Yep, deal of a lifetime.
Scott
Scott
2M thats a lot of info, something i would expect from the engineers here at work. ( I work in a engineering test lab) Very impressive research 2M.Some cable info in here:
http://www.xs650.com/threads/xs650-clutch-cable-experiments-and-tidbits.32945/
Thanks Gary, I found your cable routing post with a little searching after I had posted my question. My cable has some outer case damage so I will be replacing it anyway.That special cable can be used if you change the routing. Actually with super bike bars you about have to run the cable on the RH side of the gas tank to avoid too sharp bends.
http://www.xs650.com/threads/short-...utch-cable-rerouting-ideas.41987/#post-419895
This is an 81 special. When i made the original post I had not seen the bike yet, PO stated it was an 80The drum rear and the x-treme seat would make me think it's an '81. Of course parts can be swapped around.
This bike has the cast grab rail, it has a back rest installed which has the same conture as the grab rail.The tube grab rail vs the cast one was also exclusive.
Thanks for the link, I just ordered 2 cables.The Special clutch cable is slightly longer than the Standard one (only an inch or so) but still works very well with low bars when rerouted. As Gary said, you must run it down the right side of the steering neck and frame. Move the throttle cable routing as well, over to the left side of the neck .....
Most of us use a Motion Pro replacement cable. Best place to get one is Amazon. At this price, buy 2, one to use and one for a spare .....
https://www.amazon.com/Motion-Pro-Clutch-Yamaha-Special/dp/B000OO0WT6
Yes, keeping the cable well oiled is very important. I oil mine once a season.
Yeah. But really common too, if you like it better than the cast one.The tube grab rail vs the cast one was also exclusive.
