Paulrxs650
Snap. I had the same detatchable front guide!
That engine looks very good after your cleaning session. Well done
Your "rough" bearings may be fine and just in need of some fresh grease. I've "fixed" several in this manner. They must be the rubber shielded type though. You can't get into the steel shielded ones. If your originals have the steel shields then yes, replace them. However, even new sealed and "lubed for life" bearings may not have much grease in them. It's best to check them. The rubber seals are pretty easy to pop out using a pick, awl, or small sharp pocket knife ...
Well done, 5T! I've done this a hundred times myself, even to the point of removing the metal shields. You can remove the metal shields with a sharp blade and some determination, but they'll be open forevermore.
- - - Well done, 5T! I've done this a hundred times myself, even to the point of removing the metal shields. You can remove the metal shields with a sharp blade and some determination, but they'll be open forevermore.
Hi Higgy, 5Twins,
I bought a hypodermic needle with a grease nipple on the end.
The needle pierces the rubber shields quite easily and you can punch a little hole in the steel shields, too.
Hi Higgy, 5Twins,
That's pretty clever, Fred! I'm going to keep my eye on you!
This made me think of how sometimes I would use Zep 2000 aerosol grease. The grease came out combined with solvents, and would wash away the old cruddy grease, and then the solvent would evaporate quickly, leaving behind a very nice clear PTFE grease. I've kept a lot of old machinery going in this manner, but I don't think I would actually use this technique on a wheel bearing.
Personally, I'd go with a new bearing just for peace of mind. Those 6203 bearings are only $4-$6 anyway. Cheap insurance.
A bit more progress today, with a question, I have renewed the harness and handlebar controls with ones from mikes I have stateside ones, before the tear down as soon as I turned the key the front and back lights come on the old harness's were butchered, now with the new ones I switch the ignition on and now the lights don't come on is this meant to be this way, I have also installed a PMA. - - -
