Hey all,
The much talked about clear covers for your any year 650 with a PMA swap are ready to go.
These guys come with brand new stainless hardware, are precision cut and ready to bolt on.
Here is some info about Margard, from emplastic.com
• Excellent optical clarity
• Extremely High Impact resistance – 250 times the impact resistance of glass.
• High abrasion resistance – ideal for applications where frequent contact is likely.
• High weather performance – The surface coating enhances protection against performance losses and yellowing caused by exposure to UV radiation and sunlight.
• Chemical resistance – Lexan Margard has a high resistance to many chemicals such as cleaning fluids, paints and adhesives.
• Anti Vandal Glazing – An ideal solution in areas where there may be a risk of vandalism. The unique coating resists graffiti, enabling easy restoration to a ‘good as new’ condition. It minimizes the risk of costly re-glazing and allows frequent cleaning or removal of graffiti without causing damage.
I made a quick video to show the strength of the cover. As you will see, and I did not think this would happen, the aluminum mounts were no match for the lexan window.
Unfortunately, due to the quick carnage, I was only able to have one go at the video untill I ruined the aluminum cover. But that being said, the lexan window still looks like new. I took a few after shots to show it did come clean, as it was a bit dirty from the rubber mallet in the video.
These are $30, plus $5 flat rate shipping to anywhere in the states or canada. Thats about as cheap as I can go as the material cost is quite high considering they are made from the highest quality polycarbonate available.
To order, Simply send $35 to my paypal,
kellan_musseau@hotmail.com ,and dont forget to write your shipping address in the notes. Upon receiving payment, the cover will be out within a day!
