Okey doke Cole - I think you've got it now.
What I have learned is that your bike starts and idles fine and you have driven it on the road without any serious issues. To me, that means that the key points are these:
I will close by saying welcome to the group - and enjoy that nice old bike you've chosen!
Pete
PS - DO NOT chop the damned bike up. Just enjoy as it is for now. Once you've learned a bit about it - then snoop around, ask some questions and THEN maybe think about modifying it.
- YES - your bike - and in fact, all bikes, and all cars, airplanes, boats, snowmobiles, lawnmowers, tanks, or whatever - that are equipped with gasoline-fuelled piston engines - DO need a system advance the ignition timing as engine RPM increases;
- YES - if your bike has a 1981 engine installed in it, then your bike likely has a TCI ignition (as near as I can tell from here )
- YES - if that is true then the TCI system already has an ignition timing advance function built into it;
- NO - you do not need a PAMCO, an auto-advance unit, a new set of handlebar streamers - or anything else to make your bike more powerful.
- NO - you will not get any more power out of that engine unless you either repair something that is broken or not working quite right - or you modify something in the intake, the exhaust or the cylinders themselves (like say, the compression ratio.
Pete
