Electrical question
motorbreath
Dubuque Ia
on this diagram i was wondering, how would i hook up the battery if i wanted on? Also if im only want to be running kickstart should i even have a battery, should i upgrade the points and coil too, i still have stock
- wire it in, in place of the capacitor ... you cant run a capacitor with an original alternator-need a permanant magnet alternator
- i ride batteryless and kickstart all the time, no worries
The battery would go in place of the capacitor. If you are running only kick you can go without the battery. Not sure on the other stuff.
- you cant run the original XS electrical system batteryless, it needs an energised power source for the alternator brushes
- if you replace the original alternator with a permanent magnet alternator then you have the option of running a battery as normal with or without e-start, or batteryless with a capacitor and kick start only
