hi, am reading through a bunch of the threads about axle spacing. With engine in frame, and having .25 inch axle plates, awhile back I'd added Travis's super-spiffy spacer plates outside the frame's axle plates. That left the interior, side to side measurement a bit wide compared to the 8 1/2" of stock swing arm.
It seemed with stock axle adjusters I'd need approximately 1/8 more on each side,
inside the axles plates. But I didn't want to mess with extra "stuff" (washer spacers) each time I'd take the wheel on or off, so I went ahead and also added one MORE of the Travis's spacers to the inside of each of the axle plates. So NOW, measured with calipers, my welded up combo: spacer/axle plate/spacer each now measures just the same as the slotted axle plates on a stock swingarm. (using an adjustable wrench that is marked on both sides, so it can be used as a caliper).
But now, the distance from inner spacer to inner spacer is almost a 1/4" narrower than the stock 8 1/2".
So I could leave it, and just try like heck to shove the wheel, disc brake, axle adjusters and all in there as it is, and see if I can spread it gently that way. OR - should I go ahead and attempt to file or sand down the inner spacers to achieve the exact 8.5"?
If I did that, I'd need to remove 1/16" inch on each inner surface.
If I go that way - abrading/sanding them to be thinner, what's the best way to go?
Grinder with aggressive flap disc would be the easiest way to remove metal, for me....but it wouldn't be nice and flat that way.
A file or metal rasp? Seems that carefully used, that would remove material most evenly, but of course it would take forever.
Or maybe go to Harbor Freight and get one of those el cheapo triangle headed electric sander tools, along with plenty of sandpaper?
Or do it with the grinder and flap disc at first, and then even it up with a good file or metal rasp?
I really like how the axle adjuster area is now beefed-up, so I don't want to remove the inner spacers I added.
My XS chopper project used to be a project that could take forever if I wanted it to, but since having lost my good job over a year ago and having had to sell my 07 Sporty to pay bills, if I want a bike now, I have to make this project work.
My gut feeling is to take it down carefully, first, with a flap disc on grinder - and then, using very even strokes on a surface that has been colored with a marker to show high and low spots, finish up with a file.
(Or!!!!!! figure out a way to remove the built in washers that exist on the Mike's axle adjusters. They look to me to be pressed on with tiny spring steel "pins", and then the hole lightly welded over.)
Anyway, input appreciated. Don't hold back now - I know you are a gnarly bunch. But I sure do value your opinions, as always.
Aunty Em
FL
