and have done some like HUGH and also my own style
I think it looks nicer when its all compact and easy to adjust. When you make outside bracket you got to adjust alot. The one in the cover is just useing the stock stuff.
DADDYGCYCLES is offline   Reply With Quote
Old 06-03-2011, 12:30 PM   #8
blackbetty
XS650 Junkie
blackbetty's Avatar
I paid Bill $75 to turn the part plus shipping both ways. Cost me $100 total, but clearly it's the toughest solution.
DaddyG, cool solution for guys who don't mind putting an extra hole in the case cover; does that linkage hold up? I found that unless I used high precision heims the linkage will have too much slop. I also found that when using a design like Bill's, heim joints are necessary since the shaft will rotate within the case when the clutch is disengaged, creating a certain degree of misalignment.
Old 06-03-2011, 01:22 PM   #9
DADDYGCYCLES
DADDYG
Linkages holds up have three running around like that and i did try the other way but you have to put a stop in or you push too far and clutch disingauges. You have enough room for Heims in cover if you want to get fancy but throw is so short there is no tork on it. Cheap easy way and clean.
Old 06-03-2011, 10:34 PM   #10
SKRIBLZ
xs650 newbie
SKRIBLZ's Avatar
Here is how mine is set up looks pretty simple
Video 31 0 00 00-01.jpg   Video 34 0 00 00-01.jpg   Video 33 0 00 00-01.jpg   Video 32 0 00 13-12.jpg
Old 06-03-2011, 10:43 PM   #11
132zed
132zed's Avatar
Thanks to everyone for their input. And thank you Blackbetty/Daddygcycles for including all the pics and info. Bill's mod is simple and doesn't modify the case cover. It looks like you could easily take that right back to the traditional setup without much work.
Blackbetty, how is the functionality? Is it worth paying someone else to do it?
Old 06-03-2011, 10:59 PM   #12
132zed
132zed's Avatar
Thanks skriblz. It looks like your set up is pretty much Bill's with the addition of a spring. Why the spring? Was there a problem with it not retuning?
Old 06-03-2011, 11:35 PM   #13
pamcopete
Ride.Enjoy.Life is Simple
pamcopete's Avatar
Why not just swap the brake and clutch levers. MikesXS has a hydraulic clutch Master Cylinder that can be used as the brake MC on the left side. Easy enough to mount a clutch perch on the right side.
pamcopete is offline   Reply With Quote
Old 06-03-2011, 11:59 PM   #14
132zed
132zed's Avatar
Wait. I am think of working the throttle and the clutch with the same hand. Does anyone have any experience with that? Seems...difficult if not impossible.
Old 06-04-2011, 12:20 AM   #15
azman857
XS650 Guru
azman857's Avatar
Can't be done. Front brake is rt side.Brake clutch and throttle on one side? Nope cant be done.
I don't have a plan and I'm sticking to it! '80 SG with CND needles (#4 slot)and jet, #45 pilot and 135 mains. 256 cam. Pamco igntion w/ E advance. Ditched the buckhorns and installed superbike bars. Stainless steel brake lines front and rear, Dual front disc brake, Radio Shack/Chrysler Rectifier Regulator. AGM battery. Koni 7610 shocks. Ultimate coil. More changes in the future
azman857 is offline   Reply With Quote
Old 06-04-2011, 12:37 AM   #16
132zed
132zed's Avatar
Azman857, I don't think that is what he meant. He meant clutch on the right and brake on the left. And not everyone's FRONT brake is on the right side. I don't have a front brake so my lever is hooked to my rear brake with no right foot control. Just a lonely peg. If working the throttle and clutch with the same hand is possible I wouldn't mind trying it. I would have no foot controls. Never seen that before. I've seen no hand controls (besides the throttle of course) but never no foot controls.
Old 06-04-2011, 12:50 AM   #17
XSJoel
XS650 Junkie
XSJoel's Avatar
Hmm, no foot controls? Left hand clutch, right hand brake and throttle and a jockey shift could be really interesting.
XSJoel is offline   Reply With Quote
Old 06-04-2011, 05:04 AM   #18
pamcopete
pamcopete's Avatar
Quote:
OK. Lets try this again. This arrangement would result in:
1. Clutch and throttle on the RIGHT side of the handle bars.
2. Brake on the LEFT side of the handle bars.
3. Rear brake still available with the RIGHT foot when you need to downshift and brake at the same time.
Old 06-04-2011, 05:05 AM   #19
DADDYGCYCLES
DADDYG
skriblz
How do you adjust the clutch play on that setup?Do you take it apart then do it.
Pete
I have seen that done on a HARLEY with internal clutch lever . Looks like you foot clutch it BUT you are taking the fun out of falling over on hills when you have both feet up.
Old 06-04-2011, 01:30 PM   #20
angus67
xxxxxxxxxxxxxxxxxxxxxxxxx
angus67's Avatar
no foot contrls sound messy, like all over the road messy.
1971 xs1b 3600 miles
1980 xs chop, bored to 680, kick only. ridgid. bs34's xsjohn's needles. 46pilot, 140 MJ.
1972 xl250 (pre elsinore)
2003 suzi marauder. Debaffled, stage 3 carbs.
angus67 is offline   Reply With Quote
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
Jockey shifts DADDYGCYCLES The Garage 26 05-31-2014 01:01 PM
Jockey shift DADDYGCYCLES The Garage 5 02-28-2011 08:27 PM
Suicide/jockey shift?? brackxs The Garage 11 12-05-2010 06:23 PM
Right side jockey shifter OBSIDIAN The Garage 3 12-01-2010 08:20 PM
Jockey shift questions. PAhunter The Garage 8 06-28-2010 04:12 PM
Tags
fabricating, how to
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
