XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. Itís free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 06-13-2011, 10:39 PM   #1
Keegan
Keegan's Avatar
Default valve clearance and spark gap
I'm running a 73 engine with 34mm 1981 cv carbs and a pamco ignition. Also Air pods and strait pipes with baffles but no packing. My question is what do I set the valves at the tx650a/xs650b at in .002 ex .004 or the 1979 and later in .0024 ex .006 setting? I ask because Im going to get less fuel with the 34mm cv's. And what about the gap settings do I set at .024-.028in or the later settings at .028-.032in? Anyone know?
Keegan is offline   Reply With Quote
Old 06-14-2011, 12:24 AM   #2
5twins
XS650 Guru
5twins's Avatar
Default Re: valve clearance and spark gap
Since you have a newer, stronger ignition and coil, you can use the later larger plug gap. It's accepted practice to use the larger valve clearances for your bike as well.
'78E Standard and 4 Euro twins
5twins is online now   Reply With Quote
Old 06-14-2011, 06:19 AM   #3
pamcopete
Ride.Enjoy.Life is Simple
pamcopete's Avatar
Keegan,
5twins is correct. In general, you can open up the spark gap with an electronic ignition system.
The spark gap will depend on which kit / coil you have with the PAMCO. If you have the 17-6822 coil, then .028 to .032" will work. If you have the "Ultimate" 17-6903 coil, then you can open up the gap all the way to .040" . This will produce more power and better gas mileage, but may result in harder starting on a cold morning with a low battery, unless you kick start.
Here is a chart showing the results of a series of test runs that I did with my stock '81/H with various coil / plug combinations. In the final run, the Iridiums were gapped to .040" but I did notice a little harder start first thing in the morning.
I am currently running Autolite #63's gapped to .032" with the 17-6903 coil and I like the overall performance and better starts in the morning. The other thing to consider with the Iridiums is that only one of them really works as advertised do to the positive voltage on one of the plug wires in a wasted spark system. There is a way to determine which is the positive wire and only install the Iridium on the other wire to save a few dollars.
pamcopete is offline   Reply With Quote
Old 06-14-2011, 07:22 AM   #4
Tomterrific
XS650 Junkie
Tomterrific's Avatar
Pete,
Check out the double needle ND / Denso plugs. Purty sweet! Unfortunetly, now only sold in Japan.
The ND plugs use a .04mm iridium center which is even better than the .06mm of the NGK but doesn't last any longer than standard plugs.
Tom Graham
Tomterrific is offline   Reply With Quote
Old 06-14-2011, 08:55 AM   #5
Keegan
Keegan's Avatar
Sweet thanks guys. That helps a lot! Now I just have to get the carbs sorted..
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
Valve Clearance Question pa23driver The Garage 21 02-13-2015 03:18 PM
Ground clearance?? Fro- The Garage 8 10-20-2010 03:15 PM
valve clearance BklynMatt The Garage 10 08-24-2010 06:36 PM
Valve Clearance harmonc The Garage 7 08-09-2010 01:53 PM
Got some more ground clearance!! shreveport1 The Garage 26 10-30-2009 04:11 AM
Tags
engine
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
