Wanted - Cast Wheels
I have a set of stock cast wheels from a 78 in spanaway, closer to puyallup than tacoma. For the right price I would even separate them from the forks and swingarm. Front is 19" rear is 16".
I have a front with disk for $50.00 plus shipping (tire will be removed)
Yo my man Ratranger......you are talking my language......shoot a price and like Monty Hall used to say, "lets make a deal" WRMDOVR
Hey Daddy.....i feel kinda weird say hey daddy...:-(? anyway.....appreciate the info and if things dont go here in the PNW i will message you. WRMDOVR
I have a bunch of Wheels and a I have not decided which ones I'm going to use most have Rusty spoke s can I put stock cast Wheels on on 1983 heritage
I got a busload of parts this week couple of headlights no bucket ignition boxes regulators brake pedals wiring harness light bulbs For instrument panel calipers Wheels
Bit of a high-jack going on here. Best to start your own Classified thread.............
That being said..............only an 81SH cast mag wheels with drum brake rear mag will drop straight into a Spoke wheel swing-arm, (74-83), without modifications.
78-80 Cast mag wheels swapped into a spoke wheel swing-arm needs modifications done to the swing-arm, (brake stay position change and brackets), and frame. needs mounts and brackets for the M/C and reservoir. Also need to swap the Brake pedal shaft to a Disk brake one required to work the M/C.
In reply to post # 16
I have posted this information as a help to the thread and also as a note and advice for those high-jacking someone else's Classified thread.
I will not respond to any further posts in this thread. I will respond and help where i can in any new threads.
650 skull u da man, tks . now will therear spoke brake assembly fit the cast wheel assembly? the part numbers are the same but for the last 2 digits?
So I got a 78 rear cast wheel with drum brake ,won't work in an 83 heritage with spokes
There is no '78 rear cast mag with a drum brake, they are disc brake only.
If you have a rear drum cast mag it is from an '81.
A rear drum '81 mag will fit an '83, all brake drum parts will interchange.
