- Mount headlight properly
DONE!!!
- Find replacement line for clutch
DONE!!!
- finish off foot pegs
Getting there!!!
- mount indicators
FRONT ONES DONE!!
- mount coils
DONE!!!
- mount tacho and speedo
DONE!!
- recon front caliper/s(not sure if I want to go twin or single yet)
Going to scratch that, they don't fit
- mount Boyer ignition
DONE!!!
- add fake oil tank for housing electrics
DONE!!
- add key starter
DONE!!!
- add hi/lo light switch
DONE!!!
- add kill switch
DONE!!!
- add neutral light
DONE!!!
- add spark leads
DONE!!!
-Install Boyer power box
DONE!!!
-Install one way valve on breather
DONE!!!
-Bleed clutch
DONE!!!
- plug excess petcock holes
DONE!!!
- add petcock
DONE!!!
- install fuel line
DONE!!!
- add filter pods
DONE!!!
- sort out exhausts
- add horn
- paint fenders
-Bleed brakes
- replace tyres
- Find replacement brake line for front brake
- fab steering stop
- add chain
- mount front fender
- fabricate rear fender
- mount rear fender
- mount rear light
- paint and drill rotors
- possibly make spacers for calipers/rotors
- mount number plate
- wire entire bike
- mount rear brake switch
- clean gas tank
- paint gas tank
- add oil
- add fuel
- run engine
- tune engine
- get MOT!!
Power box installed!
I added some wire grommets to the holes for some vibration cusioning.
I then used two strips of steel, drilled a few holes, and mounted the box, behind the carbs. Job done! Only took me two hours!
It does look like it's too close to the swing arm, but it isn't
Going to redo the coil mount, I was not happy with what I did.......
