Yes 2M..... I see what you mean ....NOW !!!! thanks for the Link ! LOL
I havn't seen shit like that sense the Rotary wing forum ! and I've never gone back !
..... a change of direction is in order Me thinks before I incite a war here !
I was mainly thinking on IMPROVING the bikes handling charturaistics..... you know getting the COG lower, perhaps changing the trail in the front to get away from the "Fall in the turn" syndrome but retaining enough ground clearance to be able to lean hard enough to shed rubber of of both tires in a turn if I so desire...
Now I know the stearing head angle has too much trail for good cornering....(for me anyway)
there are a few ways to combat this, one is a smaller tire in the front,..... and raise the rear suspension.
the other is a cut and re weld of the stearing head angle...... but by how much is the daunting question !
if we look at the best raceing machines out there it might give us an idea of the right geometry for the front end and might not because tire size is usually smaller on them than what comes stock on the XS..... their 2 completely different machine types after all !
that being said, does anyone have access to stearing head angles on some of the bikes that are known to handle real well ?
I used to have all that stuff years ago but lost it in a house fire on the ranch.... I think a triumph Bonyville is a close compairison maybe the tiger 650
not sure, the early ones say '65 or so, up to about 1971 I think before they changes their angles ike all the bike makers did for freeway crusing.
anyway I think Lowering the seat, changing the head angle , wider tires too perhaps and all around ballance is the way to go to make it a great corner carver.....
what do you guys think ????
Bob...........
