Saggs
I've been trying to get my stock 73 running right for weeks. It runs good when I first fire it up after opening the petcocks, then the left cylinder cuts out. I have swapped plugs and leads and the right cyl always fires and runs great. I found tonite that the left cylinder cuts in and runs good after you shut off both petcocks and it starts to run out of fuel. I pulled the bowl at that point and found 1/4" of fuel in the bottom. I have tried to set the float level using a clear hose off the bottom drain and it always reads about 3-4mm below the carb body line. I have cleaned out the carb repeatedly and am at a loss?? Any thoughts?? Thx PS I have a Pamco ignition and the left plug always gets wet but wont fire..
